600lb or 800lb WD Hitch?
Discussion in 'Towing' started by TacoPronto, Jun 11, 2012.
  1. Jun 11, 2012 at 7:11 PM
    TacoPronto
    TacoPronto [OP] Member
    Upstate NY
    2012 TRD Off Road
    I just picked up a decent used hybrid TT and am looking for a low cost weight distributing hitch. The two that I'm looking at are the 600lb and 800lb Camco units. My TT is 3900lbs dry with a tongue weight of 440lbs.
    Would either of the two hitches I'm looking at be preferable over the other? The trailer obviously fits under both of their limits, but I'm curious to know if there would be benefits or drawbacks to using either. Thanks.
  2. Jun 11, 2012 at 8:08 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    You really need to know the loaded tongue weight.
    The TT we own lists 440 lbs as tongue weight also, but loaded it easily tops 650 lbs.
  3. Jun 12, 2012 at 5:13 PM
    TacoPronto
    Upstate NY
    2012 TRD Off Road
    Fair enough, but let's assume it comes in under 600lbs. Would there be benefits or drawbacks going with the oversized 800lb unit?
  4. Jun 12, 2012 at 8:36 PM
    sechsgang
    There is not that much difference between 600 and 800 lbs, so I would probably go with the heavier one.
    Too much tongue weight rating can result in a difficult to adjust hitch, and too much weight transfer with a lot of forces on your frame and trailer hitch. Probably not with a 800 lbs model though.
  5. Jun 13, 2012 at 10:00 PM
    Adonis
    Adonis Member
    Florida
    Tacuma-2005
  6. Jun 14, 2012 at 2:56 PM
    JUJtacoma2010
    JUJtacoma2010 Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    so which hitch did you decide to go with? I am picking up one TT this weekend with a tongue weight of 390. Not sure how much the loaded tongue weight is.
    What did you use for the brake controller? did you get one
  7. Jun 15, 2012 at 7:29 AM
    TacoPronto
    Upstate NY
    2012 TRD Off Road
    I haven't pulled the trigger on either yet. I'll probably go with a 750lb or 800lb WD hitch.
    As for the brake controller, I picked up a Tekonsha P3. The price difference was minimal between it and the Prodigy P2, so I said what the heck.
  8. Jun 18, 2012 at 11:07 AM
    JUJtacoma2010
    Fresno
    I picked up a P2 from etrailer.
    I am a little worried about the wdh I am getting. it has a rating of 10,000lb max trailer and a 1000lb max tongue weight. The owner of the trailer is giving this with the trailer.
    does anyone think that its not a good idea for me to use this wdh for my
    Dry gross weight-3375
    Tongue weight -390
    trailer?
    do you use a additional side view mirror?
  9. Jun 18, 2012 at 11:25 AM
    tractng
    tractng Well-Known Member
    You will need at least the passenger side. My trailer is only 7 feet wide and I barely can see.
    What trailer did you get?
  10. Jun 18, 2012 at 5:02 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Are you getting air bags?
  11. Jun 20, 2012 at 9:04 PM
    sechsgang
    Yeah, that WDH is probably a bit too much. It will be difficult to adjust correctly, and could actually do damage transferring too much weight. I'd look for something in the 600 / 6,000 lbs category.
