6" lift spindles
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grizz_bear, Apr 30, 2016.
  1. Apr 30, 2016 at 10:09 PM
    Grizz_bear
    Grizz_bear [OP] Member
    Seth
    Lebanon Oregon
    1998 excab tacoma black
    9 inch lift on nitrogen charged shocks and alcan springs. Halogen headlights . Double roll bar
    i have a trail master lift kit. (came with the truck) im looking to remove it but i need lift spindles to do so. does anyone know where i can find some for a 6" lift? it is a drop bracket lift
    HalfJap likes this.
  2. May 7, 2016 at 1:27 AM
    HalfJap
    HalfJap Active Member
    Evanston, Wy
    2000 Tacoma TRD
    I also just purchased a 2000 Taco, V6 4x4. 6" lift.
    Had to start a thread just to find out what that weird second strut was. Turns out to be Trail Master.
    Have been shopping online for parts to convert to UCA's. What a frustrating experience.
    Anyway, is yours 2wd? Need spindles? I see them on many websites for sale. Actually a part that can easily purchased outside buying a kit.
    Google search year+ make+spindles.
    If yours is 4x4 you don't need spindles. You need steering knuckles 6" lift and UCA's.
    Maybe we can help one another out by posting what we find.
  3. May 8, 2016 at 8:06 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    Fabtech is the last of the companies to offer a 6" dropbracket lift kit... you could try to see if their spindle can be used with the Trailmaster kit... you can see the spindle on their website at http://www.fabtechmotorsports.com/T...-Toyota-Tacoma-4-Cyl-6-Lug-2WD-4WD-p1368.html
    as for shocks, you can get into a set of Kings with dual rate springs to get rid of the coilover spacer... you would likely need a 12" travel dual rate coilover...
  4. Jul 23, 2018 at 9:46 AM
    skiersarb
    skiersarb Active Member
    Andrew
    1997 Tacoma
    what did you guys figure out about this? My tacoma has this stupid lift on it too and the strut is blown
  5. Jul 23, 2018 at 9:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    Thread over 2 years old. 1st two posters haven't been here in over a year.
    You can see this by clicking on the posters name.
    Point is, don't be disappointed if you get no response. (from them)
  6. Jul 23, 2018 at 9:58 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Your best bet would be to take this lift off and put a "normal" setup on. They don't make the Trail Master lift anymore (for good reason) so you aren't going to find the parts you need for it, at least not easily.
    You'll probably need to re-fabricate or re-install whatever was removed to put this lift on in the first place; likely not going to be a fun project but at least in the end you'll be better off in the long run.
  7. Jul 23, 2018 at 10:17 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    There are a few other more recent threads on this same subject. search around for them.
    But to summarize: Previous owner screwed you by making it difficult (but not impossible) to revert back to stock or a 3" lift.
    So it depends on what you want to do with your truck. If you want to off-road with it, you'll want to seriously consider reverting to a good quality 3" (or less) lift which will require fabrication. You'll get WAY better performance out of a well thought out 3" lift with high quality Fox/King/Icon shocks than any 6" bracket lift.
    If you're desperate to keep a 6" lift (that doesn't suck), Fabtech is probably your best bet, but even then, you pay $3,500 and the rear is still just an add-a-leaf and blocks.
  8. Jul 23, 2018 at 11:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    Or you could say whoever did the pre purchase inspection didn't make it clear to the buyer that issues would arise from this setup.
    Or even caveat emptor seems to apply.
    OP, hope you can square it away with a minimum of mess.
  9. Jul 23, 2018 at 11:41 AM
    jbrandt
    Justin
    Yeah, I didn't mean that the previous owner was malicious, just that this particular modification makes it hard to go back to a stock configuration, should the new owner want something different down the road, like a "better" lift system.
  10. Jul 23, 2018 at 12:33 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    If the only part of your lift that's messed up is the shock, you can go with a custom King front shock that will replace the stock shock AND the funky spacer... if I recall, a 14 inch travel front coilover should suffice... my buddy did a 12 inch travel King coilover for his Pro Comp 4 inch drop bracket lift and it rides 1000x better than the stock shock with the spacer...
    You can contact King Shocks with your setup and they can advise you which coilover to go with... if you have the wallet for it, a dual rate shock would be a comfortable ride...
  11. Jul 23, 2018 at 12:44 PM
    skiersarb
    Andrew
    1997 Tacoma
    thanks for the idea- contacting them to see what they say
  12. Jul 23, 2018 at 12:50 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    @bluzrider can show you a pic of his ProComp drop bracket lift with the King coilovers...
    bluzrider likes this.
  13. Jul 23, 2018 at 12:52 PM
    skiersarb
    Andrew
    1997 Tacoma
    Its the one on the left that is blown. do you still think it could work?
    13txtaco likes this.
  14. Jul 23, 2018 at 1:52 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    The shock on the right is what I assumed you meant by the strut being blown. They put a spring/shock on the spindle on the left?
  15. Jul 23, 2018 at 1:53 PM
    skiersarb
    Andrew
    1997 Tacoma
    That is the Trailmaster lift. yes.
  16. Jul 23, 2018 at 2:02 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    Wow, k. If it were my truck, I would consider one of two options.
    1. Find a fabricator who can make a full size replacement spindle to replace that whole TM setup and get the custom size King shocks.
    2. Find a fabricator who can make and mount a whole new lower crossmember and replace the whole dropbracket system to bring you back to stock height.
  17. Jul 23, 2018 at 2:07 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    Have you peeked under that boot? Just to confirm that it's a shock under there? Trailmaster appears to be in business still so maybe they could help you out, even if it's just some technical help since they no longer make a db lift for first gens...
  18. Jul 23, 2018 at 2:17 PM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
  19. Jul 23, 2018 at 2:46 PM
    skiersarb
    Andrew
    1997 Tacoma
    It is a shock under there . Trail master bought the name from the old company that is no longer in business (the one that made the kit) and they don't have any info on it. They bought the name only. -I called them already.
  20. Jul 23, 2018 at 2:58 PM
    UnderFire
    UnderFire Well-Known Member
    Fabtech likely would sell the spindles for their kit separately, you may also need to buy uppeu control arms, not sure if that lift swapped them for something other than stock.
