4WD with Snow Tire Peeps - when do you decide to use chains?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BattleKat, Jan 28, 2023.
  1. Jan 28, 2023 at 10:12 AM
    BattleKat
    BattleKat [OP] Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    Question for people with 4D trucks with snow tires. When do you decide 4WD with snow tires is not sufficient and you break out the chains?
    I have a 3rd gen Tacoma Offroad, 4WD with Falken Wildpeaks 3-peak snow tire rating. Just got them a few months ago and have never had them in the snow, heck haven't had truck in snow yet. Big Bear is getting about a foot of snow slow and steady Sunday and Monday. I am planning to head up the mountains on Tuesday to do some snowboarding.
    I'm expecting the road rating requirements that day will be R2 (for those not familiar, the R2 definition is "Requirement 2 (R2): Chains or traction devices are required on all vehicles except four-wheel/all-wheel drive vehicles with snow-tread tires on all four wheels.". There is a higher R3 rating that requires chains even with 4WD and snow tires but I don't think that rating will be in effect. If it is I will follow it.
    My question is would you tend to use chains on a curvy mountain road if you had 4WD and snow tires for the extra level of confidence, or would you trust that if the roads are rated at R2 conditions and you meet them, you should be fine in 4WD and snow tires (assuming you know how to drive in the snow, which I do. I have just never done it in the mountains on windy hills with some steeper inclines).
    I will be carrying chains regardless.
  2. Jan 28, 2023 at 10:15 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Only if my wife is in the mood and asks for them :anonymous:
  3. Jan 28, 2023 at 10:17 AM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    I wouldn’t go much over 40mph with chains on, so…
    I’d just go 4Lo if it came to it.
    (take ‘em, but you ain’t gonna NEED ‘em)
    LeakyAC and musicisevil like this.
  4. Jan 28, 2023 at 10:17 AM
    Bishop84
    Bishop84 Well-Known Member
    I have never chained (canadian near mountains, run winter tires), but I don't think I would if I had falken wildpeaks. I always imagine chains for oem highway tires.
    Just leave it in 4WD when you can't see pavement, and consider lowering pressures to 25psi if it starts to feel dicey.
    Big thing is, if you're plowing through fresh heavy snow, is getting high centered, you can usually tell when the skid plate is leaving trails. Chains and tires won't help when the snow is too thick.
    RustyGreen and ConantTaco like this.
  5. Jan 28, 2023 at 10:19 AM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    I lived in Utah for 9 years ..t he snow is lighter drier a fluffier than in cal...I would put 50lb sand bags one over each side of axle and had ta ko's never did me wrong ...that was in 2000-2009 1st gen taco
    SR-71A likes this.
  6. Jan 28, 2023 at 10:19 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    You will need to carry chains but you won't need to use them. CalTrans very seldom actually uses R3. They tend to shut down the road if the conditions are that bad. I work in Mammoth every day and have for 20 years. I've never put chains on.
    Malvolio, SR-71A, vicali and 3 others like this.
  7. Jan 28, 2023 at 10:28 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Deep fluffy snow = Aired way down and no chains.
    *You want to float, not dig to the bottom.
    Really cold grippy snow = Street pressure, no chains.
    *As long as the frame/diffs are not dragging, traction should be fine.
    Patchy snow/ice/bare pavement on the highway = Street pressure, NO chains.
    *Drive extremely cautiously, nothing abrupt with steering/braking. Chains are dangerous on bare pavement.
    Miles of slick densely packed snow several inches deep = Chains.
    *As long as snow is packed and no bare pavement, chains are best.
    Miles of snow covered ice = Chains.
    *Cold snow over ice can be tricky, but chains will work best. Drive extremely cautiously, nothing abrupt with steering/braking.
    Black ice = Ice is too thin for chains to any good amd quite dangerous. Just stay off the road.
  8. Jan 28, 2023 at 10:29 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I see snow 6 months out of the year, but I've never used chains or seen anyone using them. If I did happen to have some, I wouldn't use them until there was no other choice, e.g. if I were unable to get up an icy incline.
    I've also ridden a lot of miles on bicycle in the winter and found that studded tires are a game changer on icy surfaces but don't do squat on soft snow.
  9. Jan 28, 2023 at 11:17 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    Falken Wildpeak aren't really what I would consider actual winter tires. The 3 peak rating isn't that hard to achieve and lots of AT tires have that rating. That being said if you're going through deep snow, they should be fine.
