6" Lift on 33's overall height of truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clintonjeffries, Jul 12, 2010.
  1. Jul 12, 2010 at 12:09 PM
    clintonjeffries
    clintonjeffries [OP] Well-Known Member
    Clinton
    Wenatchee, WA
    07 4x4 SR5 super white
    6" stage 1 Procomp lift, 18" matte black XD Monsters, 33" Nitto Trail Grapplers, AMP Research Electric Steps, Grillcraft upper and lower grill, Paint matched tailgate handle, Black headlights w/ black corners & reflectors, 6k HID in heads and fogs, tint, RED badges, red brake calipers, black brake drums, flowmaster exhaust, black shorty antenna, remote start, iPod interface, Weathertech floormats front and rear
    I've got a slightly random request for somebody with a 6" lift...
    I'm looking at doing a 6" procomp lift, possibly another brand but 6" nonetheless, with 33" tires...
    Can anybody measure from the ground to the top of their roof for me for an overall height? I don't have roof racks so I don't need that included in the measurement...
    I park in a covered parking spot at my apt and it looks like I've got about 8" or so of clearance above my roof right now, at stock height. I need to know if I'll still fit in my spot before I jump into a 6" lift!
    This would help me out huge, thanks!
  2. Jul 12, 2010 at 12:49 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    seeing as stock size rims are 16" for TO and TS are 17", stock tires are 31"...
    overall gain in height should be as such...
    6" for suspension
    2"+ for larger tires (33's)
    1"+ for larger rims (if your running TO w/16" OEM)
    = 9" in total gain in height...
    35" should give you around 11" of total height gain...
  3. Jul 12, 2010 at 1:01 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    the rims wont change your height, its the tires. 33's will be around 2 inches bigger, but will only give 1 inch of lift because it's a circle, and the bottom half will add to your clearance. add that to the 6" lift and you'll have a little over 7" of lift. so you will be cutting it very close.
  4. Jul 12, 2010 at 1:01 PM
    clintonjeffries
    Clinton
    Wenatchee, WA
    Ok thanks, I'll see how much clearance I would have if I went worse case (or best depending on how you look at it) scenario, if I added 9" assuming I go with 33's
  5. Jul 12, 2010 at 1:06 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    disregard the 9" proposal.....you should be looking around 7".....6 for the lift and 1 for the tires
