5 lug tacoma ball joint part # check
Discussion in '1st Gen. Tacomas (1995-2004)' started by Das it mang, Dec 7, 2022.
  1. Dec 7, 2022 at 9:53 AM
    Das it mang
    Das it mang [OP] Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
  2. Dec 7, 2022 at 11:11 AM
    1997tacomav6
    Denver
    OEM!!
  3. Dec 7, 2022 at 11:14 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    I would if i was 6 lug, but suspension geometry and limiting factors are different between the two.
  4. Dec 7, 2022 at 2:45 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  5. Dec 7, 2022 at 2:54 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Area51Runner[QUOTED] likes this.
  6. Dec 7, 2022 at 6:55 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    There was a thread were the moog's from advance auto had 555 cast on them....
    which is the exact oem manufacturer.........right.....
  7. Dec 7, 2022 at 7:31 PM
    d33pt
    d33pt Well-Known Member
    The 555 from OEM and Moog are not the same quality. Look at the two parts side by side and it's apparent.
