4WD light blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SexyTaco, Apr 2, 2016.
  1. Apr 2, 2016 at 8:15 AM
    SexyTaco
    SexyTaco [OP] Well-Known Member
    matt
    Siloam, North Carolina
    Tacoma TRD 6 speed
    Fox MId-Travel and OME leaf packs with BAMF 12" shock relocation. Relentless Fab front bumper and custom rear bumper custom rock sliders. Other little stuff as well.
    Last summer while on a trail in low 4wd, a stick somehow disconnected a quick connect going to my actuator or front diff (the guy who found it and fixed it was not specific at all). Now my 4WD light always blinks while in 2wd, but works how it is supposed to while in 4wd and in low 4. Everything works how it is supposed to other than the light. Thought about taking it to Toyota, but afraid they'll charge me a ton for nothing. And again, it changes into 4WD and 4 low flawlessly, the light just wont quit blinking while I'm in 2wd. Anyone have any ideas? Its starting to annoy the crap out of me.
    2020tacosauce likes this.
  2. Apr 2, 2016 at 11:09 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The blinking generally means the truck is still in 4wd. I would check the connectors to ensure they are properly engaged and that there are no broken wires.
  3. Apr 2, 2016 at 11:26 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Blinking means it is Not Engaged in 4 Wheel Drive.
  4. Apr 3, 2016 at 10:22 AM
    azreb
    azreb Geezer
    TN
    Mine blinks when I turn the switch from 4wd until it disengages. Maybe yours works differently.
  5. Apr 4, 2016 at 12:54 PM
    SexyTaco
    matt
    Tacoma TRD 6 speed
    It goes in and out of 4wd fine, just when it disengages the light stays blinking. Ill check the wires and connections again though. I dont want to Toyota will say it's because of my diff lock mod I'm sure so that's why I haven't taken it to them.
  6. Apr 4, 2016 at 1:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do you you turn your diff lock mod off before turning out of 4wd. That will cause the issue.
    4WDKid likes this.
  7. Apr 4, 2016 at 1:05 PM
    SexyTaco
    matt
    Tacoma TRD 6 speed
    yea I've checked that too. Also checked the mod itself and everything is how it is supposed to be.
  8. Apr 4, 2016 at 3:49 PM
    nd4spdbh
    SoCal
    hmm something is up then. Does the light ever go stead lit when you are in 4wd?
  9. Apr 4, 2016 at 7:50 PM
    SexyTaco
    matt
    Tacoma TRD 6 speed
    I wish I knew how to upload a video. It would be much easier to see. When I go into 4wd the light goes solid, when I go to 4 low it doesn't blink (like it's trying to engage/disengage) just goes solid but everything works fine. When I go take it out of 4wd it just blinks(and hasn't quit since) but it does disengage
  10. Apr 5, 2016 at 6:31 AM
    CroResident
    CroResident Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    there are a million threads like this one on here with people having this issue, but i have yet to see some one come along with an answer for this issue.
  11. Apr 5, 2016 at 7:55 AM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    front differential actuator limit switch is hung up
    CroResident likes this.
  12. Apr 5, 2016 at 8:03 AM
    nd4spdbh
    SoCal
    4low is a seperate light that actually says "4LO". The 4wd light that blinks when going into 4hi will stay solid, then the 4LO light will blink when its going into 4LO until its engaged
    shakerhood and CroResident like this.
  13. Apr 5, 2016 at 1:45 PM
    SexyTaco
    matt
    Tacoma TRD 6 speed
    The 4 low light does come on like it normally would. I'm gonna crawl under there again and see if i missed anything from last time.
  14. Apr 5, 2016 at 1:46 PM
    SexyTaco
    matt
    Tacoma TRD 6 speed
    you're going to have to tell me what that is lol
  15. Apr 5, 2016 at 3:04 PM
    PSU Taco85
    optional
    It's a part integral to the actuator so there's really no repair other than buying a new actuator, they're around $300
  16. Apr 5, 2016 at 4:05 PM
    SexyTaco
    matt
    Tacoma TRD 6 speed
    I guess I'm living with the blinking then. I won't hurt anything like this will it? its been doing this 6 months now (wheeling and all) and everything has been fine.
  17. Apr 5, 2016 at 4:25 PM
    PSU Taco85
    optional
    Eventually it will give up the ghost and you'll either be stuck in 4wd or 2wd
  18. Apr 6, 2016 at 7:55 AM
    SexyTaco
    matt
    Tacoma TRD 6 speed
    I'll save my pennies then. Thanks a lot man
  19. Sep 10, 2018 at 5:22 PM
    MapleFarrell
    MapleFarrell New Member
    2007 Tacoma 4x4 TRD Sport
    Did you ever get this figured out? I have had an identical issue on my 2007 Taco for at least 5 years. Four-wheel drive works flawlessly but the light continuously flashes when in 2wd.
    Am looking to sell my truck and would like to fix all my dashboard fireworks before I do.
  20. Sep 24, 2018 at 9:03 AM
    SexyTaco
    matt
    Tacoma TRD 6 speed
    Never did. Still blinks. Might have to take a trip to the stealership.
    ScenicCityOverland likes this.
