75w-140 accidental fill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tac2021, Jun 27, 2023.
  1. Jun 27, 2023 at 3:50 PM
    Tac2021
    Tac2021 [OP] Well-Known Member
    Phil
    2021 SR5 Drk Grey Met Dbl cab 4 x 4
    none yet
    Ok here’s what happened. Picked up two squeeze bags of Valvoline 75w-90, or so I thought for a first time front differential change, after I did my oil & filter. First bag was the 75w-90, second bag after adding it I found out was a 75w-140.
    Is this bad? Should I drain and fill again now or wait till this fall. There is 26,000 on the Tacoma, a 2021 SR5. So 2/3 of the fill is 75w-90, the other being the 140.
    Both bags look exactly the same except for the label.
    What say you Tacoma world?
  2. Jun 27, 2023 at 3:52 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Do it right brother.
  3. Jun 27, 2023 at 3:52 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’ve been running 75/140 for 12 years, now. I think you’re fine and…D01457FB-6368-4222-A7FC-F9D5823BB588.jpg
    MR E30 and tinker_troy like this.
  4. Jun 27, 2023 at 3:55 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Don't worry about it. it's fine. Your differential will never know the difference.
  5. Jun 27, 2023 at 3:59 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  6. Jun 27, 2023 at 3:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The only reason I’d change it, is because it’s still under warranty.
    Should you need to make a warranty claim on the front differential, they have a reason to fight you.
    BTW. Although rare, the thicker fluid can travel up and out the front differential vent.
    If you weren’t still under warranty, I would run it.
    I’m running 85w-140 in my front.
  7. Jun 27, 2023 at 4:03 PM
    Bishop84
    Bishop84 Well-Known Member
    I'd leave it, the 75w is the important bit and its the same for both.
    My problem lies with thick winter ratings.
    D.A.S. Taco, RustyGreen and Junkhead like this.
  8. Jun 27, 2023 at 4:24 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Since this is not my truck, I say leave it. But, if it were mine I’d change it, but I would have no qualms getting SuperTech syn fluid for the front. Consider the experience an expensive diff fluid flush.
  9. Jun 27, 2023 at 4:38 PM
    Tac2021
    Phil
    none yet
    I think I’ll run it for the next few days and change it. I replaced the plugs with Lexus versions. Also used a T55 torx bit, the 10 mm was wobbly, the torx really gripped the inside edges well. Could have re used them, but were in real tight.
  10. Jun 27, 2023 at 4:55 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    :confused:
    10MM Allen fits just fine in there. T55 might strip the Allen head.
    Superdave1.0 and shakerhood like this.
  11. Jun 27, 2023 at 8:54 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    …right…
    So, drain and refill is what I would do.
    Speedbird likes this.
  12. Jun 27, 2023 at 8:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Same brand so the additives won't work against each other. 75W means viscosity when cold will be the same. Viscosity at operating temps (when in 4WD) will be somewhere between 90-weight and 140-weight oil. No real drawbacks to 75W140. In fact that's what I use in the front diff of my 4Runner.
    Why were you changing front diff oil anyway? Truck is 2 years old with only 26k. You aren't due by mileage or calendar time.
  13. Jun 27, 2023 at 9:56 PM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    I highly, highly doubt this will cause any issues. Plenty of people run 75w-140. I would not worry about it at all.
    zoo truck likes this.
  14. Jun 27, 2023 at 10:15 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    You’re essentially running 75w115 now. No big deal
    3JOH22A and Ricardo13x like this.
  15. Jun 27, 2023 at 10:57 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    ^^^^ this ^^^^
  16. Jun 28, 2023 at 4:47 AM
    zoo truck
    None
    If it were a transfer case mistake, I'd change the fluid out, but being the front diff which doesn't get used as often, this won't make any difference to the trucks operation. Its only to you.
    Rusty66 likes this.
  17. Jun 28, 2023 at 5:28 AM
    Tac2021
    Phil
    none yet
    The initial panic is over, thanks to everyone for the feedback. I will pass on changing it for now, before the winter I’ll consider doing a drain and fill.
    The reason for the change at that mileage I was doing and oil change, on the ramps it was easier to break loose those plugs. I filled it on level ground. Condition of the fluid was a gray silver color, the magnet had that metallic paste. Normal for a first change.
  18. Jun 28, 2023 at 5:51 AM
    Halloween
    Halloween Well-Known Member
    Toyotas a plenty
    It’s fine Just leave it. Won’t hurt anything.
  19. Jun 28, 2023 at 6:17 AM
    Buck Henry
    I concur that it won't do anything bad to the gearbox to run your blended oil stew. But I came out of the nuclear power world where everything (and I mean everything!) Is done to spec.
    So this would haunt me in my dreams so I personally would have corrected the fuck up right then and there. :)
    airforceb2cc likes this.
  20. Jun 28, 2023 at 6:31 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    It will not make a lick of difference. They'll just mix and average out.
    That said, the folks who say that beause it's 75W, they will both be the same when cold....that is not correct.
    Valvoline full synthetic pouch viscosity details:
    75W-90
    40 Celsius - 92.5 cSt
    100 Celsius - 15.6 cSt
    75W-140
    40 Celsius - 184 cSt
    100 Celsius - 27 cSt
    And just for extra information:
    Valvoline 85W-140
    40 Celsius - 370 cSt
    100 Celsius - 28 cSt
    The winter rating is highly misunderstood. The above fluids are both 75W yet one is twice as thick as the other. It is not correct that just because the rating is 75W, that the gear oil will be "like a 75 weight" in the cold. It is pretty much impossible to come up with a fluid that is a 140 weight when warm but flows exactly the same when cold as a 90 weight. All the first number really can tell you is that it will flow a bit quicker comparatively to the same viscosity oil with a higher winter rating. For example, 75W-140 will always flow a bit better than 85W-140. The number does not mean that 75W-90 will flow the same as 75W-140 just because they both start with 75.
    You can see above that the 75W-140 and 85W-140 are very different when cold, but right at the same thickness warm, as explained above.
    None of it will make any difference in the diff, no need to drain and refill again, I just wanted to correct that.
