6-speed manual vs. automatic
Discussion in '4th Gen. Tacomas (2024+)' started by hemlockz, Sep 3, 2024.
  1. Sep 3, 2024 at 5:32 PM
    hemlockz
    hemlockz [OP] Well-Known Member
    24 Bronze ORP 6MT
    I'm still waiting for delivery of my new truck that's why I'm making this kind of post. BTW I'm signed up for a 6MT
    These are all the differences between the 6-Speed manual vs the 8-Speed automatic that I have found. When comparing the same base model, for example TRD ORP 5-foot bed.
    Price:
    AT is $1,100 more than MT
    Power:
    AT is 278hp @ 6000rpm
    MT is 270hp @ 5400rpm
    Torque:
    AT 317 lb-ft @ 1700rpm
    MT 310 lb-ft @ 2800rpm
    Curb Weight:
    MT 4,650
    AT 4,630
    Towing:
    MT 6,400
    AT 6,300
    Max Payload:
    MT 1,525 lbs
    AT 1,610 lbs
    Ratios
    1st gear
    MT 4.79
    AT 4.41
    2nd gear
    MT 2.42
    AT 2.81
    3rd gear
    MT 1.44
    AT 1.95
    4th gear
    MT 1.00
    AT 1.51
    5th gear
    MT 0.83
    AT 1.27
    6th gear
    MT 0.64
    AT 1.00
    7th gear
    AT 0.79
    8th gear
    AT 0.65
    Reverse
    MT 4.07
    AT 3.65
    Differential ratio
    MT 4.3
    AT 3.58
    Diff Ring Gear Diameter
    AT 8.2"
    MT 9.5"
    Rear Diff Ground Clearance:
    AT 9.5"
    MT 9.0"
    4x4 modes:
    AT Crawl Control, Multi-Terrain Select
    MT Not available, gotta just use the clutch and brakes
    TSS 3.0:
    AT Parking assist with automatic braking and pedestrian detection
    MT Parking assist sonar alert (audio alarm)
    AT Full range adaptive cruise control
    MT adaptive cruise control (in one gear)
    Other:
    AT modern technology
    MT reminds old guys of their youth
    Its kind of surprising, MT weights 20 more pounds and has 85 lbs less payload. presumably due to slightly less powerful engine. But then has 100 lbs more towing rating, probably due to its lower gearing?
    6MT not available for a 6-foot bed. I think I read there are 2 drive shaft versions and they aren't long enough for MT in a long bed configuration because the MT is smaller and needs longer drive shaft.
    Am I missing anything?
    JuanitoBonito and tcaustin like this.
  2. Sep 3, 2024 at 7:47 PM
    Motor Away
    Motor Away Well-Known Member
    One thing I would add is the SR trim receives the same engine as the higher trims when you choose the manual. The detained engine on the SR is automatic only.
    shakerhood likes this.
  3. Sep 3, 2024 at 11:11 PM
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
    4-low, 1st gear
    You can downshift and upshift while the cruise remains on just like the auto. Only difference is you have to do the shifting, which is why one buys an MT.
    hemlockz[QUOTED][OP] likes this.
  4. Sep 3, 2024 at 11:22 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That was quite a surprise for me driving my new 3rd gen home from the dealer. All my previous vehicles always disengaged cruise control any time the clutch was depressed so when I downshifted for a hill and the truck started accelerating back up to the set speed it was unexpected.
  5. Sep 3, 2024 at 11:35 PM
    Want-a-taco
    Same thing, except I was downshifting for an off ramp and it wasn’t slowing down. I hit the brakes and didn’t really clue in, thought maybe iMT since I had it on. The 2nd time I pushed the clutch to disengage the cruise, I caught on. It’s a nice feature now that I know the clutch doesn’t disengage the cruise. I use the brake or cancel button now.
  6. Sep 4, 2024 at 9:12 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The clutch disengages cruise on my 3rd Gen.
    doublethebass likes this.
  7. Sep 4, 2024 at 9:29 AM
    Want-a-taco
    I believe it’s only with adaptive cruise control
    shakerhood[QUOTED] likes this.
  8. Sep 4, 2024 at 10:17 AM
    shakerhood
    Southern Ohio
    That makes sense.