    Personally I run studded winter tires in winter and Duratracs in summer and don't even own chains so can't really tell when those would come in handy other than if they are mandated.
  10. Jan 28, 2023 at 11:22 AM
    gudujarlson
    Minnesota
    I think if anyone were to don chains in Minnesota they would get a lot of weird looks and probably some middle fingers and honks for driving 30-40mph on the hiway. I can see how it could be different in the mountains though.
    doublethebass likes this.
  11. Jan 28, 2023 at 11:22 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Unless the snow is really, deep 12" or more, 4X4 and good tires are probably fine. It is ice where you NEED chains.
  12. Jan 28, 2023 at 11:27 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Is that because the people without chains are parked in the ditch?
    BattleKat[OP] likes this.
  13. Jan 28, 2023 at 11:28 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I was born and raised in the San Bernardino mountains and those of us who live there or at least have been driving in snow for many years virtually never chain up our 4x4s unless we are forced to by chain check, or it snows a ton (like 2’+) and there’s no other choice to leave the house. In 45 years, I’ve honestly only needed to chain up a 4x4 exactly 2 times in my life. However, if you haven’t sat behind the wheel in snowy conditions for many hours, you need to put chains on when you start to feel even slightly uncomfortable with them off. Too many people fail to realize that chains are NOT meant to get you unstuck - They’re meant to prevent you getting stuck in the first place. Don’t be one of the asshats that thinks they can make it without chains, then gets stuck in the middle of the road, and blocks traffic for an hour while they put their chains on after the fact with cars sliding all around them. That makes the locals want to throat punch you.
    Malvolio likes this.
  14. Jan 28, 2023 at 11:32 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Never used chains in my live. I drive in a foot of snow, no issue with my awesome Duratracs! Usually leaving many people in the dust....
    musicisevil likes this.
  15. Jan 28, 2023 at 11:35 AM
    gudujarlson
    Minnesota
    I’m not sure if you are joking or misunderstanding me. No one uses chains here, so a person using then would look highly unusual. Possible reasons for this are a very capable snow removal system, the lack of mountains, and experienced drivers.
  16. Jan 28, 2023 at 11:41 AM
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    when you see 4wd vehicles coming down opposite direction all with chains
    Malvolio, MNMLST and BattleKat[OP] like this.
  17. Jan 28, 2023 at 11:41 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    As long as your snow is not packed slick, then you are absolutely golden with decent tires.
    When it gets packed super tight or frozen solid, no bare tire is a good option.
    There is a very wide range of snow types across the country and each condition deserves the right approach.
    A person that has lived and driven on the same perfect condition snow for 45 years would lose it if they didn't adapt to the conditions.
    I would love to have cold mountain pass snow to drive on, but we get this shitty wet floppy snow that is really close to slush when it starts to accumulate and then it freezes solid at night.
    Ever see the videos of Seattle and PDX slip-n-slides? Try driving on that without chains and results will be the same.
  18. Jan 28, 2023 at 11:45 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Add very incapable snow removal, mountains, and inexperienced drivers from out of state, and you see what kind of shit show we deal with in the PNwet.
    We just don't get good snow on the wet side if the state (Oregon/Washington). Central and eastern sides are much much colder and flatter, and inexperienced drivers don't tend to venture far from major cities.
    gudujarlson[QUOTED] likes this.
  19. Jan 28, 2023 at 11:50 AM
    Oly14411
    Oly14411 Well-Known Member
    Washington State
    2019 Cement TRD OR DCLB
    It is highly unlikely that you will never need them if driving on roads that lead to ski areas. Never had to chain up w/a 4x4 in 40+ years of driving in the mountains of the PNW. I have them onboard to meet National Park access requirements, but they remain untouched.
    TacoEspecial likes this.
  20. Jan 28, 2023 at 11:51 AM
    gudujarlson
    Minnesota
    The one thing that does break down in the twin cities during a snow storm is the Uber/Lift system. A majority of the drivers are recent immigrants from places where there isn’t much snow and they shun snowy roads.
    A similar thing happened to me in New Orleans during a thunderstorm. I ended up stranded at a bar all night because the entire Uber/lift/cab system shut down due to flooding. Luckily bars stay open all night there. That was a trip. :)
    doublethebass and Tocamo like this.
