70k Miles - Dealer Tune Up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KiloFoxtrot_, Jul 20, 2020.
  1. Jul 20, 2020 at 6:41 AM
    KiloFoxtrot_
    KiloFoxtrot_ [OP] Active Member
    Maine
    2018 Cement TRDOR
    Hey guys
    I just hit the 70,000 miles mark (70,857 to be exact) on my 2018 DCSB TRDOR.
    I’m looking to go in for a routine service (oil change, tire rotation, fluid checks) and I am seeing a recommended “Engine Tune Up” service for $350. The description hardly says anything noteworthy about what they actually do:
    I’d like to get my plugs changed and anything else that I should do at this mileage milestone.
    Questions:
    Has anyone gone through with a similar Tune Up through their dealer?
    Do you happen to know what was included?
    Is there anything I should make them aware of or ask about that would be wise to get inspected or replaced?
    I know a lot of you guys are self-maintenance types, which I totally envy, however, I am not.
    They also recommend a “4x4 Service” for $190 which I’m thinking about going with too, although I have rarely, as in like twice, even used 4HI and never 4LO.. more of a piece of mind thing I suppose.
    I suppose one final question I would have is if I should go with the 75K routine maintenance as well for another $100. The difference in the 70k and 75k seems pretty substantial for the same price. The 75k includes far more inspections, level checks, and torque checks.
    Appreciate any and all replies. Thanks all!
  2. Jul 20, 2020 at 6:45 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I would stick with the recommendation chart in the owner's manual, a lot of the dealer packages are fluff. Also in the manual, is recommended engaging 4wd more often ;)
  3. Jul 20, 2020 at 6:59 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    If you are handy you can do all that stuff yourself...
    kgilly, shakerhood and whatstcp like this.
  4. Jul 20, 2020 at 7:10 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2
    Pay them for what's recommended in the manual, and say a little prayer they actually do it..
    t0nyvalenzuela and whatstcp like this.
  5. Jul 20, 2020 at 7:20 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Be prepared for big money. I believe they're charging over 1k for a plug Job.
  6. Jul 20, 2020 at 7:22 AM
    jmneill
    SE
    Aptly named...
  7. Jul 20, 2020 at 7:24 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Well dang, I'll start saving now.
  8. Jul 20, 2020 at 7:27 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It's really not hard to do yourself though. Passengers side takes like 30mins. Driver's side can take quite a bit longer though. Dealers think the intake plenum needs to be pulled for driver's side, hence the cost.
    shakerhood likes this.
  9. Jul 20, 2020 at 7:29 AM
    AmericanDrug
    AmericanDrug Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    Uh diy?.. 1k for spark plugs is retarded. Less than $100 in plugs and ten minutes of work. Haven't looked at location, only at 19k miles, can't imagine it's difficult.
  10. Jul 20, 2020 at 7:30 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Gotcha, I've only got 15k on mine, but I'll look in to it, my buddies are techs, I'll start saving for OEM plugs and beer:D
    Skydvrr[QUOTED] and AmericanDrug like this.
  11. Jul 20, 2020 at 7:30 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Wow you drive a lot.
  12. Jul 20, 2020 at 8:09 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It's not 10mins. It's closer to 3 hours if you're not mechanically inclined. I was into it two hours or so and I'm fairly on the ball with that stuff.
  13. Jul 20, 2020 at 8:11 AM
    AmericanDrug
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    3hrs? Now I'm curious and wanna see what's in the way.
  14. Jul 20, 2020 at 8:12 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    The whole intake plenum. It's not hard necessarily, just time consuming. It's tight in there. Couple of brackets need to be moved, undoing clips etc.
  15. Jul 20, 2020 at 2:19 PM
    KiloFoxtrot_
    Maine
    2018 Cement TRDOR
    Went in to the dealership earlier to just to talk and clarify what exactly the engine tune up involved. Was basically told “all it means is a plug replacement”
    Set up my appointment for next week. Might add the 75k “check up” as well, just for piece of mind.
    Estimate came out to $347.17 for the tune up. Also have a 10% service coupon, so, not too bad.
    Thanks for the replies guys. Will update if anything dealership f*ckiness occurs. :playball:
    Chew and chstaco like this.
