650# vs 600# coils on 6112s
Discussion in 'Suspension' started by EricT, Jun 7, 2021.
  1. Jun 23, 2021 at 9:06 PM
    parel
    parel Well-Known Member
    Kin
    Calgary, AB
    (ex. 2014 Black Tacoma TRD)
    OEM FJ TRIBUTE EDITION (REPLICA)
    So you decided to go with the 6112s I see. On the lower perches the ride is amazing btw. With minimal preload the digressive shocks really shine.
  2. Jun 23, 2021 at 9:42 PM
    EricT
    EricT [OP] Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Yeah I was always going to do the 6112s, just wasnt sure if I should go for a bigger spring and lower on the shock setting. But for now the ride is a ton better than my 5100s and eibach performance coils. That were crooked... probably wasnt helping anything.
  3. Jun 24, 2021 at 10:05 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I've considered jumping to the 700lb springs myself. I prefer the no front sway bar as there is less jarring when hitting large bumps and freer travel off road. I had 3rd gen TRD OR suspension on my truck before the 6112's. 3rd gens use 700lb springs from the factory are rode great! Now with the 600lb spring that comes with the 6112's it just feels way under sprung.
  4. Jun 24, 2021 at 10:11 AM
    EricT
    Arizona
    I don't have any extra weight (steel bumper, fancy skid plates etc) up front. Yet. I would prefer having a longer spring and lower shock setting, that seems to be the magic formula. But for now the 6112 with 600# spring seems to be going great, feels much better. My old coils appear to have been bent, probably my shitty spring compressor tool install fuckup on my part. I thought when I ordered from headstrong I was talking to the original much more knowledgable crew when I was asking questions, kind of bummed that I wasn't. But I will ride with it as is and see how I like it, got a good road trip coming up so that should be a good test.
    And my anti sway bar is sitting in the bushes next to my garage, right on top of the toyota stock leaf springs. Road test time!
    TacoFergie likes this.
  5. Jun 25, 2021 at 10:06 AM
    parel
    Kin
    Calgary, AB
    No-spring-compressor-method FTW. Much simpler and safer IMO, if you’re on the ground.
  6. Jun 25, 2021 at 10:17 AM
    EricT
    Arizona
    I was about to ask what that was, thought about it for a minute and I think I get it. Place shock in coil, bolts to lca and just Jack up the lca until it’s in range to thread the top bolt and bushings? I am guessing.
    parel likes this.
  7. Jun 25, 2021 at 10:23 AM
    parel
    Kin
    Calgary, AB
    You got it. Even at 75% preload the top bolt was super easy to thread on, once the LCA was jacked up. In the course of a few hours you could easily try a couple c-clip positions.
    the only tip is you have to loosen the cam bolts a bit so your LCA swings freely. And mark your alignment positions so you’ll know if you bumped your alignment or not.
    Silentshredr likes this.
  8. Jun 25, 2021 at 11:05 AM
    EricT
    Arizona
    I'm just bummed as my original plan was to resell the eibach coils, since they're crooked now I'm not sure anyone would want them.
  9. Aug 7, 2021 at 9:53 AM
    TacoFergie
    Iowa
    TRD Pro shocks for 3rd gens is Fox and TRD Off Road are Bilstein that are no where near similar to 6112's, they are a 4600 series Bilstein, see picture below. 2nd gen had Pro or Baja Bilstein shocks options. Pro's were Progressive valving 600# springs (gets stiffer as piston speed increases) and Baja's were Digressive valving and 650# springs (gets softer as piston speed increases) which are similar to how 6112's are valved. But not the same. I haven't found any hard numbers but I know the valving is different between the Baja 6112's and standard 6112's.
    I'm curious how this goes. This thread goes over the 700# options and people who have ran them. https://www.tacomaworld.com/threads/bilstein-6112s-with-700lb-springs.596857/
    Even though I don't have any additional armor (will be getting sliders built soon) I still have Taco lean with 600# springs and clip settings at 5/4 which is why I am considering 700# springs.
    On my 15 DCLB I can tell it's under sprung with 600# coils. I have my sway bar removed and no additional armor, though I do have an AGM battery which is heavier than the stock one. I notice quite a bit of dive in turns and still have the old taco lean with 5/4 settings. When I had my 3rd gen TRD Off Road shocks/springs it rode great and didn't have as much dive like the 6112's. The 3rd Gen TRD OR springs are 700#. As mentioned above, the 2nd gen Baja springs were 650# springs. Toyota must have done that for a reason to possibly avoid more dive since the Baja 6112's were digressive valving, like the after market 6112's.
    I am considering the 8112 700#(pn 53291394) springs on my setup since it won't likely be too stiff. Remember, the springs job is only to support and the shocks job is only to dampen. Knowing that I expect a stiffer ride, but it shouldn't be harsh and it should dive quite a bit less. Considering high end coilovers for my MR2 (2450lbs) have very good damping (not megan or tein), they still ride nice and preform well on auto-x/track with around 400lb front and 550lb rear springs. Comparatively a 700# spring isn't much on a truck that is more than twice the weight and has the engine in the front means it isn't that crazy for a 700# spring to be used.
  10. Aug 7, 2021 at 11:44 AM
    lefty9206
    lefty9206 Well-Known Member
    Jarrod
    2021 gray TRD off road
    None yet
    It’s going great they feel really nice and will support the bumper and winch when the bumper arrives.
    TacoFergie[QUOTED] likes this.
  11. Aug 9, 2021 at 7:31 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Guess I’m going backwards. I have 650lbs coils on now and going to install 600lbs. I’m all stock, so weight isn’t a issue. The truck is ok off road, but want it a little smoother.
    Just curious if I’ll notice a difference between the 600 and 650
  12. Aug 9, 2021 at 7:41 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    600lb springs are nice :thumbsup:
    pahaf[QUOTED] likes this.
  13. Nov 19, 2021 at 12:07 AM
    VHiN
    VHiN Member
    Melvin
    2015 white trd sports Tacoma
    Would you post an update after install and review. I’m on the same boat right now. And maybe link on coil. I have full steel bumper with winch. Thanks
  14. Nov 19, 2021 at 12:15 AM
    VHiN
    VHiN Member
    Melvin
    Which coil did you go with? I have full steel bumper with winch. Planning on getting that set up
  15. Nov 19, 2021 at 6:18 AM
    #35
    71tattooguy
    Dino
    Petaluma , Ca (707)
    600lb springs you will notice a difference. They will definitely soften up in time IMO
  16. Nov 19, 2021 at 10:43 AM
    #36
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    700# and I'm very happy so far.
    Been offroad a few times.
    71tattooguy likes this.
  17. Nov 19, 2021 at 10:46 AM
    #37
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I'll check this afternoon and post up.
    I'm curious too.
    I've flexed it up on a couple trips while carrying a full camping load.
  18. Nov 19, 2021 at 11:55 AM
    #38
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :thumbsup:
  19. Nov 19, 2021 at 12:16 PM
    #39
    VHiN
    VHiN Member
    Melvin
    Right on! Which brand did you go with, got a link? And did have to upgrade UCA aswell?
  20. Nov 19, 2021 at 12:29 PM
    #40
    pahaf
    paul
    NorCal
    i did notice a diffrence. truck is much smoother now. i love it.
