6" ROUGH COUNTRY LIFT
Discussion in '1st Gen. Tacomas (1995-2004)' started by albert7991, May 29, 2019.
  1. May 29, 2019 at 7:21 PM
    albert7991
    albert7991 [OP] Active Member
    Albert
    Vancouver WA
    99 Red Tacoma SR5 TRD Off Road 200K+
    Fabtech suspension 4.5" lift Rolling on 33s Gutted
    Hey everyone. Anyone here install this 6" lift kit? Simple enough to do on jack stands over a weekend or should I do it at work using my hoist? Or find a shop to do it for me while I'm at work? Page says 6-8 hours install cant leave truck on my hoist overnight since i need it to work on customers cars the next day. Ill be ordering it shortly. Currently have a 2.5" inch lift fabtech coil overs in the front + 2" body spacers which i might remove since I'm getting a 6" lift and 2" body on top of that will be overkill for my wife who is 4'11".https://www.roughcountry.com/toyota-suspension-lift-kit-74130.html
  2. May 29, 2019 at 8:59 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    But why friend.
  3. May 29, 2019 at 9:02 PM
    albert7991
    Albert
    Vancouver WA
    I have a daily and my current shocks are leaking. Its $1500 for the shocks i have or like $400 to reseal+ shipping from WA to Los Angels. This 6" will cost me slightly more than a reseal but will also provide me with a skid plate(which i been needing). New shocks. A brake line extension(also been needing due to it stretching when full extended) and well more clearance.
  4. May 29, 2019 at 9:05 PM
    Sebz13
    Shane
    Maui Hawaii
    970btu, whatstcp and QuicksandTaco like this.
  5. May 29, 2019 at 9:09 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Tacomaworld isn’t very supportive of bracket lifts in general...
    I easily fit 33 skinnies with 1/3 of that height on my 99. Your wife will be extra thankful..
    808charger and whatstcp like this.
  6. May 29, 2019 at 9:25 PM
    albert7991
    Albert
    Vancouver WA
    I understand the suspension sits lower but doesn't the frame driveshaft and exhaust sit any higher in the middle of the truck?
  7. May 29, 2019 at 9:26 PM
    albert7991
    Albert
    Vancouver WA
    I have 33s right now. 12.5 in width and they don't rub.
  8. May 29, 2019 at 9:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @albert7991 let's go back a little bit; what exactly do you wish to accomplish and how much do you really have to spend?
    Rachelsdaddy likes this.
  9. May 29, 2019 at 9:46 PM
    albert7991
    Albert
    Vancouver WA
    Get new shocks skid plate and brake line extensions are the priorities even of i stay at the 4.5" I'm at right now (2.5" suspension 2" body). Thought getting the 6" would help clear some obstacles that you'd high center on in the middle of the frame? And don't really have too much to spend on mods trying to keep <1k for the coil overs or kit. .....so say if i dont get the 6" lift would you guys recomend resealing the fabtech coil overs i have or getting new ones? Fabtech doesn't sell my particular once anymore but equivalent they said would be $1500. Or they referenced a shop that reseal them in LA (im in Vancouver WA) which would be about $400+shipping coil overs there and back
  10. May 29, 2019 at 9:50 PM
    Sebz13
    Shane
    Maui Hawaii
    Look a little harder for someone who can rebuild them, I still think you would be happier off sourcing a skid and brake line extensions separately.
    Yes, you will be higher in the center, but you then think of this, you are going to have to run blocks in the back further limiting articulation, the front will remain the same as the rear ground clearance wise.
    you are going to change driveline angles and have to deal with worn carrier bearing and possible vibration from unfavorable pinion/driveline angles.
    in my opinion of things if you cant have the coilovers rebuilt, a strut setup from @Wheeler's Off-Road Inc could get you set up.
  11. May 29, 2019 at 9:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ok but the second question was, how much can you spend?
    Bilstein 5100's are an affordable alternative to obtaining a lift as well as gaining better on and off-road manners than stock (since you keep mentioning clearance, etc).
    You can get away without extending your front brake lines since you won't articulate much; the rear only consists of a single brake line and will cost you less than $40 bucks.
    Not to mention, you would be able to do it yourself easily the same day.
    I just replaced my rear shocks within 15 minutes earlier this morning.
    Area51Runner likes this.
  12. May 29, 2019 at 10:14 PM
    albert7991
    Albert
    Vancouver WA
    Lets say $1k-$1.5k and just checked the bilstein 5100s they are shocks. Whats leaking are my 2.5" lift coil overs in the front. Yea i know labor itself is easy for stuff like this. I do similar for a living (Mercedes Benz Tech) just not too knowledgeable in the offroad lift area.
  13. May 29, 2019 at 10:31 PM
    albert7991
    Albert
    Vancouver WA
    This is my current setup. I have it on jacks because I'm taking off the lower control arms to press out the old bushings and press in new ones.20190529_222356.jpg 20190529_222414.jpg 20190529_222458.jpg
  14. May 29, 2019 at 10:49 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Definitely leaking :annoyed:
    If you have that to spend, why not dump the spacer/block lift and just go with an Old Man Emu Suspension Lift? Not going to get you to 6" by a long shot in fact it'll be somewhere around 2.5 - 3" but honestly, with that 6" you're going to have more problems than you think.
    At 2.5-3" are trucks are really at their best. http://www.lowrangeoffroad.com/toyo...mu-suspension-lift-kit-heavy-ometac04hks.html
    https://www.headstrongoffroad.com/store/c97/Tacoma_1995-2004_Complete_Lift_Kits.html
    As for install, there is a enough documentation here on TacomaWorld and YouTube that just about anyone could do it. You're a mercedes tech, you should have no issue with it. coilovers and leaf springs...
    If sticking with the Rough Country thing, all I can say is good luck (I know nothing about Rough Country - sorry).
  15. May 29, 2019 at 10:51 PM
    Area51Runner
    also, what tires/wheels are you running?
  16. May 29, 2019 at 10:51 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Mall crawler kit
  17. May 29, 2019 at 10:56 PM
    albert7991
    Albert
    Vancouver WA
    I have 33x12.5r15 on the mickey Thompson wheels.
  18. May 29, 2019 at 10:57 PM
    albert7991
    Albert
    Vancouver WA
    Lol yea thats what ive been noticing so not getting it. Now i been looking for alternatives either find a shop to reseal or replace. Called a handfull of offroad shops locally all dont rebuild.
  19. May 29, 2019 at 10:59 PM
    albert7991
    Albert
    Vancouver WA
    Idc about the brand haha what ever does the job. Yea my suspension is at 2.5" right now.
  20. May 29, 2019 at 11:12 PM
    albert7991
    Albert
    Vancouver WA
    https://www.bilsteinlifts.com/shop/...ble-front-shocks-for-1995-2004-toyota-tacoma/
    Im looking at these right now. If it comes as a kit my rear shocks can use replacing. The $1k-$1.5k was if im changing my lift and such which is obviously not worth it as per everyones comments on the bucket list. Would be nice to just R&R for $500. Ill have to check to make sure i can reuse the fabtech spring on the 1500 shock.
    Area51Runner[QUOTED] likes this.
