4x4 system maintenance?
Discussion in '4 Cylinder' started by frog13, Jan 14, 2012.
  1. Jan 14, 2012 at 9:26 AM
    frog13
    frog13 [OP] Well-Known Member
    Never owned a 4x4 truck before.......the unit(4x4 system) would only be used during inclement weather. If a 4x4 system(engaging the 4x4 drivetrain) isn't used that often,is there any preventative maintenace one could perform to keep the system "healthy"?.I'm confident this has been discussed before...did a search,all that came up is breakdown issues...possibly my search wording isn't correct?.Any previous post recommendations would be appreciated.
  2. Jan 14, 2012 at 9:35 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    It says in the manual that you should drive your truck in 4H 10 miles per month. This will keep things lubricated and in working condition. Make sure you don't do it on pavement, and if you have to due to lack of gravel or snow or mud, don't turn to sharp.
    Other than that just the normal, outlined in the manual, service is needed.
  3. Jan 14, 2012 at 2:53 PM
    frog13
    Thanks for the reply sir!. I think you answered my next comment.....what if there isn't mud,gravel etc. for me to run 4H in?....I guess if I drive slowly in a straight line(in 4H) on pavement for a couple of miles per week that should surfice without tearing up anything......right?.
  4. Jan 14, 2012 at 3:03 PM
    Fightnfire
    Marysville, WA
    Should be fine you just want to avoid the 90deg stuff at 4 way etc.
  5. Jan 14, 2012 at 3:05 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    hey OP. i'm glad you asked that question because i was wondering the same thing. with my old Ford Ranger I would remind myself every day it rained to kick the 4x4 on for a few miles. we haven't had rain here in KS for awhile so i'll probably just go slow on pavement also.
  6. Jan 14, 2012 at 4:04 PM
    frog13
    Thanks for the reply's folks....straight line,slow driving "shouldn't hurt anything.
  7. Jan 14, 2012 at 4:26 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    IIRC, 30k gear oil changes.
  8. Jan 15, 2012 at 8:45 AM
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    i did my diffs at 1k. rear was nasty, with what looked like antiseize all over the plug. front was not bad at all. i will redo them at 10k, and if it looks pretty i will then adhere to the 30k changes.
    there was ZERO grease in my driveshaft, went through nearly a whole small tube of grease on all the zerks.
  9. Jan 15, 2012 at 4:18 PM
    frog13
    Rodney........you mean you changed your differential fluids at the 1000k mark?.....and your driveshaft was that lacking in lube in only 1000k:eek:.
  10. Jan 15, 2012 at 4:31 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Lube ujoints every 5k. Should take five pumps from a primed gun, give or take. All of my gear oils were still clean after 40k. I wonder what's up with yours.
  11. Jan 16, 2012 at 7:25 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I bought my '06 reg.cab 4X4 exactly a year ago with only 17,800 miles on it. Needless to say I think it sat for long periods of time, which led to moisture build-up in the differential cases and transmission. The fluids were opaque and gray in color. Very recently I changed my rear differential fluid again at 31,000 miles and it was the same color as when I put it in. I'll probably stick to the 30,000 mile interval now.
    Rear u-joints should be done with every oil change, if not earlier.
