5w30 oil for the 2gr-fks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jun 7, 2023.
  1. Jun 7, 2023 at 7:17 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Any of you guys running 5w30 oil in your v6? Any noticeable difference negative or positive ?
  2. Jun 7, 2023 at 7:24 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I use 5w30 in mine. Has worked fine. The supposed reason for 0w20 is gas mileage. Before I moved to Knoxville my mileage was 22 to 24 in the Arizona mountains.
    Gfenza89[OP] likes this.
  3. Jun 7, 2023 at 7:26 PM
    Gfenza89
    Running 5w30 it was that high?
  4. Jun 7, 2023 at 7:29 PM
    azreb
    azreb Geezer
    TN
    Yep.
  5. Jun 7, 2023 at 7:40 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    You can run pretty much anything you want from 0W-20 to 15W-40, provided you don’t take 10W-30 below 0°F or 15W-40 below 10°F. The various viscosities of oil are nowhere near as drastically far apart as they sound.
  6. Jun 7, 2023 at 7:43 PM
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    I did my first oil change at 5k miles with synthetic 5w30 (because it’s what I had on hand). Seems like a minuscule difference, but I swear it’s the slightest bit more sluggish.
    I will be going back to 0w30 when Costco puts their synthetic back on sale and I hit 10k miles.
  7. Jun 7, 2023 at 7:44 PM
    BLtheP
    Plano, TX
    If it’s sluggish on 5W-30, it’s going to be sluggish on 0W-30.
    Murd3rd, cookiedough and Phlogiston like this.
  8. Jun 7, 2023 at 7:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This thread is bound to be thrown off course soon enough.
    How do you like Knoxville?
    RustyGreen and Chew like this.
  9. Jun 7, 2023 at 8:03 PM
    Wwjvd
    Jimmy
    Haha, Thanks for your thoughts on my perspective. I should have known I couldn’t share an oil opinion!
    By Friday, folks will be recommending mineral oil.
    99TacoDriver and TnShooter like this.
  10. Jun 7, 2023 at 8:06 PM
    BLtheP
    Plano, TX
    They are the same operating viscosity. If you’re going to go back due to sluggishness, you need to go back to 0W-20. It’s not an opinion….0W-30 and 5W-30 are for all intents and purposes the same except for when they’re cold.
    and actually…..mineral oil is a perfectly fine choice.
    Murd3rd, NorrinRadd and cookiedough like this.
  11. Jun 7, 2023 at 8:10 PM
    Wwjvd
    Jimmy
    See Link ——> https://www.tacomaworld.com/threads/5w30-oil-for-the-2gr-fks.803713/#post-28811516
  12. Jun 7, 2023 at 8:19 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    What's wrong with the recommended 0W-20?
    Tacopycho, RustyGreen, Chew and 4 others like this.
  13. Jun 7, 2023 at 8:22 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Because 0W-20 is for gen Z kids. Us old timers use 20W-50 or 15W-40. :thumbsup:
    ceh527, ricco333, RustyGreen and 3 others like this.
  14. Jun 7, 2023 at 8:23 PM
    TnShooter
    Deogee
    STOCK
    You’ve been a member for almost 8 years now.
    You should know by now.
    The oil.
    The oil is what’s wrong with it.
    OP, I’m sorry man.
    But I really can not help you.
    Never owned a 3.5 or ran the oil you’re asking about.
    But I can almost bet, you’ll be more confused about what to use by the time this thread reaches the weeks end.
  15. Jun 7, 2023 at 8:41 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    If you don't run 0W-20 you'll be placed on an FBI watch list where you'll eventually get picked up in the cover of night and taken to a secret factory in siberia where you'll be forced to run tests on Tacoma oil samples for the rest of your life.
    oil is serious shit.
  16. Jun 7, 2023 at 9:08 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Always have. It's getting hard to find 5w-30 in conventional oil. I run synthetic in my RV because that what the guy who owned it before me used.
    I'm old school and like conventional oil
  17. Jun 7, 2023 at 11:54 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    i use 5w 30 and also use 91 oct just to feel warm and fuzzy inside:spending:
    D.A.S. Taco likes this.
  18. Jun 8, 2023 at 12:05 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Xw-30 isn’t really all that different from 0w-20. Keep in mind though, most wear occurs at engine startup. All other things being equal, lighter oils better protect earlier at startup. You can make up for this somewhat by selecting extremely high quality oils.
    Go with Pennzoil Ultra Platinum 5w-30 or Amsoil 0w-30 if you want a bit more viscosity at operating temp while also maintaining pretty good low temp performance.
    ScrippsRanch67 likes this.
  19. Jun 8, 2023 at 3:40 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    I put in the 5w-30 from Costco. No difference at all.
  20. Jun 8, 2023 at 5:02 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    According to the car care nut (Toyota service) you should use the oil that is stamped on the filler cap. Why wouldn’t you follow what the Toyota engineers state. I am not saying it won’t work but a lot of things will work but don’t follow recommendations.
    TacoTime55 likes this.
