5th Wheel Trailer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cchar, Jun 25, 2021.
  1. Jun 25, 2021 at 6:40 PM
    cchar
    cchar [OP] Member
    St. Albert, Alberta
    Tacoma
    I have 2012 tacoma, was wondering if anyone with the same has pulled a 5th wheel trailer?
  2. Jun 25, 2021 at 8:24 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  3. Jun 25, 2021 at 8:30 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Not a real 5th wheel travel trailer if that's what you mean.
    Depending on trim/payload some Tacomas can handle the lightweight Scamp 5th wheels.
    TnShooter and ColoradoTJ like this.
  4. Jun 25, 2021 at 8:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Jun 25, 2021 at 9:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I've seen tacos with goosneck hitches before but never a 5th wheel, those are generally reserved for 3/4 ton and up trucks.
    Unless you have something light that happens to have a 5th wheel or just need to move a 5th wheel around off highway there would be no point it having a 5th wheel hitch in a Tacoma, it's just not a big enough truck to safely tow one.
    Grey 2015 likes this.
  6. Jun 26, 2021 at 9:14 AM
    cchar
    cchar [OP] Member
    St. Albert, Alberta
    Tacoma
    Reason i ask is that my taco has a tow package on it and should be able to tow 6500 and some 5th wheels are around that weight.
  7. Jun 26, 2021 at 9:21 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    https://www.scamptrailers.com/showroom/19-deluxe-trailer
    https://escapetrailer.com/escape-5-0-specifications/
    Those are the only two currently produced 5th wheel travel trailers I know of that the Tacoma can pull. You'll be best off towing a trailer with a maximum weight of around 5000lbs wet, the Tacoma is not a good tow vehicle. It is adequate, but if you're going to tow with any kind of frequency and any kind of weight then you should buy a larger truck.
    6 gearT444E and Dm93 like this.
