5w-20 VS 5w-30
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dutd33, May 22, 2023.
  1. May 22, 2023 at 11:50 PM
    dutd33
    dutd33 [OP] Well-Known Member
    **EDIT **
    Sorry, I forgot to mention that we have a four cylinder 2009 Tacoma.
    Hi Everyone,
    We have a 2009 Tacoma and the specs call for 5w-20. If we put 5w-30 in it will that be OK? I've read different answers on this topic.
    Thank you in advance!
  2. May 23, 2023 at 3:06 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    It'll be fine. My 2008 V6 used 5w-30.
    dutd33[OP] likes this.
  3. May 23, 2023 at 3:21 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    The question is, "did Toyota change the internals of the engine when they began specifying 5W-20 from 5W-30, or are they just using the thinner oil to keep up with EPA laws.?
    I have always felt the EPA is the reason for lighter oil to get better gas mileage. Maybe at the sacrifice of a little engine longevity.
  4. May 23, 2023 at 3:34 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You have the 4-cyl? 5W30 is fine. Fuel economy when cold is reduced by about 1mpg, that's about it.
  5. May 23, 2023 at 8:03 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    30 weight will be fine
    dutd33[OP], TnShooter and Steves104x4 like this.
  6. May 23, 2023 at 9:25 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Once the Dual -VVTI 4.0 came out Toyota went to 5w-20. I don’t know the real reason. But I do know that a lot of people don’t change their oil as often as they should. The cam phasers are oil operated. Cold oil is thick, so is severely neglected oil. Thick oil doesn’t flow well, and this can cause timing issues (codes).
    And it probably does help MPG a bit.
    Again, this isn’t why they went to 5w-20.
    It’s just my guess.
    I do know if you you use 5w-30
    In a 0w-16 engine, it will throw a code.
    There was a Toyota tech on YouTube that posted about it. Evidently the quick lube shop used the wrong oil.
    Never the less, the 4.0 and 2.7 are not at all picky about oil. So you won’t have tot worry about that in these engines. Not unless you run 90w+ gear oil or something. :rofl:
  7. May 23, 2023 at 10:08 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I alway say stick to the oil the manufacturer reccomends, they designed the engine and specified oil based on that design and the bearing clearances within.
    There's no real benefit to running an oil weight different than specified.
    5W-30 for the 4.0L and 5W-20 or 0W-20 (depending on year model) for the 2.7L
  8. May 23, 2023 at 10:31 AM
    TnShooter
    Deogee
    STOCK
    I agree.
  9. May 23, 2023 at 10:47 AM
    Hoff
    Hoff Well-Known Member
    Engines are made to function with different oil viscosities. Picture this. Your Tacoma towing a motor home in Florida in mid summer vs that same truck travelling down highway empty in Alaska in mid winter. The viscosity of the oils in these situations would be drastically different.
  10. May 23, 2023 at 10:57 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's why we use multi-viscosity oils today vs straight viscosity oils that we used to use as they are more stable with temperature changes.
    Some engines do reccomend different oil weights for different climates but this is becoming less common in modern engines as they have very tight tolerances and operating temperature regulation.
  11. May 23, 2023 at 11:04 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I was going to make a comment about the cooling system keeping the internals at a constant, set temperature. But Im more interested in why you picture a Tacoma towing a motor home? :eek:
  12. May 23, 2023 at 11:15 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    The question is why do you want to use a different viscosity than what the manufacturer
    recommends? What do you think you are going to accomplish by using viscosity different than the factory engineers state should be used? I doubt the viscosity you suggest will do any harm but I am not an automotive or petroleum engineer or expert. I doubt anyone here is.
    Stemmy, SR-71A and Dm93 like this.
  13. May 23, 2023 at 12:27 PM
    TnShooter
    Deogee
    STOCK
    I am certainly not an expert.
    But I have used a different viscosity.
    Mostly because what I had on hand is better than not enough oil or, nothing at all.
    I have used 5w-20 motorcraft in my 4.0.
    I am not advocating this, just stating I did it.
    Sprig[QUOTED] and dutd33[OP] like this.
  14. May 23, 2023 at 2:20 PM
    dutd33
    Thank you for taking the time to respond. I believe your V6 calls for 5w-30. I've read some of the threads on this forum that 5w-30 will cause our 4-cylinder Tacoma to work harder and thus lead to unintended engine wear. Any truth to this?
    My apologies as I should've mentioned that we have a four banger.
  15. May 23, 2023 at 2:24 PM
    dutd33
    That's a great question!
    We have some left over bottles of 5w-30 when my uncle bought a new vehicle (a Honda). He now uses 0w-16 or something like that.
  16. May 23, 2023 at 2:25 PM
    dutd33
    Motocraft Synthetic Blend for the win! J/K, thanks again!
    TnShooter[QUOTED] likes this.
  17. May 23, 2023 at 6:55 PM
    1medic
    1medic New Member
    2011 TACOMA TRD
    0w or 5w/20 vs anyW/30 is fine. Toyota allows for anything up to 20w50. However, you won't find any US manual stating what Toyota allows all over the world. All the low grade oils started in the US for fuel milage reasons. All the light weight oils have come along way in the past 30 years. Run whatever you want. You could do a deep dive into bobistheoilguy.com and do oil analysis to see what works best in your motor. I run 5w40 in all my rigs. Here's a link to the Hilux 2.7L oil spec. https://toyota-club.net/files/techdata/ttx/hilux_20w.htm
    Don't over think it as long as you keep to a consistent interval and check your oil often to make sure your not burning any..
    Jeff Lange and Hoff like this.
  18. May 23, 2023 at 7:02 PM
    TnShooter
    Deogee
    STOCK
    I agree.
    Keep it simple.
    Twist the lid, turn the bottle, pour it in.:thumbsup:
  19. May 23, 2023 at 10:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Ah shieeet another oil thread gone wrong
    SR-71A likes this.
  20. May 24, 2023 at 2:22 PM
    DeepFriedTaco
    DeepFriedTaco Well-Known Member
    Teddy the Taco
    2021 MT OR Taco
    On the oil topic what is Toyota oil anyway? They are not producing their own oil so whose product are they repackaging?
