5 tire rotation - Are onto this?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OZ TRD, Dec 14, 2020.
How do you manage your Taco's tire rotation?
  1. 4 tire rotation only - I ignore the spare
    116 vote(s)
    69.5%
  2. 5 tire rotation - I have a real wheel for my spare ad it is included n the rotation
    34 vote(s)
    20.4%
  3. I do not rotate - Wheeling keeps me on perpetually new tires
    3 vote(s)
    1.8%
  4. I wear out the rears and then replace those. I replace the fronts in due time
    0 vote(s)
    0.0%
  5. What is tire rotation?
    1 vote(s)
    0.6%
  6. I prefer Burritos
    13 vote(s)
    7.8%
  1. Dec 14, 2020 at 2:03 PM
    OZ TRD
    OZ TRD [OP] Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Or do you just go with the 4 tire rotation - and ignore the spare in this equation?
    I am new to Tacos... - What happens when you have 4 well worn tires and then you put the spare on? Does this not cause trouble with the 4WD system?
    Maybe event he 2 WD mode in the case that you end up with the new spare in the rear?
    Toyota provided a steelie for the spare, so they are not assuming a 5 wheel rotation by owners...
    So in order to do a 5 wheel rotation, then an additional wheel must be purchased...
    I know my previous AWD vehicles had a tight tolerance of a couple 32nds before the AWD system acted-up. (Toyota Sienna, BMW IX, etc.).
    Are the Tacos more forgiving in terms of different wear between axels (front to back) or side to side?
    Are there any instances of trouble due to different tire wear?
    Thanks!
    TRDSport10, MNMLST and tacotoe like this.
  2. Dec 14, 2020 at 2:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's hard enough to remember the cross-rotation every other time. For me, trying to juggle five tires wouldn't work out for long.
  3. Dec 14, 2020 at 2:08 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Tacomas are not awd. You're good.
    A lot of Tacomas are driving around with bigger tires and little spares.
    Forget your spare, (other than checking pressure)..
    I move them around when I swap winters, front to back back to front.
    TRDSport10, tacotoe and tonered like this.
  4. Dec 14, 2020 at 2:08 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Only ever done 4 tire rotation.
    On my Tacoma and my Rubicon.
  5. Dec 14, 2020 at 2:12 PM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    I have done this for the past 7/8 years (2 cars). Assuming you can source a reasonably priced 5th wheel it makes sense.
    - Easier to rotate: you can just jack one corner at a time
    - if you end up with a ruined tire say 33-66% thru their wear life. You don’t have to think about a mismatched replacement, or just getting a whole new set and forgoing the unused life of the other 3.
    - if you ruin a wheel, you Allready have a replacement (vs ordering and waiting on a new one (assuming it is even available)
    - maybe not so true in our applications. But most spares for passenger cars are rated really bad. Like 55mph or less, 50 miles max. Imagine being out of town, needing a new tire on no notice. (It sucks. BTDT)
    TRDSport10, WarFab Armor and tonered like this.
  6. Dec 14, 2020 at 2:14 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    4. And I barley manage that!
  7. Dec 14, 2020 at 2:14 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    1 to 2, 2 to 3, 3 to 4, 4 to 5, 5 to 1 every oil change... that’s the way I’ve always done it, right or wrong.
    tacotoe likes this.
  8. Dec 14, 2020 at 2:15 PM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    If its wasn't for the TPMS sensor and having to deal with activating the one on the spare tire, I would rotate the spare tire in there. Since I don't have a techstream I ignore the spare.
    I do however have a matching 285/75/16 spare tire
  9. Dec 14, 2020 at 2:17 PM
    Speedbird
    Fort Couch
    2017 TRD-OR
    Forgot to add... (pissed off about it also). Current gen 3 can only save 4 TPMS at a time. So if you want to rotate the 5 th one in. You either have to: tolerate the damn tire red light in the dash, or have access to tech stream. Or pay dealer to reset.
    so for me, this is the deal breaker. This week when I get tires, I’m going with 4 only.
    (Cheap Job by Toyota with this... my 2013 VW and 2008 BMW managed throwing a 5th wheel in the mix no problem)
    Rockefelluh, TheCochese and Anton338 like this.
  10. Dec 14, 2020 at 2:18 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Just front to rear swap is all I ever do on the Tacomas. Yeah the spare is a plain ol steel one. I often wondered what will or would happen if I had to run the factory spare on my wife's truck as its quite a bit smaller diameter. Another vehicle with matching spare wheel and tire I will put in the rotation thing.
  11. Dec 14, 2020 at 2:23 PM
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    Reasons to do five tire rotation:
    Increase the time between tire changes by 25%... that's it.
    Reasons against five tire rotation:
    Fifth alloy wheel costs money.
    TPMS will be wonky since the computer only holds four codes.
    Slightly more complicated rotation procedure.
    Doesn't really make sense when you weigh out the benefits.
    TRDSport10 and cwdog like this.
  12. Dec 14, 2020 at 2:24 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's no problem, except for 4wd use. 2wd and AWD cars come with compact spares. So on the Taco, the open diffs will handle it.
    My method of prep, which would be different if being serious about an extended expedition, is a plug kit on board for the small stuff. The spare is there if needed to limp home to end the wheeling day or whatever. This mainly goes back to my current experience of not really having to deal with any significant punctures in decades. The Taco is my first truck, but wheeling hasn't caused any issues yet.
  13. Dec 14, 2020 at 2:25 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Totes not worth it, especially when your wheels weigh 90 pounds a piece. no thanks
    vicali likes this.
  14. Dec 14, 2020 at 2:30 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    :rofl:understand I'm not always the sharpest knife in the drawer; I fear I might start on this method and not know when to quit...just kidding
    MNMLST[QUOTED] and tonered like this.
  15. Dec 14, 2020 at 2:43 PM
    MNMLST
    Earth
    ‘course if you run your truck to 200k mi this pays for a whole set of tires.....
    tacotoe likes this.
  16. Dec 14, 2020 at 2:44 PM
    MNMLST
    Earth
    ... or disable the maternal light and buy a $5 tire gauge.
    Mark77 and tacotoe like this.
  17. Dec 14, 2020 at 2:46 PM
    Bishop84
    Bishop84 Well-Known Member
    Lots of us northerners have winter tires too, so 8 tires is enough, the spare can stay and rot.
    TurdTaco64, MNMLST and tacotoe like this.
  18. Dec 14, 2020 at 2:47 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    The light stops. I run winters without TPMS and no light unless I drive for more than 20 minutes..
  19. Dec 14, 2020 at 2:47 PM
    Betty.White
    Betty.White Active Member
    2020 White Tacoma TRD Pro
    None (Yet!)
    What if a) your tire is larger than your spare (theoretically 265/70r16 vs 265/75r16) and b) you live 350km from a tire shop? Can you drive that far on a different size tire?
    tacotoe likes this.
  20. Dec 14, 2020 at 2:47 PM
    Anton338
    Anton
    New Jersey
    I don't follow how method of rotation can "pay for" a whole set of tires. Please explain.
