4x4 vacuum hose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexlopez123, Dec 1, 2017.
  1. Dec 1, 2017 at 7:24 PM
    Alexlopez123
    Alexlopez123 [OP] Well-Known Member
    Alex
    2006 silver Tacoma 4x4
    So today I Crawling under my truck and I looked at my transfer case and I Notice that my hose that goes to tcase it was cracked I think it was off two is this part of my vacuum hose for my front Actuator
  2. Dec 2, 2017 at 5:25 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    The 4x4 actuators are electrically operated. The vacuum lines are vent lines. Replace them if they are cracked to keep water out of the t-case and front diff.
    landphil likes this.
  3. Dec 2, 2017 at 7:05 AM
    Alexlopez123
    Alex
    I was wondering because someone in here told me that the reason that my 4x4 will not engage was probably my vacuum line or it not having vacuum
  4. Dec 2, 2017 at 7:07 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  5. Dec 2, 2017 at 4:28 PM
    Alexlopez123
    Alex
    Ok thanks man but the only thing am still wondering is does your t-case have a actuator too
  6. Dec 2, 2017 at 4:34 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    The T-case has an electric actuator as well as the front differential. There's sensors too and all this feeds back to the 4x4 ECU which controls this mess.
  7. Dec 2, 2017 at 4:44 PM
    Alexlopez123
    Alex
    Ok cause I already took my front actuator off an all my post look good i Even tested it with a battery in my Actuator it was working good but I did notice that on my tcase on the side there is a hose that was crack so think it’s letting the vacuum out
  8. Dec 2, 2017 at 5:01 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    There's a rod behind the actuator. All the way in is 2wd, out one position is 4 hi, out to the furthest position is 4 lo. All controlled by an electric actuator. It's located on the back of the transfer case. The rubber hose is a vent.
  9. Dec 2, 2017 at 5:22 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    That's a vent hose. But it possibly let water in and now the actuator is water logged. This happens a lot to the front actuator. Not as often to the tcase actuator.
  10. Dec 2, 2017 at 5:23 PM
    Alexlopez123
    Alex
    So what do I need to do
  11. Dec 2, 2017 at 5:26 PM
    jowybyo
    Joe
    Baltimore, MD
    Take the actuator off. Verify if it's working. If it's not, open it up, dry it out, clean the terminals of the motor and try again. If you can't fix the actuator, replace it. Fix the vent line so you don't get water in it again.
    Alternatively, replace tcase with a FJ tcase that is stick shift so you never have to worry about the actuator again.
  12. Dec 2, 2017 at 5:27 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  13. Dec 2, 2017 at 5:31 PM
    Alexlopez123
    Alex
    Ok I done that I cleaned my terminals when I took it off I got my flashing light to go off but when I turn on my 4x4 they started to blink again I just do know
