7P Recovery Ring
Discussion in 'Recovery' started by BlindingWhiteTac., May 30, 2018.
  1. May 30, 2018 at 10:12 AM
    BlindingWhiteTac.
    BlindingWhiteTac. [OP] Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
  2. May 30, 2018 at 8:58 PM
    ThorsTRD
    ThorsTRD Pretty good at F'n shit up.
    Nick
    Fort Worth
    2021 TRDOR DCSB
    Let's just call it my 401K.
    Damn cool idea. Thanks for sharing.
  3. May 31, 2018 at 7:39 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Interesting but not much info about it.
    SR-71A likes this.
  4. Jul 2, 2018 at 6:21 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Low friction rings and soft shackles are common place on sail boats as is Dyneema line. Tremendous load forces in those applications especially on large racing class yachts. Typically stronger than their pulley type counterparts, and with a little practice and a set of fids you can make a soft shackle in minutes. Light weight, strong, packable and have multiple uses. Seems like a no brainer to me.
    The_Black_Pearl and gilligoon like this.
  5. Jul 5, 2018 at 4:26 PM
    GoogleybearR6
    GoogleybearR6 Well-Known Member
    Andrew
    Yucaipa, CA
    2010 TRD Sport 4x4 6spd
    Are you going to test one out for us OP?:rofl:
  6. Jul 6, 2018 at 9:20 AM
    NudeLobster
    NudeLobster Well-Known Member
    Justin
    Tucson, AZ
    2006 Lexus GX470
    I talked with 7P at overland expo about recovery quite a bit. They don't even touch automotive market snatch blocks. They said they haven't found a single one properly designed for synthetic line. They said some labeled "for synthetic line only" have a proper pulley material but the pulley grove is still too rounded (for steel line). Synthetic line grooves should be flatter since the syn line flattens under tension.
    If they use snatch blocks they use arborist blocks. they also use these rings which one of the guys thought up and designed recently. even the smallest one is rated to like 7k lbs and weighs like 1 pound. Allows multi use of your recovery kit components to slim down the load out versus having dedicated kit for each application.
    They are truly brilliant. Much ligher and easier to pack, and more versatile than snatch blocks. Considering you (should) already have soft shackles in your kit, this means adding 1-2 lb compact aluminum ring(s) instead of 5-10lb steel snatch block, or even the 3-5lb all aluminum arborist snatch blocks they use.
    gilligoon likes this.
  7. Aug 6, 2018 at 7:53 AM
    SOAZ
    SOAZ New Member
    4runner
    I sat down with Andy of 7P chat about these and we did a full line pull. It's not really a review, but more of a walk through since there is so little info on these still.
    We're spending a year driving to South America and decided to use 2 of these to replace our older Arborist style aluminum pulley blocks.
    (Full disclosure: I have no direct financial interest in these selling, but work for Overland Expo and 7P so there is bias)
    Cheers,
    Tim
    f86sabjf and gilligoon like this.
  8. Aug 6, 2018 at 8:03 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Are they available for sale yet?
  9. Aug 6, 2018 at 8:18 AM
    SOAZ
    SOAZ New Member
    4runner
    I know that every one including demos sold out at Expo, but I'd hope they have some more on the way. I'd shoot an email to 7P. (I'll do the same and repost if I hear back. We're heading back out camping after a night at a hotel so I may not have service for a few days)
  10. Aug 9, 2018 at 4:50 PM
    SOAZ
    SOAZ New Member
    4runner
    Sounds like it's mid-September. Ugh..
  11. Oct 27, 2018 at 4:28 PM
    GAHLizard
    GAHLizard Member
    Greg
    NW Montana
    2019 DCLBOR
    2" ADS lift, Off Grid Dual Battery Kit, Twin ARB Compressor, Snomaster Fridge, Truck Vault, 23 Zero Byron RTT, Sliders, Bumpers, Winch, 33s, 5.29 Nitro Gears
    Back in stock...
    Marbleyard likes this.
  12. Oct 27, 2018 at 4:57 PM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    Ordered :thumbsup:
    GAHLizard[QUOTED] likes this.
  13. Oct 27, 2018 at 7:42 PM
    Spoonman
    Jamie
    Alberta
    Wait who has them?
  14. Oct 27, 2018 at 10:49 PM
    GAHLizard
    GAHLizard Member
    Greg
    NW Montana
    2019 DCLBOR
    7P has them on their web page. UTV, Jeep and Large Truck sizes...
  15. Oct 27, 2018 at 10:51 PM
    Spoonman
    Jamie
    Alberta
    Bastek and NateMob like this.
  16. Oct 27, 2018 at 10:52 PM
    GAHLizard
    GAHLizard Member
    Greg
    NW Montana
    2019 DCLBOR
    Which European product is similar?
  17. Oct 28, 2018 at 9:25 AM
    Spoonman
    Jamie
    Alberta
    The snatch ring in that link^^^
    90 bucks usd, shipping is cheap
    GAHLizard likes this.
  18. Oct 28, 2018 at 12:05 PM
    Marbleyard
    Virginia
    2019 4Runner Pro
    Shipping wouldn’t calculate on their site, said you have to call for shipping rates. Still may do this too
  19. Oct 28, 2018 at 1:41 PM
    Spoonman
    Jamie
    Alberta
    Shipping quote worked for me last week, I think it was like $40. For 2 snatch rings, 3 soft shackles and 3 other small items. Seemed very reasonable.
  20. Oct 29, 2018 at 8:30 AM
    lanceputnam
    lanceputnam Well-Known Member
    I am super thrilled about this concept.... but: those prices are ridiculous. $185 each and $99 for a single soft shackle? wow.
