5100s with 6" Fabtech lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2002Taco_Tacoma4x421, Dec 28, 2021.
  1. Dec 28, 2021 at 12:07 PM
    2002Taco_Tacoma4x421 [OP] Member
    2002 Toyota Tacoma 4x4
    Alright guys and gals I'm new to this forum so I need some help with a Tacoma I just bought. It has a 6 inch fabtech lift but I want to change the rear shocks because everytime I hit a bump I can feel it hit hard. So I'm thinking of running 5100 bilstein shocks but can't find them anywhere on the websites. Do you guys think that's a good idea to run those with the fabtech suspension?
  2. Dec 28, 2021 at 12:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tons of websites carry 5100s.
    Where are you looking exactly?
    Did you figure out your shock length needs? I ask because I'm sure that kit uses big ass blocks in the rear.
  3. Dec 28, 2021 at 12:14 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    This.
    5100's are fine more many applications and ride pretty nice for the price, just make sure you get the correct length. Measuring the collapsed and extended length of the shocks currently on there will be a good first step.
  4. Dec 28, 2021 at 12:17 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Firstly, the drop bracket lifts aren't well favored by many who actually wheel and the long-term support from the 4 wheel industry as a whole isn't that great. That being said, if you are looking for something like "5100s for a 6" Fabtech lift", you're not going to find much. But you can remove one of your existing shocks and measure the extended vs collapsed length of the shock, and then get 5100's which match that. But you'll want to talk to a dealer and let them walk you through that process.
    When you say "hit" do you think that the current shocks are just blown? or do you think you should maybe inspect things and see if a larger bump stop might help the situation as well?
    Mark77 likes this.
  5. Dec 28, 2021 at 12:17 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    5100s are sold out on a lot of sites, probably what he meant. I just checked a couple places and it showed not in stock
    probably a big container full of 5100s sitting off the coast lol
    Speedytech7 and whatstcp like this.
  6. Dec 28, 2021 at 12:18 PM
    I've been on bilstein shocks website, toytec, and just random websites on Google. honestly I just thought it was 6 inch shocks. I'm new to all this suspension so if you guys can point me in the right direction would be great. I actually have it at the mechanic's right now getting some things done to it. I could ask them if they can let me know the length of the shock so I know what i actually have to look for
  7. Dec 28, 2021 at 12:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If he's looking for Tacoma-specific shocks then I can believe it.
    Shockwarehouse can easily narrow down to some part number variants that'll work for his application, once he finds out length needed. Match the valving similar to that of what's found on a Tacoma, and you're set.
    eon_blue[QUOTED] likes this.
  8. Dec 28, 2021 at 12:22 PM
    eon_blue
    Azusa, CA
    shoot I should pull my 5100/881s out of storage and list them for 4x what I bought them for
    gsubioguy and Kwikvette[QUOTED] like this.
  9. Dec 28, 2021 at 12:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Should post those Fox 2.0 I gave ya for 8x as much cause you know, Fox :burp:
    gsubioguy and eon_blue[QUOTED] like this.
  10. Dec 28, 2021 at 12:25 PM
    Andy, when I say it "hit" it could be that the shock is blown. It's like a dry hit but only my right rear shock. I took it into the shop so they can take off an extra leaf that the last owner had put on it and get that all inspected make sure it's good. What do you mean a larger bump stop?
  11. Dec 28, 2021 at 12:27 PM
    eon_blue
    Azusa, CA
    8x free is still free :burp: Well I guess we did trade lol
    But those are gonna go on whenever I get around to sending the Icons off for rebuild
  12. Dec 28, 2021 at 12:27 PM
    Andy, I will look into that though. I want to be able to drive my Tacoma up into the forest without a problem but also have it as a daily
  13. Dec 28, 2021 at 12:29 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Drop bracket lifts can wheel just fine.......
  14. Dec 28, 2021 at 12:33 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    wait... a previous ower put 6" lift blocks and an AAL? Good lord.
    It sounds like you need to do some reading up of suspension components, before making any more decisions.
    Bump stops in general are placed between suspension components and the frame to soften the contact and limit the travel of the suspension. If your bump stops aren't doing their job correctly, that could be a thing, but in the rear, it would mean that the suspension has to compress all the way.. I'm not sure how likely that is just driving around on the street...
    In the opposite direction though, if the axle is dropping more than the shock has the capacity, then you might feel the suspension bottom out, in which case, you actually want limit straps to keep the axle within range of the shock (or shocks with a longer extension... provided that the bump stop is limiting how far the axle can compress up correctly)
  15. Dec 28, 2021 at 12:33 PM
    Thanks man. I'm just new to this suspension thing. I had a 2001 tacoma before this one but it was all stock. Had to sell it for a reason. just bought this Tacoma a couple months ago and just trying make the ride a lot smoother than it is now
  16. Dec 28, 2021 at 12:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    Measuring the existing shock is only of value if the previous install used the correct length shock or some type of shock mount extender.
    Whoever does the measuring needs to know what they are looking at.
    Also, I agree that a DB lift 'can' wheel ok 'most' of the time. However, since there is no actual ground clearance added at the axle lines, the impression of "I have an extra 6" isn't exactly correct.
    OP, since you don't give a location, has the truck lived in salt country? A detailed inspection of the frame for rust is in order if it has, including the areas where the frame was cut out up front to accommodate this particular lift.
    whatstcp likes this.
  17. Dec 28, 2021 at 12:37 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Sure they can. And I didn't say they couldn't. I said they aren't favorable, and that is true. No sense in increasing your COG without gaining clearance under the axles.
  18. Dec 28, 2021 at 12:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Stock trucks can too
    Glueman[QUOTED] likes this.
  19. Dec 28, 2021 at 12:43 PM
    Yea man I'm gonna have to do a lot of reading about it all. Yes he did. I think I might have pictures of my suspension so I can show you on here. Oh ok all that makes sense now.
  20. Dec 28, 2021 at 12:44 PM
    02hilux
    Planet: EARTH
    I bet the few FT DB lift dude I know wheel harder than most mall rated tacoma. I've seen nice and shiny fox, ads, kings tacoma do nothing but travel through bypass instead of obstacles.
