5th gen 4Runner suspension on 2nd gen Tacoma
Discussion in 'Suspension' started by Jarhead4.0L, Mar 4, 2024.
  1. Mar 4, 2024 at 9:50 PM
    Jarhead4.0L
    Jarhead4.0L [OP] New Member
    2006 trd sport
    So I accidently bought some second hand billstien 6112 from a 5th gen 4runner for my 2nd gen tacoma without doing research but now I found out that the lower bushing that connects the LCA to the shock is bit wider than 2nd gen taco, but it can be shaved down a mm or 2 and should fit right in? Has anyone done this swap even if it's regular suspension from 5th gen to a tacoma 2nd or 3rd gen?
  2. Mar 5, 2024 at 6:41 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    That's not uncommon to do, to retrofit it. Just make sure the coils aren't too soft or short, as a Tacoma needs stronger and taller ones than a 4Runner to get the same lift height out of them.
  3. Mar 5, 2024 at 9:24 AM
    Jarhead4.0L
    2006 trd sport
    Yeah the ones I bought came with 700lbs eibach springs as well and they are on 7th circlip setting for both shocks
  4. Mar 6, 2024 at 3:01 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Yes, take measurements. The lower bushing will have to be slightly modified.
  5. Mar 12, 2024 at 4:03 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    You can likely just bend the ears more open on the LCA to squeeze them in. I have done it before. Hammer and pry bar.
