6.5 quarts of oil in a 3.4?
Discussion in '1st Gen. Tacomas (1995-2004)' started by smirk, May 19, 2016.
  1. May 19, 2016 at 10:56 AM
    smirk
    smirk [OP] Well-Known Member
    I just had my oil changed. I bring along 6 quarts of Mobil 1 5W-30, and a new OEM oil filter for my 2002 3.4. The shop I go to charges just little enough ($20..) that it's worth it for me to take it there and not deal with doing it myself. But today they told me it needed 6.5 quarts of oil?
    Has anyone ever had to put 6.5 quarts of oil in their 3.4? I can't figure out how they needed 6.5.
    Last time they rotated my tires they lost one of my lug nuts and put a rusty one on in its place. I might be over this place.
  2. May 19, 2016 at 12:03 PM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    A 3.4 (4x4) should only need 5.5 qts. with a new filter.
    12TRDTacoma likes this.
  3. May 19, 2016 at 12:04 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    5.5 quarts, check the dipstick
  4. May 19, 2016 at 12:06 PM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Hey Smirk,
    I have '03 Tacoma PreRunner with the 3.4 (135,000 miles). I've changed the oil/filter on it since new and I've never put more that 6 quarts in.
    Like they said above..about 5.5 quarts
  5. May 19, 2016 at 12:08 PM
    smirk
    I know it's 5.5 from first hand experience. Can't figure out how they needed an extra quart. I haven't checked the dipstick yet ... :cool:
  6. May 19, 2016 at 1:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Ask then how they came to determine this. If it with the dipstick level, you can verify for yourself if it is reading low.
    FWIW, the owners manual says 5.5 but 6 will not over fill it. I always put the full 6 in. 6.5 would put it over the full mark on my dipstick.
    DustStorm4x4 likes this.
  7. May 19, 2016 at 4:14 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    they just want an extra quart of oil for free :D
  8. May 19, 2016 at 5:33 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    No way, manual calls for 5.5 but I put the full 6 in, brings it right up to the full mark. I can't stand it being below that like it is with 5.5 lol and it's never hurt anything dumping the whole 6 in but I'm pretty sure 6.5 would be a bad idea in the long run for your head gaskets.
  9. May 19, 2016 at 6:04 PM
    smirk
    They actually gave me the remaining half of the 7th quart ...
    And the results are in. .. drumroll please:
    The all-telling dipstick confirms there is an extra quart of oil in my truck.
    What do I do now? Take it back to the shop?
    Stick a hose down in the pan and pull a quart out with a syringe? And then maybe take the extra quart back to the shop?
    :frusty:
  10. May 19, 2016 at 6:10 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Take it back and show the guy that said it needed 6.5. He will proabably tell you it is fine and wont hurt anything.
    I would get a little messy pulling the plug and putting it back in a couple seconds later. Then top off as needed and never go back to that place.
  11. May 19, 2016 at 6:12 PM
    CodeSeven
    Serge.
    Coachella Valley
    you may be able to get a syringe in the dip stick tube and pull some out. just need a thin tube.
    or you could stick an air hose in your filler cap and blow some extra oil out the tube
  12. May 19, 2016 at 6:22 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Sounds like they lost some of your oil as well. Hopefully they didn't putrusty oil in its place.
  13. May 19, 2016 at 7:24 PM
    smirk
    I'm going to stick some 1/8" clear tube down that hole, use my lungs to pull a siphon/vacuum, and drain a quart into a bucket.
  14. May 21, 2016 at 8:45 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Find another shop. The folks at the one to which you went only give a shit about your money. I wouldn't even bother wasting my time to talk to them 'cause it won't do any good.
  15. May 21, 2016 at 9:49 AM
    NM Lance
    NM Lance Well-Known Member
    Get a shop vac, put a rag over the hose and have someone hold suction where you add oil. As they are doing this pull the drain plug, have them remove the vacuum for 8 seconds, put the vacuum back on the filler, then put the plug back in. No mess.
  16. May 21, 2016 at 10:07 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I did an oil change on a 3.4 Taco recently and if I recall correctly I think I used 6 quarts to fill it to the full mark. It seemed a bit weird to me because the capacities chart indicated 5.5, but it filled it to the full mark so I wasn't going to argue with physical indications. Most likely the filter took the other .5 quarts in my case. Anyways, 6.5 sounds like its over. Depending where it marks on the dipstick, if its a bit over you will be okay. As long as you aren't like 3 or 4 quarts over the full level it won't come gushing out from your seals. Lol. Check the level and do what you feel you must if it bothers you. Best of luck.
  17. May 21, 2016 at 10:54 AM
    MoonCrawler
    MoonCrawler Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
    Mine takes 6 quarts flat. If for some reason, they went a little over (spill, etc) and had to crack a new bottle, they would round up and charge a half quart, even if they only used .10 quarts.
    Even so, it's much easier to do it yourself, then deal with a rusty lugnut or begin overcharged. And then, you don't have to worry about anything and your neighbors think you are cool because you're crawling around under your truck looking manly.
  18. May 21, 2016 at 12:12 PM
    Mush Mouse
    mush
    2013 SR5
    5.5 quarts fills it perfectly with new yzzd3 filter, no ifs ands or butts about it
  19. May 21, 2016 at 12:44 PM
    MoonCrawler
    Sacramento, CA
    I've owned 4 different 3.4L Tacomas (4x4). 5.5 has always shown on the low side (though still in range). 5.9 is perfect but I just put in 6 and call it done. It's still shows in the target range. I only use Toyota filters.
    Not disputing people, just reporting my experience.
    The FSM isn't always correct. For example, it says an Auto Trans drain and fill will yield 2.5 quarts. However my own experience and countless threads on the subject have found it's 3.9 or 4 Quarts. Sometimes things are just printed wrong.
