75w-90 on Diffs and Transfer Case
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Expedition Sandy, Jun 21, 2021.
  1. Jun 21, 2021 at 5:17 PM
    Expedition Sandy
    Expedition Sandy [OP] Member
    Jack
    2007 Black Tacoma
    Bilstein 5100's, Front Runner RoofRack
  2. Jun 21, 2021 at 5:39 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    never hurts to stick to factory oem manual requirements
    not everyone has the same load on their driving............whereas i might use a product
    have NO issues .......i drive hiway a lot !!!
    my vehicle does not have a lot of cycles on ALL components = less wear& tear
    so my answer might NOT apply
    check out RED LINE !!!!!! they have More Driveline Lubes than anyone
    hiPSI likes this.
  3. Jun 21, 2021 at 6:06 PM
    Expedition Sandy
    Jack
    2007 Black Tacoma
    Ok cause all I've found was that the recommended 75w-85 is just better for fuel economy...
  4. Jun 21, 2021 at 6:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I have enough experience to stick with OEM specs. You do you.
    drizzoh, Skydvrr and RustyGreen like this.
  5. Jun 21, 2021 at 6:08 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    The difference between 75w-85 and 75w-90 is so insignificant as to be functionally zero. Run what you want. The Mobil will work great
    IronratPR and Pro-Taco like this.
  6. Jun 21, 2021 at 6:08 PM
    Expedition Sandy
    Jack
    2007 Black Tacoma
    what experiences do you have if you don't mind me asking. Thats why I put the question up on this forum.
    hiPSI likes this.
  7. Jun 21, 2021 at 6:27 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
  8. Jun 21, 2021 at 7:41 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    And better fuel economy is bad how? :confused:
  9. Jun 21, 2021 at 7:45 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    After trying all the usual brands, I stick with adrenochrome. Way better mpg.
    mushroom_man7 and hiPSI like this.
  10. Jun 21, 2021 at 8:26 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I know the guys who specified the lube know their shit better than me. Again, you do what you want but I trust the engineers who designed it.
    RustyGreen likes this.
  11. Jun 21, 2021 at 8:31 PM
    OpeCity
    Long Beach, CA
    That’s an appeal to authority, not an experience that informs your opinion.
    Engineers often make decisions based on priorities different than the end user. MPG standards might change a lube standard at the expense of severe-duty wear protection, for instance. If you weigh variables differently than corporate does, following the engineer’s recommendation might not yield an optimum result.
    75-85 and 75-90 are functionally identical and using one or the other won’t harm anything
  12. Jun 21, 2021 at 9:43 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Prove it. They can. You can't.
  13. Jun 22, 2021 at 12:54 AM
    Hatfieco05
    Hatfieco05 Well-Known Member
    Portland, OR
    2020 DCLB TRD Off-Road Premium
    As much time as I spend working closely with engineers, they are given a set of parameters. When what they have in front of them meets said parameters their job is over and it doesn’t matter if it’s not practical. All they can prove is it met that set of parameters. I bet most of them nowdays are meet epa mpg standards, make it past warranty. Hence why they still have that garbage roller bearing in the diff instead of a bushing.
  14. Jun 22, 2021 at 1:51 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes. Just changed to 85-140 in my front diff (ECGS needle bearing mod). Don't over think it.
    Hatfieco05 likes this.
  15. Jun 22, 2021 at 2:22 AM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    I run Redline 75W-90 in both diffs with no problems, and will run 75W Ravenol in transfer case when I change it. The sooner you change your diff oil the better. Both of my diffs were under filled by as much as 30% from the factory. I also do not have noisy rear diff probably because I filled/replaced mine early on.
  16. Jun 22, 2021 at 3:39 AM
    18TRDOR
    18TRDOR Well-Known Member
    Kyle
    New Philadelphia, OH
    2018 TRD OR DCSB 6MT
    Been running 75w/90 Redline in my front and rear diffs for 20k miles without any issue. It definitely helped my rear diff quiet down a little bit. When I change them again here at 60k I am going to move to the 75/110 to see if it helps quiet it down some more unless I regear then I'll run the dino oil instead of synthetic per ECGS.
  17. Jun 22, 2021 at 4:14 AM
    OpeCity
    Long Beach, CA
    You can’t prove that the engineers’ recommendation is better than 75w90 for the goals of the OP. You say “they can,” but you don’t even know the design compromises made.
    Look, I’m all for going OEM. But there are lots of times where the OEM recommendation is at odds with the goals you’re trying to achieve. We don’t all run only stock size wrangler Kevlar garbage tires…because they don’t meet our needs/wants. We don’t all run stock suspension bushings, shocks, diff bearings, cab mounts, alternators, batteries, bumpers, brake pads, and a thousand other things…because they don’t meet our needs/wants.
    All of that aside, there’s literally zero functional difference between 75w-85 and 75w-90. As long as it meets the GL spec, which it does, it’s not going to harm a thing. Engineering is a lot less precise than that.
  18. Jun 22, 2021 at 10:31 AM
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Same goes for engine oil. They make us run 0w-20 for fuel economy when 0w-30 is a better oil for trucks, especially working trucks, IMO.
  19. Jun 22, 2021 at 1:02 PM
    ROAD DOG
    FEW
    some think themselves ' clever ' splitting hairs over minutiae
    rear diffs when thousands o miles b4 ' synths '
    unless severe conditions exist in Ur normal daily environs
    thinkin extreme conditions on other continents + the ever present ' just n case ' IS rather Futile !!!
  20. Jun 22, 2021 at 1:04 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I presume this is based on lab analysis of a large sample size? Because otherwise I’d like to know how this statement could be made...
