6 lug axle to 5 lug axle swap is it possible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chris280e, Jan 19, 2023.
  1. Jan 19, 2023 at 9:39 PM
    Chris280e
    Chris280e [OP] Active Member
    Christian
    2002 Tacoma base model 5spd
    Can you convert a six lug axle to a five lug axle and or are the axle carriers interchangeable?
  2. Jan 19, 2023 at 9:45 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    You might be able to have your axles redrilled for 6 lug pattern but I doubt you could find drums since the 5 lug drums are smaller. The 6 lug axles are 8" ring gears in larger carriers than the 5 lug which is a 7.5".
    I'd just weld 5 lug perches on a 6 lug axle housing and toss it in place if you want 6 lug in the rear.
  3. Jan 19, 2023 at 9:51 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Are you thinking about using a 5 lug wheel? Curious why you would do this.
    Bivouac likes this.
  4. Jan 19, 2023 at 10:14 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Why do you want to, because that will determine the answer
    Wulf likes this.
  5. Jan 19, 2023 at 10:17 PM
    Chris280e
    Christian
    Ahhh yes you’re right I remember reading about the different sized ring gears
  6. Jan 19, 2023 at 10:22 PM
    Chris280e
    Christian
    So I’ve been wanting to change the rear axle on my 2002 2.4L 5 speed manual base taco. She has the 3.48 or is it 3.58? Anyways I was just curious cause I’m going to be purchasing a 1999 pre runner 6 lug that was in a roll over accident. I’m getting the hood, grill, lights front bumper, seats and trying to part out the rest of it. For a split second I thought maybe the rear axels were interchangeable if it had a more favorable gear ratio than the one I have now.
  7. Jan 20, 2023 at 12:08 AM
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    The axle from a 6 lug truck will not bolt into a 5 lug truck. 6 lug trucks use a spring-over suspension and the 5 lugs are spring-under. I think the e-brake is different as well but I am not sure. The driveshaft might be an issue as well. Even if the e-brake/driveshaft aren't issues you would have to cut off the stock SOA spring perches on the axle and weld on SUA perches. You could keep 5 lug wheels with adaptors.
    You might find more info if you search in the 5-lug forum:
    https://www.tacomaworld.com/forums/5-lug.114/
  8. Jan 20, 2023 at 2:53 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I think your looking at more fabrication then you want to make that happen.
    Now your needing to carry 2 different spares as well.
    Search for the differential gears to fit your housing with the ratio you seek.
  9. Jan 20, 2023 at 8:19 AM
    Chris280e
    Christian
    yea that sounds like a lot of work (sigh). I found a 5 lug axel that I wanted on eBay but they wanted $600 for it and I don’t think that included shipping (sad emoji face). I guess I’ll just sell everything I don’t need off the donor truck.
  10. Jan 22, 2023 at 1:48 PM
    Sebz13
    Shane
    Maui Hawaii
    Look into a ford 8.8
    Chris280e[OP] likes this.
  11. Jan 22, 2023 at 2:20 PM
    Sebz13
    Shane
    Maui Hawaii
    Sorry meant to post more. There is a guy who ls swapped his 1st gen on YouTube. He swaps the rear to a ford 8.8 if I remember correctly it’s bolt on maybe a little moddint
  12. Jan 22, 2023 at 2:20 PM
    Sebz13
    Shane
    Maui Hawaii
    Toms turbo garage
  13. Jan 22, 2023 at 2:29 PM
    Bivouac
    I am sure their is more then just bolting it in
    Narrowing Ford axles was a go to back in the day.
    Sebz13[QUOTED] likes this.
  14. Jan 22, 2023 at 2:33 PM
    Sebz13
    Shane
    Maui Hawaii
    I don’t have time to go through it but I’m almost positive it’s a straight swap minus driveshaft adapter and I think with the 5 lugs the shock and ubolt “frame” needs to be slightly redrilled
    here another guy did it too
    https://youtu.be/NJ97eOMf8Cw
  15. Jan 22, 2023 at 2:40 PM
    Chris280e
    Christian
    hey! Yea I had read somewhere that was an option just didn’t know there was a YouTube video on how to do it! Thank you I’ll check it out.
  16. Jan 22, 2023 at 3:06 PM
    Chris280e
    Christian
    I just got through the video where he swapped them out. Yea looks like it pretty much bolted right up minus some grinding. What would be the advantage of using that ford rear end? I’m guessing they can handle more horse power? Also if you wanted disc brakes in the back?
  17. Jan 22, 2023 at 6:41 PM
    Sebz13
    Shane
    Maui Hawaii
    Disk brakes. Stronger axle, cheaper more plentiful parts I assume. It’s an almost 9 inch ring gear too as apposed to 7.5 so beefer. Let’s call this the 5 lug equivalent to tons lol
