5 lug bolt pattern?
Discussion in '4 Cylinder' started by TBLOCK09, Mar 3, 2009.
  1. Mar 3, 2009 at 6:19 PM
    TBLOCK09
    TBLOCK09 [OP] Member
    San Diego
    05 5Lug
    Total chaos lt in front , icon aal in back, Hannemann front fenders ( painted stock white and painted the roof black at same time), window tint thats not to dark (i had to get the last pair taken off they had to find a ticket for something...)Afe cold air intake, Alpine 102 deck, kenwood eXcelon KFC-X1730P componets, alpine s-12 shallow sub behind the seat pushed by a rockford fosgate mono 400 wt amp, Grillcraft black grill (re powdered flat black), and just installed the LCE header.
    does anyone know the bolt pattern for a 2005 5 lug?
  2. Mar 3, 2009 at 6:32 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    5 X 114.3mm
  3. Mar 3, 2009 at 6:44 PM
    TBLOCK09
    San Diego
    05 5Lug
    so is that 5x4.5?
  4. Mar 3, 2009 at 7:11 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Correct.
  5. Oct 14, 2010 at 7:46 AM
    NickWRX
    NickWRX Member
    Hamburg, NY
    09 taco 2.7l.
    so anyone know what other OEM wheels will fit this?
  6. Oct 14, 2010 at 7:53 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    ALOT of cars. 5X114.3 is a very common lug pattern.
  7. Oct 14, 2010 at 10:22 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I think the highlander, camry, rav4, sienna all have the same bolt pattern but I don't know about offset and backspacing.
  8. Oct 14, 2010 at 11:32 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    also Murano, Cherokees, Endeavors
    offset around +30mm, for wheels to sit flush with fenders
  9. Oct 14, 2010 at 3:37 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Good to know. That would look way better.
  10. Oct 14, 2010 at 4:53 PM
    epa4wd
    Eduardo
    2019 SR
  11. Oct 14, 2010 at 4:55 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    The black ones look sick.
  12. Oct 14, 2010 at 4:56 PM
    epa4wd
    Eduardo
    2019 SR
    yeah black are the ones I have my eyes on! :D
  13. Jan 12, 2011 at 8:18 AM
    seanmyers22
    seanmyers22 Member
    Sean
    Tampa
    05 Access Cab
    Color matched grillcraft, BHLM, black box mod, fat bob's garage 2.75" lift, smoked tail lights, Webasto 770 sunroof, Aries bull bar, grinded down calipers, full exhaust, 15% tint, Weathertech mats and rain guards
    Do any of you know if that 5.25 inch backspacing will have any rubbing with some 31"s on just the 3" lift? I'm thinking about getting those as well..
  14. Feb 25, 2013 at 11:57 PM
    puretone
    puretone New Member
    1998 Tacoma, chassis type RZN150
    I've got a 1998 5-lug, with 2004 Highlander Hybrid Limited wheels...the front wheels needed a bit of modding to fit.
  15. Mar 13, 2013 at 6:38 PM
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    With a five lug pattern you measure the bolt centers while skipping one bolt.
    1-2-3-4-5 - so you would measure 1-3 or 2 to 4 or 3 to 5 - etc.
    PHM
  16. Mar 13, 2013 at 6:41 PM
    Poodle Head Mikey
  17. Mar 13, 2013 at 6:43 PM
    Poodle Head Mikey
    PHM
  18. Mar 18, 2013 at 10:11 AM
    tripletrouble
    tripletrouble New Member
    Toronto ontario
    SR5 4cyl
    Not so. The measurement has to be diametrically opposite.
  19. Mar 19, 2013 at 5:32 AM
    Poodle Head Mikey
    Let's say I have a 5x4.5 wheel size. There are five wheel studs: 1-2-3-4-5
    How is the size of the stud pattern properly measured?
    Which bolt centers do I measure between to find the 4.5" ?
    I say it is between any two studs having one between them.
    What do you say?
    PHM
  20. Mar 20, 2013 at 6:01 AM
    tripletrouble
    Toronto ontario
    SR5 4cyl
    With an even number of holes on a pitch circle diameter (bolt circle) you can measure directly. Not so with an odd number of holes, this has to be calculated. The formula is below:
    D = B / (Sin(360/2N))
    where
    D = PCD (diameter you are after)
    B = distance between holes
    N = number of holes
    Try googling PCD to verify this.
