5 tire rotation with TPMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blueberry.Taco, Sep 22, 2020.
  1. Sep 22, 2020 at 5:25 AM
    Blueberry.Taco
    Blueberry.Taco [OP] blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    Hi everyone,
    did a quick search but didn't come up with the capability of the "tpms reset" button.
    I was looking to add a tpms sensor to a 5th (spare) wheel/tire and rotate that spare along with the other 4 tires (these are all non-stock wheels/tires), but starting to get the feeling that the TPMS system only memorizes 4 sensors at a time?
    in which case I need to get an OBD tool for 'relearning' a new tpms sensor each tire rotation?
    or will the 'tpms reset' button suffice for adding in a 5th sensor, but it is sometimes hanging off the bumper as a spare?
    dnguy77 likes this.
  2. Sep 22, 2020 at 6:02 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I believe that the truck has only 4 active spots and the button only relearns position after rotating those 4 based on this thread.
    I still went ahead and got a 5th OEM wheel and 5th TPMS and I plan 5 tire rotation when I buy my next set of shoes.
  3. Sep 22, 2020 at 6:13 AM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    Great question, I plan to get some used wheels, extra wheels to the trailer and rotate the spare in, why waste a perfectly good tire by letting it sit as a spare.
  4. Sep 22, 2020 at 6:23 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    On my 2nd gen that also only holds 4 spots, I have to plug in the tool to reprogram the TPMS to know which 4 sensors to listen to when I rotate my 5th wheel in. The reset button under the dash just resets the “ok” pressure of the 4 current sensors it is reading. Reprogramming only takes like 5 minutes with the right tool.
  5. Sep 22, 2020 at 6:33 AM
    NMBruce
    SW Colorado
    Which tool?
  6. Sep 22, 2020 at 6:47 AM
    megillet
    Mark
    Atlanta, GA
    Autel MaxiTPMS TS501 TPMS Service Tire Pressure tool Car Diagnostic Tool https://www.amazon.com/dp/B00BHCFNTS/ref=cm_sw_r_cp_apip_1Vqvi7rCR438n
    I got it on Amazon as a Lightning Deal so it only cost me $111. After you rotate, you can walk around and read each sensor, store it to this, then plug it in and program those sensors to the truck. Super easy.
    NMBruce[QUOTED] likes this.
  7. Sep 22, 2020 at 8:22 AM
    Blueberry.Taco
    Ryo
    SE MI
    thanks for the info, unfortunate that it requires a separate tool, oh well.
  8. Sep 22, 2020 at 5:25 PM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    I've always done five tire rotations on 4x4s with a matching tire and I was thinking of doing the same, but bummer that one needs a tool. I was surprised that my 2019 OR only came with a matching spare tire? That's just a waste of a tire... :(
