75W90 with LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by keepitrunning, Jun 4, 2021.
  1. Jun 4, 2021 at 2:09 PM
    keepitrunning
    keepitrunning [OP] Member
    2009 Silver Tacoma Access Cab TRD
    So it is alright to use the Valvoline 75W90 with LSD in the crankcase and front differential? I bought 5. I've already changed the rear differential.
  2. Jun 4, 2021 at 3:54 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I use Mobile 1 fully synthetic also 75/90
    For both
  3. Jun 4, 2021 at 3:57 PM
    keepitrunning
    With LSD?
  4. Jun 4, 2021 at 3:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You have LSD in the front?
    I’d probably avoid synthetic in the Mechanical LSD. As some guys get a chatter.
  5. Jun 4, 2021 at 4:02 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Yes. Have been for 4 years
  6. Jun 4, 2021 at 4:02 PM
    keepitrunning
    Ok. So just get some without the LSD. Thanks
  7. Jun 4, 2021 at 4:04 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Its actually hard to find gear oil WITHOUT the lsd additive, i use it in all 3 in my truck, 120k miles, shifts in and out of 4wd and 4low with zero hesitation.
    Needless to say, the LSD additive wont hurt a damn thing on any 2nd gen tcase or front diff let alone the rear diff.
    schao87, spitdog, Too Stroked and 2 others like this.
  8. Jun 4, 2021 at 4:12 PM
    TnShooter
    Deogee
    STOCK
    Like @nd4spdbh said, it shouldn’t hurt anything.
    And it’s going to be hard to find without it. Unless you run a different weight.
    I thought you were asking about synthetic fluid in a Mechanical LSD.
    Which, isn’t my recommendation. As some guys have gotten a chatter when using synthetic fluid in the mechanical LSD.
  9. Jun 4, 2021 at 6:06 PM
    Waasheem
    Waasheem
    2007 xrunner
    Just to be clear, you don’t plan to put gear oil in the crank case, correct?
    Motor oil goes in the crank case. Gear oil goes in the differentials and manual transmission.
    Ya never know what someone might do.
  10. Jun 4, 2021 at 6:29 PM
    keepitrunning
    I was asking about the front differential and transfer case. Sorry about that. I have an automatic transmission and used the Toyota transmission fluid.
  11. Jun 4, 2021 at 8:19 PM
    Waasheem
    Waasheem
    2007 xrunner
    :thumbsup:
  12. May 28, 2022 at 4:35 PM
    JHudd
    JHudd Member
    Jordan
    Virginia
    Red 07' TRD Double Cab Short Bed
    Current Mods: Front and rear Wet Okole Seat Covers (Charcoal and Black) UWS TBS-63A BLK Toolbox Maglite mod Flowmaster muffler Dual exhausts Wheelskins cover Future Mods: WeatherTech DigitalFit BDS 6'' Coil-Over lift 35x12.50x18 Tires CB & Antenna BEEFED Sliders Snorkel Satoshi Grill Devil Horns
    I have the same question. Is it safe to use Valvoline conventional 75W90 on the front diff, rear diff, and transfer case? I have a 2007 with the mechanical LSD.
    Thanks.
  13. May 28, 2022 at 5:06 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    If you have the mechanical LSD then just make sure the oil has the LSD additive in it. Should be fine for the front diff and tcase too.
    JHudd[QUOTED] and TnShooter like this.
  14. Mar 11, 2023 at 9:35 AM
    JHudd
    JHudd Member
    Jordan
    Virginia
    I ended up taking mine to the dealer for this service. The mechanic said I do not have the mechanical LSD and that he used the same Mobil 1 75W90 for the transfer case and both differentials. That was 9 months ago and I haven't had any issues with the fully synthetic Mobil 1 75W90.
