7' x 18' utility trailer build.
Discussion in 'Garage / Workshop' started by koditten, Jan 16, 2014.
  1. Jan 16, 2014 at 1:38 PM
    koditten
    koditten [OP] Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I build trailers for a hobby. this is one that I build last winter. I took a bunch of random pics of how I do build them.
    Ask any questions you want.
    We are going to start with a bunch of raw steel and end up with what you see.
    Stay tuned if you are interested in building your own trailer.
    KO
  2. Jan 16, 2014 at 1:42 PM
    koditten
    Kirk
    Central Michigan
    This one will have 2 fold down ramps. One in the back and one on the side. The customer needs to haul 2 full sized quads and a personal recreational vehicle.
    Here are some pics to get started. I won't be doing this in one sit down, so bear with me on getting all the pics posted.
    I start out by laying the recangular shape of the frame on the floor.
    I measure diagonally to make sure it is square.
    KO
  3. Jan 16, 2014 at 1:44 PM
    koditten
    Kirk
    Central Michigan
    Because I'm a one man show, I needed a way to hold the tape measure. When you span 20 or so feet the tape foot wants to slip off the steel. Makes it a pain trying to measure your diagonals.
    I solved that issue by tack welding a couple of nails to the corners. The Tape measure foot grabs the nail nicely making it easy to get the trailer squared. As I said in my previous build, you only need to be within an 1/4".
  4. Jan 16, 2014 at 1:45 PM
    koditten
    Kirk
    Central Michigan
    Here is a pic of all 10 cross members. I spaced them at 24" on center (roughly). Because this trailer is a utility trailer, only 5/4" lumber will be used for the deck. You can see the 5/4" spacers below the cross members.
    I should have mentioned that the trailer is upside down at this point.
    I like to alternate welding between ends and sides to prevent the trailer from pulling out of square. If you start on one side and work your way down, you will likely end up with a frame that is slightly diamond shaped.
  5. Jan 16, 2014 at 1:47 PM
    koditten
    Kirk
    Central Michigan
    Here Ihave hoisted the frame onto my welding table. Because the table is only 4 x 5", I like to tack weld some "legs" to the frame ends that overhang the farthest from the trailer. Even tho the fram is made out of 2 x 4 1/8" wall tube, it will still flex quite a bit. This is the time when I finish welding the cross members. Because the trailer is upside down, I can only weld 3/4 of the cross members. If you don't have the legs,you run the risk of the trailer staying in the flexed possition. My theory is the welding "stress relieves" the steel, and that is the way it stays.
    I have only 1" weldson the cross members while it was on the floor. I just don't care to be bent over or kneeling doing all that welding when it is a lot easier while on the bench.
    If anyone noticed, I used 2" x 2" angle as well as tube. I've found that the combination makes the trailer stiff while keeping it a bit lighter. This trailer would have been fine if it was 16' or less to just use angle.
  6. Jan 16, 2014 at 1:49 PM
    koditten
    Kirk
    Central Michigan
    Here is the welding of the ball coupler. Because this is a light duty, tandem axle, I was fine to use base model 50* ball coupler. If one was to plan on hauling cars or tractors it would benifit to move to a heavier duty coupler.
  7. Jan 16, 2014 at 1:50 PM
    koditten
    Kirk
    Central Michigan
    For some reason, I never took pics of positioning the tongue. To make it easy on me I make the tongue just long enough that it does not fall to the floor. I just slowly pull it forward until I am just before the point of balance. You end up with enough tongue that enables a costomer to attach a truck box to the front, which work great for storing the random stuff you need to safely tow.
    Anyways, because I never know what width the customer wants, I just order 9' pieces and cut off the rest of the tails. Simple trig will tell how long you need to make the tongue angles to match the width of your trailer. Once you have that number it is just a matter of making all measurements equal. I wish I would have taken a pic of this. Having a hard time describing it. Measure from the far corners (were the nails hopefully still are) to tongue tip and check to see if you are close. Once again 1/4" is perfectly fine number.
    To note, I use my port -o-band to cut off the tongue angle tails after the tongue is welded to the frame. Attaching the tongue is very important. Make sure you trust your welds completely.
    __________________
    "You guys kill me, you can find more reasons not do do something than to actually do it. How do you get anything done without taking a few risks?"
  8. Jan 16, 2014 at 1:53 PM
    koditten
    Kirk
    Central Michigan
    Here I am shortening the axles. Because I never know what width trailer a customer wants, I usually have to shorten or lengthen the axle. I just several of one size andmake them the width I need.
    I back of the trailer as a temporary bench. We already know the trailer is square so I use the frame as guide to ensure the axle is welded together strait. I just eyeball down the cross member and back frame membere to to make sure the axle is strait.
