5VZ-FE - cam pulley Torque (217lbs!?) Bent my Cam holder tool! What to use?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ArizonaBrian, Oct 30, 2021.
  1. Oct 30, 2021 at 7:20 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I would inspect the bolt for damage.
    Superdave1.0 likes this.
  2. Oct 30, 2021 at 7:21 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Checked multiple sources/websites and even a reputable YouTube video. It's 81 ft lb for camshaft sprocket bolt 100% sure.
    JudoJohn likes this.
  3. Oct 30, 2021 at 7:26 PM
    Kiloyard
    Phoenix, AZ
  4. Oct 30, 2021 at 7:28 PM
    ArizonaBrian
    ArizonaBrian [OP] Well-Known Member
    Yep, there it is... I don't know whether to laugh or cry. Maybe both. LOL
  5. Oct 30, 2021 at 7:28 PM
    Superdave1.0
    SoCal
    Just be happy the bolt didn't snap off. :fistbump:
  6. Oct 30, 2021 at 7:30 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Here you go out of the 2000 Toyota FSM
  7. Oct 30, 2021 at 7:31 PM
    ArizonaBrian
    Well, thanks folks. Wish I had a picture of the whole setup... a 3 ft. long cheater bar on my homemade cam holder tool one side and a 250# torque wrench on the other. I'm such a baffoon!
  8. Oct 30, 2021 at 7:32 PM
    Kiloyard
    Phoenix, AZ
    I've been there, @ArizonaBrian. By the end of my timing belt and valve cover job my brain was fried.
  9. Oct 30, 2021 at 7:33 PM
    ArizonaBrian
    Trust me - I'm ecstatic!
    Good night gents, thanks for the info!
  10. Oct 30, 2021 at 7:34 PM
    ArizonaBrian
    Valve covers are next. :)
    I've done timing belts before on other vehicles and was making good time until this stupid episode.
  11. Oct 30, 2021 at 7:37 PM
    ArizonaBrian
    Just noticed your in Phoenix - Surprise here. At least today was a decent day temperature wise - was putting this job off until it cooled down. Usually when vehicle works is required it's a 114F out and we have dirt for a drive way. Nothing like rolling around covered head to toe in dirt, sweat and blood and it's boiling outside.
    DrZ and Kiloyard[QUOTED] like this.
  12. Oct 30, 2021 at 7:46 PM
    Kiloyard
    Phoenix, AZ
    Hah! Yeah I save the big projects for winter, too. ;)
  13. Oct 30, 2021 at 7:47 PM
    ArizonaBrian
    Actually was just now thinking a cam holder may not even be necessary - tighten up the cam bolts as good as you can, install the timing belt and tensioner then put a cheater on the crank and lay it over the frame then tighten the bolts. I wouldn't think 81# would be enough to jump the belt - 217# yes LOL - 81? Any thoughts on that procedure?
  14. Oct 30, 2021 at 7:55 PM
    Kiloyard
    Phoenix, AZ
    I like using the holder, but since yours broke it's worth a try! It's a pretty beefy timing belt. Any risk of damaging the tensioner like that?
  15. Oct 30, 2021 at 8:13 PM
    #35
    Superdave1.0
    SoCal
    I wouldn't risk it, but it might work just fine.
    I would try using the old timing belt. Wrap it around the pulley, then double it over the idler bearing in the center. Use vise grips to hold the belt together. Or just buy the proper tool.
  16. Oct 30, 2021 at 9:46 PM
    #36
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    This is more or less what I did, but just with the cams. Local holders didn't fit. Didn't have the patience or budget to order a tool I'd use once. I used a torque wrench, breaker bar, pry bar, and adjustable wrench.
    But you'd need to have marked the pulleys and belt on both sides first.
  17. Oct 31, 2021 at 7:22 AM
    #37
    Bivouac
    After torquing the bolt that tight.
    I have been thinking will you be able to get a true torque reading.
    The fact the bolt or cam did not break those threads really have had to have stretched !!
    *** Please just what year FSM did that wrong number come from??
    It could save many people from the same mistake.
  18. Oct 31, 2021 at 5:54 PM
    #38
    ArizonaBrian
    It's the (c) 2002 edition that's floating around online. The service specification section has it wrong but it's correct in the installation and component sections.
    Bivouac[QUOTED] likes this.
  19. Jul 15, 2022 at 9:24 PM
    #39
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    2003 Tacoma TRD 4dr Prerunner 4wd conversion
    6”rough country lift, 35” bfg mud terrain, step bars, home made solid 5" bull bar frame mounted top and bottom with gussets ( used an excavator to completely suspend the truck in the air held only by the bull bar), 180k, no rust, no leaks, no cel's, no issues. 4wd conversion with front and rear e-lockers.
    Camshaft gear bolt is 81.. mmkay, that would explain why i snapped both off in the head.. ok. Good to fu$&@ing know.. my manual said same torque spec as crank see rite hur..
    now tell me where you got the 81 number from.. cuz thisn seems to be updated witg the new 217 ft lbs modified spec..
  20. Jul 15, 2022 at 9:44 PM
    #40
    ArizonaBrian
    All the info is in the previous posts.
