5 lug wheel options??
Discussion in '5 Lug' started by Clearwater Bill, Oct 20, 2014.
  1. Oct 20, 2014 at 6:04 PM
    Clearwater Bill
    Clearwater Bill [OP] Never answer an anonymous letter
    Billy
    Largo Florida
    '13 base w/OE 15x6 wheels. But even my '98 Sonoma had 15x7!
    I'd like to upgrade to a 15x7 or possibly a 16x7 with the correct offset to match the position and steering geometry I have now. So nothing radical, just a bit bigger.
    Is there anything out there in the Toyota family that fits the bill?
    Are there wheels from other marquees proven to work?
    Barring some great looking OE wheel, I kinda like the idea of a steel wheel with a enough of a lip to use trim rings and some dog dish or moon lug covers. Kinda old school hot rod/sleeper muscle. Examples out there?
    TIA!
  2. Oct 22, 2014 at 2:54 PM
    ihatecorollas
    ihatecorollas Active Member
    WI
    Icon Coilovers with bypasses. Total Chaos UCA's. Kender Klever At2's
    I'm planning on going with some basset wheels for my next wheel purchase. Steel, you can order width, offset, back spacing, size, everything. They are also hella cheap.
  3. Oct 24, 2014 at 9:56 AM
    Inmand09
    Inmand09 ArkLaTex Offroad Vice President
    David
    Granbury, TX
    ‘18 White TRD Offroad
    3" Suspension Lift, Skids, Sliders, Ditch Lights, Rock Lights, CB, etc.
    Cragar soft 8s (397 series I believe)
    15x8 rim 5x4.5 bolt pattern -13mm offset 3.75" back spacing around $250 for a set of 4.
  4. Jan 23, 2015 at 7:44 AM
    AllTerrainMonster
    AllTerrainMonster Well-Known Member
    South Korea
    2006 2.7L Base 2WD
    MB TKO's 15x7 or 15x8 not sure of center bore
  5. Feb 1, 2015 at 12:13 PM
    ferdie
    ferdie Member
    escondido
    05 tacoma
    For allterrain monster
    I just installed 15x 8 TKO on my 05 taco with 235x75r15 and did the black box mod and its fine drives great , no lift
  6. Feb 1, 2015 at 12:34 PM
    ferdie
    ferdie Member
    escondido
    05 tacoma
    I'd post pictures if I can figure out how! Help!!!!
  7. Feb 2, 2015 at 7:48 AM
    AllTerrainMonster
    South Korea
    2006 2.7L Base 2WD
    are they lug or hubcentric?
  8. Feb 2, 2015 at 10:21 AM
    ferdie
    ferdie Member
    escondido
    05 tacoma
    No problem with the hub. Mine are 5x114.3 bolt pattern
  9. Feb 14, 2015 at 10:45 AM
    SicKnd
    SicKnd Well-Known Member
    HTX
    pork chop taco w/ cheese
    some
    you can always get some street rims for sports cars. caliper clearance wouldnt be an issue and theyre usually light weight
  10. Mar 1, 2015 at 4:07 PM
    ArizonaMike
    ArizonaMike New Member
    Arizona
    Base 4cyl
    Here's my new 16" 5x4.5 "chaos" wheels by MB Wheels with 245/70/16 tires that I replaced the original 15" steelies with....they look great and they lifted the truck about 2".
  11. Mar 20, 2015 at 8:29 PM
    atomictaco
    atomictaco New Member
    Kevin
    NE OHIO
    09 rwd access
    How about 225/45 17s from an 08 Lexus rx350 for my light duty 09 rwd Tacoma?
  12. Sep 30, 2015 at 6:39 PM
    1st2TR
    1st2TR Member
    Tennessee
    2012 SR5
    Tinted windows, undercover, bug guard, running boards, Toyota RAV4 16" alloys with Michelins
    image.jpg image.jpg Exact fit with lug and center bore I went with some 2001 RAV4 wheels with 225 70 16 great ride and fit
  13. Oct 6, 2015 at 8:19 AM
    htioki
    htioki Active Member
    2015 Tacoma Access Cab, base, 5-speed MT
    1st2TR, were you able to transfer the stock TPMS sensors from the stock steel wheels to the RAV wheels?
  14. Oct 12, 2015 at 7:28 PM
    1st2TR
    1st2TR Member
    Tennessee
    2012 SR5
    Yeah saved them in my old wheels lol
    No they don't work with these
    I don't mind the light
  15. Oct 15, 2015 at 1:40 PM
    ld626
    ld626 Member
    Guys help? I have a 13 crew cab with fenders flares, I found a good deal on a set of American Racing AX186 15x7 -6 offset but the installer is talking me out of it saying this offset will make my wheels seat too far out, like sticking out of fender about 1 1/2", what you guys think of this offset? I have a set of brand new 235/75/15 Michelins so I am sticking with 15"s...
  16. Oct 18, 2015 at 11:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    Just pull a wheel off, put one of your proposed wheels on (no tire changing), secure it with 2 lugs.
    Put a straightedge on the wheel and see where it comes in relation to your fender line.
    That should give you enough of an idea to decide if it's too far out or not. Likely it will be, but it's a free test just to prove it to yourself.
  17. Nov 10, 2015 at 10:48 PM
    Tomass321
    Tomass321 Well-Known Member
    Thomas
    San Luis Obispo
    2014 Base Tacoma access cab. 1994 Toyota pickup long travel
  18. Nov 11, 2015 at 3:26 PM
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    I have Bushwacker fender flares on mine, which I believe are 1.5 inches wider than stock flares. The wheels I have are 15x8 with a 3.75 in backspace and -19mm offset. My wheels and tires barely stick out the side of the flares, maybe half an inch. I don't think your wheels will stick out past the flare -- maybe a little tucked in actually.
  19. Nov 11, 2015 at 3:26 PM
    SleazyPetey
    Pete
    2013 Regular Cab
    ^ oh and I have 235/75/15 as well
  20. Nov 11, 2015 at 7:13 PM
    Tacoma Rook
    Tacoma Rook Member
    Changing rims does not seem to be worth the hassle from what I read.Got to by the rims then the tire pressure monitor system,new lugs and then spacers.Put it all together and then pray you dont get any wobble in the steering wheel.Some say the Kragers fit with no adjustments but theyre as plain as the stock rims IMO and still got to mess with the air pressure system.Would like to get new rims myself just do not trust getting into that mess!