  9. Sep 4, 2024 at 10:23 AM
    TRD75
    TRD75 Member
    23MY GR86 [2021 PRO 6MT MBM gone]
    I believe MT has A-TRAC. Third gen MT did.
    EubeenHadd likes this.
  10. Sep 4, 2024 at 10:34 AM
    2001 4x4
    2001 4x4 Well-Known Member
    2008 TRD Offroad 6MT
    I find the gear ratios for 1st and 2nd to be a little extreme. First seems REALLY low and 2nd seems really high. Has anyone driven both the MT and AT 4th gen Tacos back to back and given a driving report?
  11. Sep 4, 2024 at 10:40 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Who would want this? Aren't the only people willing to wait for an MT are the ones who want to control the shifting and speed themselves?
    Who wants the car to do the majority of the driving for them, and want to change gears and work the clutch? These seem like they should be mutually exclusive.
    tcaustin likes this.
  12. Sep 4, 2024 at 10:43 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Correct, radar cruise mode stays in cruise when you use the clutch. Standard cruise (on 2016-2017 models or on later models if you hold
    the cruise “on” button), will cancel when you hit the clutch.
  13. Sep 4, 2024 at 10:50 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    4th gen MTs have a lower redline than the ATs. Designers metioned at one point that they had a high RPM vibrations issue with the carryover manual that they didn't have the budget to tune out, so they just lowered the redline to below where that happens.
    I don't remember what the exact decrease is, but it was fairly significant.
  14. Sep 4, 2024 at 11:07 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Long highway drives don’t require much shifting, might as well have the cruise control help out a bit.
  15. Sep 4, 2024 at 11:21 AM
    hemlockz
    24 Bronze ORP 6MT
    Yep, absolutely. I get restless legs holding the accelerator with my foot still on long drives, it can be excruciating (all psychological) ankle pain if I can't move it around. Hard to describe, but I definitely appreciate the cruise control on long drives.
  16. Sep 4, 2024 at 11:27 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Those numbers are a pipe dream for either. I haven't seen any hard info on a 4th gen yet but 2nd and 3rd gens posted similar (MAXIMUM) payload numbers but the real-world numbers for a DC 4X4 2nd gen were around 1200 lbs. A 3rd gen, 900-1000 lbs. I'll be shocked if the 4th gens are much if any better.
    This is a HUGE improvement for 4th gen trucks. But still a huge disadvantage for the manual especially if you tow. The automatic gets its power at much lower rpm. You have to rev the engine up high in order to get a load moving with the manual. It is near impossible to back a trailer uphill with either a 2nd or 3rd gen with a manual. 2nd gens needed 3600 rpm, 3rd gens 4600.
    Getting torque under 3000 rpm should be a MUCH better match with the manual in 4th gen trucks. That's getting close to diesel torque/rpm numbers.
  17. Sep 4, 2024 at 11:35 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    The hybrid is 465 ft/lb @1700. That's definitely small diesel territory.
  18. Sep 4, 2024 at 11:38 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    This is the perfect combo IMO. I don't want to have to think about the fucksticks that pull in front of faster traffic then decided not to use cruise, forcing me to either manually control speed or aggressively pass them to go back to consistent speeds. I also don't want the truck to be unable to come to a decision about which gear is correct driving through the mountains. MT means it's gonna use the gear I choose and not hunt, radar cruise means it's either going to go as fast as it can or at the speed I set without me needing to think about two vehicles' worth of driving decisions, one of which I've already identified as someone inconsiderate or blind enough to pull in front of faster traffic.
  19. Sep 4, 2024 at 11:47 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    That's a good point, you get the benefit without the whiplash. Just fundamentally it didn't make sense to me at first.
    I usually don't use cruise control because when there is a slight hill, the transmission acts like it's having a stroke (and this is the beloved 5 speed, too). Adaptive cruise usually has a lag that causes the same issues.
  20. Sep 4, 2024 at 11:55 AM
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    Both my 2nd Gen and my 4th Gen DC LB's are indeed placarded at about 1200 lbs. So, 4th Gen payloads restored to 2nd Gen levels and well short of 1600 lbs.