    In one of the pics you can see a slight bow to the axle. I like a bit of camber to my axles. This helps the trailer pull strait when going down the road. This measure is not really crutial. Anywhere from 1/2" to <2" is fine.
    I cut the axle in half and slide the sleeve over the joint. You can see my piece of scrap metal holding up the axle in the position I wanted. Once you have it peervectly strait and have your camber where you want it, just tack weld multiple points on both sides of the sleeve. After 4 or 5 tacks on both sides you can finish welding the sleeve. I usually only end up welding 2/3 of both sides of the sleeve. I do the bottom after I turn the trailer over, which now becomes the top.
    This is a tandem trailer, so I had to do 2 axles. One of the axles is a breaked axle, so be carefull and support the hub end after you cut it in half. The hub end is heavier than the axle tube so the hub may want to swing down. This happens with shorter axles. I didn't have that problem on this axle, but it is worth mentioning. Dropping half an axle from 35" makes a scary and sometimes expensive noise. I usualy cut my axles in half on the floor with the band saw to keep the axle from falling off the trailer frame. Once on the frame and the sleeve pushed on they are pretty safe.
  9. Jan 16, 2014 at 1:55 PM
    koditten
    Kirk
    Central Michigan
    Time to position the axles.
    The front spring hanger on this trailer is 90" from the front. You can weld this front hanger in position now. The other 4 hangers will follow the front hanger position. Regardless what you have heard, there is not a calculation for positioning axles on a frame. This trailer will have a heavy front gate off one side, so I had to take that into account. In general, I like to have the front axle about 1/2 to1' back from center. This way I can put tires on the front axle only and move it around the shop with ease. The trailer is only slightly tongue heavy at this time.
    If you notice the spring bolts, you can see they are shoulder bolts. This is to prevent the bolts from being over tightened. I don't like using these, but they do serve a purpose. Years ago I over tightened a bolt on the shackle end. The bolts were so tight, the spring could not flex. It actually ripped the hanger off the bottom of the trailer frame. I was left with a 2" x 4" hole in the frame that had to be repaired.
    These equalizers are a pain at times to get assembled. The extra weight of the braked axle makes the equalizer pivot. I solve this by replacing the shoulder bolt with one of my standard trailer bolt. I can now tighten up the pivot point so the equalizer can not move. Finish assembling your bolts and links. Adjust the rear axle and equalizer hanger so the links are hanging straght down. Do this on both sides and measure the position of both side hangers. as long as you are withing a 1/4" you are good to go. Weld all the hangers in place. I don't weld all 4 sides of the hangers, just the front and back. I have found if you have 4" of welds on both sides, you can warp the frame upwards. The welds cool and shrinks the metal, especially if you have 3 hangers.
    Tighten up the rest of the bolts and don't forget to loosen the pivolt bolt on the equalizer. 1-2 turns on the nut is fine.
    You will notice on one of the pics that there is a gap between bolt head and hanger. Because of these shoulder bolts, this is as tight as you can get them. To me it looks like I forgot to tighten the bolts.
  10. Jan 16, 2014 at 1:56 PM
    koditten
    Kirk
    Central Michigan
    Not much to show here. I used my chain falls to lift the trailer off the table. I just lift the back end, roll out the table and lower the upside down frame the the ground.
    Now I attach the chain falls to one side of the trailer and start to raise one side of the frame up. Once it is verticle, I push the top over and lower. The trailer is now upside right. You might have to "walk" the frame to one side of your bay or the other so you have room to lower. I have no trouble doing this by byself. The trailer weight is resting on the hub faces so its easy to handle as long as you hoisted it from somewhere near the center.
    Once on the ground I jack up the axle and attach wheels to the front axle. Now I can position it to start welding. I usually attach the tongue jack at this time. This way I can level the trailer.
    I weld all the cross members and frame pieces that were previously on the bottom at this time. I like to weld my tie downs on as well. You can see what I use for tie downs in my other build. There are many things that carry over from the other build thread that will be used on this build, so please view that thread for details.
    One note that I should mention. I said this trailer has a combination of 2 x 2 angle and tube for cross mebers. On the tube cross members ilike to leave 1/4" on the bottom unwelded. This gives any condensation that builds up a place to drain. I have had trailers in the past build up so much water in the tubes that they will freeze and round out the tube. Don't ask me how the water gets in there, but it does.
    KO
  11. Jan 16, 2014 at 1:58 PM
    koditten
    Kirk
    Central Michigan
    I wasn't happy about about the gap I had here. My uprights must have not been quite plumb. I solve this by using my 8' bar clamp. I clamp on the opposite side and pulled the gap closed. Just be careful, the uprights are only solidly tacked in place and it is easy to make the whole thing come a part like a house of cards.
