5 lugger: upgrade to 16 inch from 15 inch .. ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fchen7, Nov 23, 2011.
  1. Nov 23, 2011 at 5:37 PM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    Bushwacker pocket style fender flares
    I got this information from a very useful post in this forum.
    Base Steel Wheels: 15x6, +40 mm offset, ? backspacing, 5x4.5" bolt pattern, ? hub bore, ? lbs
    My Taco is 05 basic silver access cab 4 cylinder 5 lugs 15 inch stock rims, no mod yet. I like to move up to 16 inch 5 lug wheels. And eventually get 235/70/16 or 235/75/16 highway tires. My questions is: how to look for 16 wheels that will fit my car ?? 16x6 ? 16x6.5 ? 16x7 ? And is the +40mm offset a required spec when i look for a wheel ?? If the stock suspension is setup for +40mm offset, then i dont want to mess with it and i would only look for +40mm offset. Or am i not making sense ?
    235/70/16 vs 235/75/16. It's a difference of about 1 inch. How will you pick ? I am going for the look. I need to mention that the truck is getting the Bushwacker pocket style fender flares painted and install this week.
    thanks fo any comment .... I am learning so much about tires and rims the last day or two. But i need more ....
  2. Nov 23, 2011 at 5:40 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Go to TireRack and put your vehicle in there and it will show what will fit, I had 18"s on my truck when it was like yours. Welcome to TW!
  3. Nov 23, 2011 at 5:46 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Here's a good website for comparing rims to fit on your truck.
    http://www.rimsntires.com/specs.jsp
    It gives a good visual for comparing offsets/backspacing between rims. I'm not sure exactly what would fit but 15x8 w/4.5" backspacing has been known to fit so I would think a 16x8 4.5" backspacing should fit too. :notsure:
    BTW the hub bore is 60.1 mm.
  4. Nov 23, 2011 at 5:53 PM
    fchen7
    fchen7 [OP] Member
    05 Base AC 4 Cyl
    ok, 4.5" backspacing .. is that also called lug pattern ?
    and there is also hub bore of 60.1mm...
    i think there should be a class for this, some kind of certificate ... :)
    thanks , i will check out that web site
