4WD Switch Illumination
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JAHGB2, Oct 4, 2018.
  1. Oct 4, 2018 at 2:15 PM
    JAHGB2
    JAHGB2 [OP] Well-Known Member
    Pennsylvania
    2010 TRD Sport DBL CAB Pyrite Mica
    Hey guys,
    I have 2010 TRD that I bought used a year ago and noticed that the 4WD selector switch on the dash does not illuminate at night when the other instrument/dash lights are on. Is it supposed to light up? Nothing in the below image lights up. I'm wondering if I have a bad fuse or if this never lit up.
    Thanks.
    I'm referring to this switch:
  2. Oct 4, 2018 at 2:17 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
  3. Oct 4, 2018 at 2:17 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    On other Toyotas it does. Toyota cheaped out with the taco. From the factory, it doesn't light up, but it's easy to modify it so it will.
    JAHGB2[QUOTED][OP] likes this.
  4. Oct 4, 2018 at 2:20 PM
    JAHGB2
    Pennsylvania
  5. Oct 4, 2018 at 2:25 PM
    replica9000
    2019 T4R ORP
    I've done that mod a couple years ago
  6. Oct 4, 2018 at 2:25 PM
    JAHGB2
    Pennsylvania
    Looks good. Thanks for sharing the pic and info!
  7. Oct 4, 2018 at 2:26 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    @rcbs204 used to sell the boards. Not sure if he still does.
    JAHGB2[OP] likes this.
  8. Oct 4, 2018 at 3:07 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I went a cheaper route on mine i ran a led lights from the ac controls and stuffed it in the whole where the bulb goes. Its not as bright as the pic above but it is illuminated
    NepaTaco and JAHGB2[OP] like this.
  9. Oct 4, 2018 at 3:40 PM
    Muddinfun
    Muddinfun Well-Known Member
  10. Oct 4, 2018 at 5:30 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
  11. Oct 4, 2018 at 5:53 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Any option for a 2015?
  12. Oct 4, 2018 at 6:04 PM
    rcbs204
    Nope unfortunately.
    PzTank[QUOTED] likes this.
  13. Oct 4, 2018 at 7:19 PM
    PzTank
    Above the Notches
    Well, that sucks now doesn't it....
    Thanks for the quick reply @rcbs204
  14. Oct 4, 2018 at 8:30 PM
    E.RDZ_TACOMA
    E.RDZ_TACOMA Well-Known Member
    Denton, TX
    2007 Blue Tacoma Access Cab 4×4
    Wish there was a plug and play light up 4WD switch. Not good with electric work :(
    rcbs204 likes this.
  15. Oct 4, 2018 at 8:48 PM
    rcbs204
    My mod is not hard at all, if you buy the little posi-tap connectors you can just tap into the connections. No soldering required.
  16. Oct 5, 2018 at 5:44 AM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    rcbs204 is absolutely right. This is a very easy mod, and the directions to do it are great. The new board drops in with just one screw and, if you do what I did to the switch, you won't need to solder anything and it stays completely removable.
    You can do this. :)
    eherlihy, tbird95 and JAHGB2[OP] like this.
  17. Oct 5, 2018 at 2:14 PM
    JAHGB2
    Pennsylvania
    haha. no doubt!
  18. Oct 5, 2018 at 2:16 PM
    JAHGB2
    Pennsylvania
    Muddinfun[QUOTED] likes this.
  19. Oct 5, 2018 at 4:06 PM
    rcbs204
    Good point, I forget about that little brown connector. My new solid core wire will lend itself really well to that installation method.
  20. Oct 5, 2018 at 4:50 PM
    E.RDZ_TACOMA
    Denton, TX
    Thanks guys. Ima bite the bullet and try to do it. Gotta get my next paycheck first though to order :D