  12. Jan 16, 2014 at 1:58 PM
    koditten
    Kirk
    Central Michigan
    Got the top rail tacked in place. I can now finish weld the top rail and the corner uprights.
    The second pic was taken to try and show you the sag in the 18' top rail. I'll show how I addressed that in future posts.
    You can see that the shop was getting kind of smokey from all the welding I was doing. I took a break and had a beer with the doors open. Since I usually build the trailers in one session, I treat myself after 3 or 4 hours. If anyone is bored, they can check the time and date stamps and get an idea how long this takes me. It actually took me longer because of stopping to snap some pics.
    KO
    Attached Thumbnails[​IMG] [​IMG]
  13. Jan 16, 2014 at 1:59 PM
    koditten
    Kirk
    Central Michigan
    Cheap ass gloves. You would think I could get more than 6-7 trailers out of a pair of gloves. Dammit! They were just getting perfectly broke in.
    KO
  14. Jan 16, 2014 at 1:59 PM
    koditten
    Kirk
    Central Michigan
    I'm getting ready to build and mount the fenders. Because I just eyeball the position of the fenders, I need both tires mounted.
    The clamp in the picture keeps the axle from pivoting down. It keeps the tires on that axle from contacting the floor. I can still move the trailer around the shop on one axle this way. Its a little heavier, but I can still do it by hand.
    KO
  15. Jan 16, 2014 at 2:00 PM
    koditten
    Kirk
    Central Michigan
    Time to build my fenders. I use 14 gauge sheet steel bent into 10" wide channel. The lip is 1". My fenders may not look as good as store bought fenders, but they are a whole lot stronger. I can stand on my fenders after they are properly mounted with no fear of bending them. My way is alot cheaper as well. I pay around 50 bucks for the pair. 1 store bought fender can be 70+.
    Anyways, I notch the fenders at 10" and 8". This gives me the length I need to cover the tire properly. Do the same for the other end. I have my angle gauge set to find this angle preset. I am only trying to get close on the angle. The only thing I care about the verticle section is perfectly plumb. You can see the bends in the notches. This allows me to bend the channel a bit easier. I put the channel on the floor and bend it by hand. I have clamped to the steel table, but I was in a bit of a hurry.
    KO
  16. Jan 16, 2014 at 2:00 PM
    koditten
    Kirk
    Central Michigan
    KO
    Attached Thumbnails[​IMG] [​IMG] [​IMG]
  17. Jan 16, 2014 at 2:01 PM
    koditten
    Kirk
    Central Michigan
    As I said, I just eyeball the position of the fenders over the tires. I need to make the gap between the front of the front tire to be equal to the gap between the rear of the rear tire. A person could measure if they want, but the naked eye works just fine.
    I have a jacks on both ends of the fenders. I just raise or lower the jacks to make the front and rear of the fenders match. 4" of height between the bottom of the fender and the top of the tire is plenty. If one wants it higher that is fine too. I usually stick my fist under the fender and that is the height I make the fenders.
    Please remember that i still have the rear axle clamped up. I the front axle and tire to take all my measurements from.
    Once you get the fender were you want it, make sure it not tipped. You can now weld it to the frame.
    KO
  18. Jan 16, 2014 at 2:01 PM
    koditten
    Kirk
    Central Michigan
    I've marked were my upright will live. I use my plasma cutter to notch out the fender. A cut off wheel on the grinder actually better because the cuts will be good and strait.
    In the second pic you can see were the upright is positioned on a floor jack. I mentioned earlier that the the top rail has a sag. Using the jack I can go to the end of the trailer and look down the full length. I just jack the upright up until the sag is gone. Weld the uprights in place. weld the fender to the upright and you now have fenders that will support a pretty heafty person. They have no trouble supporting my 215 lbs.
    I usually weld my fender notches as this time as well.
    KO
  19. Jan 16, 2014 at 2:02 PM
    koditten
    Kirk
    Central Michigan
    You can just see the sag in the top rail in this pic. The jack took care of this.
    KO
  20. Jan 16, 2014 at 2:03 PM
    koditten
    Kirk
    Central Michigan
    My battery finally gave out on the camera. I was forced to use the cell phone. Pretty crappy, but you can get the idea on what the finnished product will look like.
    I wont be posting any more pics until this weekend. The pics are the way the trailer presently sits. Hopefully I can get to building the ramp gates and other details on Thursday and Friday.
    Lets see, to do list:
    Finnish welding in tiedowns.
    Make foot rest, front and back of fenders.
    Build gates
    Wire trailer
    Wash trailer
    paint trailer
    Deck trailer.
    Brace for tongue jack.
    I'm sure I for got somethings.
    Questions are welcome.
    Later
    KO
