6-speed guys: at 35mph, what gear are you in?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Iowa10, Jun 30, 2016.
  1. Jul 3, 2016 at 10:12 AM
    #41
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    Usually 4th maybe 5th if it's slightly down hill. 6th and sometimes 5th at 35 on flat ground starts to lug and kill mpg. If I was on stock tires I would be in 5th more often at that speed.
  2. Jul 20, 2016 at 11:58 AM
    #42
    Iowa10
    Iowa10 [OP] Well-Known Member
    Ha, that's exactly why I stay in 3rd at 35mph. The noise the engine makes at around that 2,200rpm mark keeps me mindful of my speed. If I shift into 4th, I'm almost certain to go 40mph+ and I don't need another speeding ticket.
    Pigpen[QUOTED] likes this.
  3. Jul 20, 2016 at 12:01 PM
    #43
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    3rd gear for me and I'm sitting just above 2000 rpm. Lots of torque making getting around easy and decent engine breaking.
    I'm on 32" tires.
  4. Jul 20, 2016 at 12:05 PM
    #44
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Probably 4th, definitely not 5th. The engine doesn't like being under 1,500 RPM but I suspect power loss due to 6000' elevation/thinner air is to blame for that.
    I tend to sit in 4th a lot in the suburbs.
    Though it also depends if I'm coming down to 35 mph from a higher speed or coming up to it from a lower speed. Probably 4th if coming down and 3rd going up depending on how long I'll be at 35.
  5. Jul 20, 2016 at 12:06 PM
    #45
    Iowa10
    Nope, I've had 7 others before this one. It's not like sustained travel at 2,200rpm is hard on the drivetrain. Hell, it's higher than that in 6th gear at 70mph.
    As an aside, in 13000 miles, my truck has never once seen the tach above 4,000rpm so I don't think it leads too rough a life. ;-)
  6. Jul 20, 2016 at 12:07 PM
    #46
    TheMuffinMan
    Coeur d'Alene, ID
    +1
  7. Jul 20, 2016 at 12:42 PM
    #47
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    With VVT-i you can lug the motor at very low RPMs without pinging or other adverse effects. Sure you should downshift if you are climbing a hill or need to accelerate quickly but for cruising on relatively flat roads, the motor (at least in my truck) seems perfectly comfortable humming along just over 1K RPM.
    I wouldn't advise this on a 1st generation 22-R though ;)
  8. Jul 20, 2016 at 12:56 PM
    #48
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Been driving a manual transmission since I learned to drive 18 years ago. There's no rule of thumb and what gear you use for a given speed depends on a lot of factors. After you've driven a vehicle for a length of time you get a feel for which gear works best at what speed.
    With that said, I usually shift my Tacoma at the following speeds:
    1-2 at 15 mph
    2-3 at 25 mph
    3-4 at 35 mph
    4-5 at 45 mph
    5-6 at 55 mph
    I have no issue with regularly revving mine full throttle up to 4-5k RPM when I'm getting on the highway or horsing around, I mean that's one of the reasons I got my truck with a manual transmission in the first place. The power starts to drop off after a certain point so it's not worth going all the way to red line before you shift.
  9. Jul 20, 2016 at 1:01 PM
    #49
    TheMuffinMan
    Coeur d'Alene, ID
    I get pinging when I lug mine if I leave it in 3rd as I bounce over a speed bump in my apartment complex and accelerate after that when I'm going probably 5-10mph.
  10. Jul 20, 2016 at 1:33 PM
    #50
    Iowa10
    LOL, yeah I personally don't get it, but whatever. Even with sustained driving at 50mph, I'm still not in 6th.
  11. Jul 20, 2016 at 2:01 PM
    #51
    TheMuffinMan
    Coeur d'Alene, ID
    At 50mph on flat ground I cruise in 6th.
  12. Jul 20, 2016 at 5:04 PM
    #52
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    i rarely use 6th unless I'm cruising for long periods of time
  13. Jul 20, 2016 at 7:56 PM
    #53
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    I rarely use 5th. It's so close, most times I just shift straight from fourth to sixth.
    shakerhood likes this.
  14. Jul 20, 2016 at 8:59 PM
    #54
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    COuld be 4th 5th or 6th, flats roads and near sea level in SNJ, i usually lug in the highest gear possible if im holding constant speed. it depends on the road
  15. Jul 22, 2016 at 3:37 AM
    #55
    BWIG
    BWIG Tarheel.
    2008 TRD OR AC 4X4 V6 Manual.
    I try to avoid ever lugging my engine.
    Duck_Hunter likes this.
  16. Jul 22, 2016 at 6:22 AM
    #56
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Same here
    TheMuffinMan likes this.
  17. Jul 22, 2016 at 6:36 AM
    #57
    NickofTime
    NickofTime Well-Known Member
    Nick
    Anchorage, Ak
    2006 White Tacoma DCSB TRD
    I just throw money at my truck
    After reading through this thread, it makes sense why my mileage is so shit. Some of you guys are 6th gear @ 35?? Geez Us. I like to live my life 1/4 mile at a time so I keep it 3rd gear @ 35
    Doggman likes this.
  18. Jul 22, 2016 at 7:19 AM
    #58
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If I put mine in 6th at 35, my engine would be below idle and die. Lol. @ 50mph, in 6th, it is barely over 1K. I doubt 5th would even keep the engine spinning at 35mph....Hmmm
  19. Jul 22, 2016 at 9:53 AM
    #59
    Iowa10
    Just for S&G, I put it in 6th yesterday on a long stretch of 35mph. I mean, it works, but it sure didn't seem happy. If it's a stretch without any stoplights I'll do 4th gear, but if there are stoplights, I choose 3rd so I can punch it if the light turns yellow.
  20. Jul 22, 2016 at 10:16 AM
    #60
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    3rd! I see no reason for anything else
