6 speed manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kpazzh0ly, Jan 7, 2010.
  1. Jan 7, 2010 at 3:30 PM
    kpazzh0ly
    kpazzh0ly [OP] Member
    Paul
    Round Lake Hts, Il
    hello Tacoma owners. I don't actually own a Tacoma, just work on them. I ask of you for a favor as one car enthusiast to another.
    I own a Lexus IS300, and found that it may be possible to use the 6 spd from a Tacoma in our vehicles, obviously with some modifications. IS300's don't have a lot of options for standard transmissions that are reliable and economically friendly to swap. So we are venturing out and trying to find some specifications.
    I have found some information and would greatly appreciate it, if possibly a guru could help me out. I would like to know the bolt pattern on the Transmission for the Bellhousing, and I could use overall dimensions.
    If someone has a trans. out of there truck right now, id be willing to drive and compare. At the moment I do not have any Tacoma's with a 6-spd at my work, otherwise I would do there.
    Thank you for reading, looking forward to your replies.
  2. Jan 7, 2010 at 5:38 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
  3. Jan 7, 2010 at 6:08 PM
    kpazzh0ly
    Paul
    Round Lake Hts, Il
    The IS only came in a 5 speed. Which they used a W55..... :-/
  4. Jan 7, 2010 at 6:13 PM
    kpazzh0ly
    Paul
    Round Lake Hts, Il
    That's really interesting because the IS300 from 02-05 only had the option of a W55 5-spd. So that's interesting.
  5. Jan 7, 2010 at 6:13 PM
    grammy
    grammy Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    I'd like to know the answer to this as well. I don't have an IS300 but I think they are awesome cars and would love to own one. GTE/Getrag swap would be nice as well.
  6. Jan 7, 2010 at 6:19 PM
    kpazzh0ly
    Paul
    Round Lake Hts, Il
    Yea I totally agree, but you're looking at 4000 just for a used trans. (ballpark) Plus drive shaft, bellhousing, clutch. And our dif. is to tall (3.72) for that trans. So best bet you have to swap it out with gs400 i believe.
    Or you can got with a r154 but that trans is sloppy. Now we have found that more than likely you can use an AR-5. Because it is built on the r154 housing.
    In any case thanks. But I am really curious about this trans. Although I do think that the first gear is too high.
  7. Jan 8, 2010 at 3:56 PM
    kpazzh0ly
    Paul
    Round Lake Hts, Il
  8. Jan 8, 2010 at 7:21 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I would not use this transmission. I would search out another. It has a history of bad throw out bearings. Also, the input shaft is not supported at the tip like most manual transmissions.
  9. Jan 8, 2010 at 8:10 PM
    kpazzh0ly
    Paul
    Round Lake Hts, Il
    Well would anyone the difference between the RA60 from the tacoma and the RA62 of the IS250?
    At the moment I am just trying to find out if the bell housing bolt pattern would match up to a 1jz bell housing. Basically is the RA60 and the R155 the same bell housing bolt pattern?
  10. Mar 7, 2010 at 6:11 PM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    Did you ever find the answer to this or any other alternatives?
  11. Mar 7, 2010 at 8:19 PM
    tonkatoy
    tonkatoy Well-Known Member
    Billy
    Phoenix, AZ
    08 White TRD Sport Acc 4x4 6 spd
    Have to add that this transmition is a clunka. Bad to bearings make it very squeeky deeky. Trust me, mine squeeks and squeeks and squeeks. Toyota doesn't even have a tsb for it. They'll put in a new bearing thats good for another 25,000 miles. Then it squeeks again. There too busy keeping there cars from crashing into things right now. I hope they come to terms with a permanent fix.
