6 lug to 5 lug conversion
Discussion in '5 Lug' started by Dr.I.B.Rollin', Jan 16, 2016.
  1. Jan 16, 2016 at 5:18 PM
    Dr.I.B.Rollin'
    Dr.I.B.Rollin' [OP] Member
    joshua
    2001 double cab tacoma
    ok, I have a 2001 double cab Tacoma and I was just wondering if the conversion from 6 lug to 5 lug would be as simple as changing out the rear axles and the front spindles?
  2. Jan 18, 2016 at 6:48 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    OK, why...?
    goldentaco03 likes this.
  3. Jan 23, 2016 at 2:55 PM
    Dr.I.B.Rollin'
    joshua
    i've come to notice there's a better wheel selection for 5 lug than there is for six lug. The set of wheels i've found are only made for five lug.
  4. Jan 23, 2016 at 2:57 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Way easier and cheaper to have the wheels re-drilled for a 6lug. Whole entire suspension and mounting points are different. Hell, you'd even be better off selling your truck and buying a 5lug
  5. Jan 23, 2016 at 2:59 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    First of all why the hell would one want a 5 lug. Secondly you can probably get some sort of adapter/wheel spacer that will convert from a 6lug pattern to a 5 lug pattern.
  6. Jan 23, 2016 at 7:47 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Wow, really? You do realize that this question was asked on, and posted to the 5-lug sub-forum, right?
    Bore size, possible need for center hub ring-adapters would require further investigation, before considering the below spacer/adapter find:
    http://www.amazon.com/Wheel-Adapter-Lug-5-5-4-5/dp/B008L4NAFE/
