6" lift pros/cons
Discussion in 'Suspension' started by Capitol, Jan 19, 2023.
  1. Jan 19, 2023 at 3:25 PM
    Capitol
    Capitol [OP] New Member
    Tyler
    2019 Black Tacoma TRDSport
    Just wanting to know some of the pros and cons yall have had with a 6" lift.
  2. Jan 19, 2023 at 3:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What type of 6” lift?
    Drop bracket?
  3. Jan 19, 2023 at 3:35 PM
    Capitol
    Tyler
    Yes sir
  4. Jan 19, 2023 at 3:47 PM
    TnShooter
    Deogee
    STOCK
    Pros:
    Cheaper than Long Travel.
    The CV angles kept “better” inline
    Cons:
    You are cutting out part of your cross-member. Which is an argument for potentially “weaker” structural integrity.
    Limited to aftermarket skids and parts.
    Thats just a few.
    I’ve only had experience with 1 drop bracket lift.
    It wasn’t on a Toyota, and it isn’t wheeled hard.
    alwaysHI likes this.
  5. Jan 19, 2023 at 3:48 PM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    6in diff drop bracket = You have entered Floridaman territory
    airmax233, golfindia and TnShooter like this.
  6. Jan 19, 2023 at 3:51 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Drop brackets will bend if you get to crazy with it.
    Saw it happen on a truck right in front of me when climbing up a big ledge. He fixed it by replacing the drop cross bracket, but it never seemed to align correctly afterwards. I will look for the pics.
    Good luck with your truck.
    TnShooter likes this.
  7. Jan 19, 2023 at 3:52 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    no
  8. Jan 19, 2023 at 3:58 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Drop bracket rides like total garbage, bordering on dangerous, constantly has shit coming loose, wears tires quicker and gains you nothing.
    Mully likes this.
  9. Jan 19, 2023 at 4:00 PM
    TnShooter
    Deogee
    STOCK
    You gains the ability to run larger wheels/tires.
    Other than that, you are mostly correct. The gains are not worth it.
    And no, I’m not for DB lifts.
    They are not for me.
    Mully likes this.
  10. Jan 19, 2023 at 4:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    Remember your true ground clearance is at the axle line. Only tires raise that. Suspension lift will change approach/departure angles, but generally that doesn't matter much on a DB truck.
    It's mostly considered a looks thing. And it greatly narrows your resale market. Well, at least among knowledgeable folk.
  11. Jan 19, 2023 at 4:09 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Con. Significantly reduces the group size of people interested in your truck if you decide to sell.
    Superdave1.0, b_r_o, Mully and 2 others like this.
  12. Jan 19, 2023 at 4:16 PM
    Bishop84
    Bishop84 Well-Known Member
    The problem with 6” lift is you need to pony up and buy a coil over set or don’t bother.
    They ride great with coils from bds.
    but most have massive top hat spacers on factory shocks. So they ride like trash.
    A good 6” is over 2500$ anything less is brodozer garbage.
    They fit 35s no issue and can off-road moderate trails no issue.
  13. Jan 21, 2023 at 5:45 PM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    these two are the only ones I agree with.
    I run a DB.
    I regret it, knowing what I know now. Only reason why I regret it however, is because it makes it a bit difficult to load my 150qt fishing coolers. Had I stayed 3”, I would’ve gone Fox coilovers and a full leaf pack to handle the weight. At this height however, for a 3rd Gen Tacoma anyway, I’d drag my bumpers freaking everywhere..
    I have a pro comp on mine, full length bilsteins up front,14” Bilstein 5160 for the rear, Alcan leaf pack 650lb over stock capacity and 6” spring (I like a rake for when I load shit), archive hammer hangers and a whole bunch of shit. It gets expensive really quick!
    I don’t go on steep ass trails like Moab or bash my shit on rocks, but I’d like to say I do moderate things with it (I work wayyyy too hard to bash my only brand new vehicle in my life against things)
    I mainly traverse very uneven volcanic rock, and sand here and there
    Anyways, if you do go DB lift here’s my thoughts:
    Get FULL length shocks for the front. Fox or King coilovers, or Bilstein makes a full length strut (what I’m currently using) Accutune can tune them accordingly (not the Bilstein tho)
    Also upgrade to a better shock in the rear, and get a full leaf pack in order to ditch the block. I have zero axle wrap in mine, Alcan knows what they’re doing.
    I honestly have no idea what people are talking about regarding tires wear out quicker, rides like shit, or whatever. Like stated, the above two I quoted are the only ones I agree with. The others prolly don’t have a DB lift and are getting their miss-info from hearsay on Tacomaworld.
    I’m giving you my personal experience.
    With that being said, once you go DB, you can never go back (unless you have some one fab the crossmember but it’ll never be the same)
    I wish I had some off road action pics but I’m too lazy nowadays to get outta my truck to snap pics…if I’m offroad, I seriously wanna just get to my spot as safely and fast as possible cause I wanna freaking fish hahaha…plus I’m getting older
    Whatever you decide, remember:
    Buy once, cry once.
  14. Jan 21, 2023 at 5:48 PM
    alwaysHI
    2017 MGM DCSB
    forgot to quote you as well.
    agree.
    good luck finding skids online - no one makes um. Have to go custom
    TnShooter[QUOTED] likes this.
  15. Jan 22, 2023 at 1:44 PM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Pros:
    • you’ll gain real lift, in other way you have to limit uptravel or not gain any more room for the tires when compressed the front suspension
    • you’ll save the steering rack for the premature wear because the steering rods keeps near to vertical as originally
    • no need to cut frame if Rough Country kit is used (I’d choose 4” kit instead of 6” kit)
  16. Jan 22, 2023 at 2:41 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Pros there is none
    Cons truck will look lame ass shit
    Have to cut cross member
    And just don't.
    Mully likes this.
  17. Jan 29, 2023 at 1:20 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    That's a pretty solid hitting the nail squarely on the head.
    One of the best things you can do for in the event you ever sell or have some other reason to remove the kit, save the piece that is cut from your crossmember. This way you have the (unique) piece that fits in the space on your frame and it is only a matter of welding it (or having it welded) back into place.
    alwaysHI[QUOTED] likes this.
  18. Jan 29, 2023 at 6:30 AM
    FinnJ
    Finland
    Or buy Rough Country’s kit, when you don’t have to cut the crossmember. Upgrade it with decent coilovers/shocks are you are good.
  19. Jan 29, 2023 at 7:05 PM
    4x4junkie
    So Calif. (SFV)
    Rough Country 4 & 6" DB kits both require cutting the crossmember (they use the same drop-downs, only the spring spacers are different between the 4" and 6").
    https://s3.amazonaws.com/roughcountry/install/921757200B.pdf (Step 29 & 30)
    The RC 3.5" kit doesn't require cutting, it is not a DB kit (though I can't imagine the CV joints & steering rack are going to live long with that much lift and no DBs or knuckles).
    FinnJ[QUOTED] likes this.
  20. Jan 29, 2023 at 7:11 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    If you're 2wd you can do a 4" spindle lift with a 2" suspension lift. The spindle lift keeps stock geometry and requires no cutting.
