5-tire rotation pattern
Discussion in 'Wheels & Tires' started by locster, Mar 11, 2015.
  1. Mar 11, 2015 at 1:34 AM
    locster
    locster [OP] Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I have matching spare that I'd like to work into the rotation. I found this illustration from Tirerack.com. Anyone else follows this or have any other suggestions?
  2. Mar 11, 2015 at 3:36 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Just got 5 new tires 4k miles ago.....I'll be doing the rotation from the first pic. Seems easier to remember LOL
  3. Mar 11, 2015 at 4:03 AM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    I initially did the rotation on the right with my Jeep. I actually printed the picture out and laminated it, kept it in the console with my tire pressure gauge and valve stem tool.
    Towards the end my jeep days, I think I just rotated counter clock wise. It was quick and easy to do in the garage or driveway with just one floor jack. Pull the spare off, walk to the right, continue until you're remounting the spare. Additionally if I got lazy and had a shop rotate my tires it was easier to explain the rotation pattern. In my opinion it really doesn't matter what pattern you use, just stick to it so the tires all hit each positions equally, and rotate them frequently.
    The main thing those other rotation patterns do is prevent you from running a tire up front for two cycles, where they usually get the most abnormal wear. Rear wheel drive rigs normally flatten and smooth the tires back out on the rear axle. I guess if you're seeing more abnormal wear up front, one of the pictured rotations may keep your tires in better shape and riding more smoothly.
