4WD in rain OK?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by puckstopper55, Sep 28, 2011.
  1. Sep 28, 2011 at 4:12 AM
    puckstopper55
    puckstopper55 [OP] Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    Hello guys .. I have read, and know the rules for using 4wd (ie, do not use it on dry pavement due to binding, try to use it for 10 miles a month to keep it lubricated, dont try to switch it into 4WD on the fly above 62mph, ect).
    My questions is, is driving in 4WD in the rain, or on wet road OK? Basically my concern is that the wet road wont allow the wheels to "slip" and I would have a binding issue.
    I dont have any off road trails or the likes to drive in 4WD near me, it snows, but only in the winter, and I think it makes perfect sense to try and use it once in a while to keep thinks in working order and well lubricated.
    What do you guys think? Thanks
  2. Sep 28, 2011 at 4:23 AM
    Namyo
    Namyo -
    Wet = slip :p
    I use mine if it's raining real hard..puddling on the side. Other than that no, not if just wet road.
  3. Sep 28, 2011 at 4:30 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I wouldn't for more than a few hundred feet, and no turns that cause binding.
    I know the front diffy and drive shaft turns, and therefore part of transfer case at least, since it's coupled to one wheel all the time. I think someone mentioned the oil pump for the TC works even when 4x4 isn't engaged. I just don't see the point in operating it for long... really only in and right back out basically to make sure the actuators are functioning normally.
    Lastly: our 4x4 system is not designed for continuous operation, and especially not high-speed operation (which in this context is anything over 25mph) on paved roads. Using it like that wears components at a prodigious rate, and there's just no reason to. It's designed to be engaged, truck through a hazard, and disengage.
  4. Sep 28, 2011 at 4:36 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    No way. I wouldn't flip the switch on wet roads. If I'm going from snow/mud to dry dirt/pavement I get enough momentum and turn it off before I get on the asphalt/dirt. IMO there's no reason to use it unless absolutely necessary
  5. Sep 28, 2011 at 6:52 AM
    puckstopper55
    Long Island
    I am not saying I need to use the 4WD, just trying to determine is the wet roads would provide enough slip to keep the drive train from binding.
  6. Sep 28, 2011 at 7:15 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    There must be a dirt or unpaved road somewhere near by to go thru the motions. I would wait until you find a dirt road to play 4x4
  7. Sep 28, 2011 at 7:17 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i wouldnt use it on wet roads.
  8. Sep 28, 2011 at 7:20 AM
    puckstopper55
    Long Island
    The closest one that I know of is about 30 minutes away, and its just a big dirt lot, nothing special. Seems a bit extreme just to throw it into 4wd. Maybe I will just drive some very straight lines to lube everything up.
  9. Sep 28, 2011 at 7:28 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    If we get a hard rain while I'm towing the boat (straight/hwy not over 60mph), I will throw it into 4x4.... Always done this, gives me a little peace of mind, and its never give me a problem.
  10. Sep 28, 2011 at 7:31 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    4wd in rain is unecessary , but less likely to bind up than dry pavement
  11. Sep 28, 2011 at 7:32 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    If it's a hard rain with large puddles I use it as well. There will be some slippage there just based on how light the ass end of the truck is. I have never had an issue, never had any binding. For light rains no, just wet roads no, but heavy rains with puddles.
  12. Sep 28, 2011 at 7:38 AM
    puckstopper55
    Long Island
    Not sure the rear is of any concern due to the open differential .. the front would be the concern correct? (Due to it not being an open diff)
  13. Sep 28, 2011 at 7:41 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    If you're getting traction.... you don't need 4WD, and if you use it, you risk binding.
    If you are not getting traction, the drivetrain cannot bind... go for it.
  14. Sep 28, 2011 at 7:55 AM
    puckstopper55
    Long Island
    I didnt "need" it, I just wanted to use it to keep all the gears lubed, and was looking for the best opportunity to use it without risking binding.
    When everyone talks about "not turning" while in 4wd, do you mean like 90 degree turns, or even slight lane changes?
  15. Sep 28, 2011 at 8:04 AM
    wlmuncy
    William
    Knoxville, TN
    The front is an open differential.
  16. Sep 28, 2011 at 8:12 AM
    Mathman222
    Mathman222 Member
    Roger
    Nashville
    11 DC OR Pyrite
    265/75/16's, more to come...
    The binding issues occur at the transfer case, due to differences in the front and rear. An AWD transfer case is a limited slip or viscous coupling, acting like a differential between the front and rear, but the transfer case in a 4wd would be analogous to a spool...no slipage, and so if the front is turning more or less than the rear you can run into problems on dry pavement (or really any surface with a decent amount of traction).
  17. Sep 28, 2011 at 8:36 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    ah 4wd i nthe rain not a problem as long as road is nice and wet. Yeah dont do 90 degree turns on pavement with 4x4 . Llight S curves will not be a issue.
    BTW to keep lubricated you dont need to make full 10 miles. All you need is to switch system on and off couple times so all the forks move from their normal positions for oil to get there.
  18. Sep 28, 2011 at 8:46 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    what i found that works. if i am at a stop sign thats on a hill or at the wal mart i go to you have to turn up hill as you pull on to the road. when it’s raining or the road is really wet i shift it to L or 2. and i don’t spin the tires. now if i just leave it in “D” it dose.
  19. Sep 28, 2011 at 8:48 AM
    Canuckwithatruck
    Canuckwithatruck Well-Known Member
    Ross
    Bow Lake, Alberta
    2006 TRD Sport
    OME 885 Coils Light Racing UCA's Dakar Leaf Pack
    /\ /\ What he said, think of runners running around a track, the inside lane (front tires) have less distance to travel around a turn. But all tires are being forced to travel the same amount. This will cause everything in the system to bind, and will likely result in a CLUNK when you disengage. If you are driving straight you will not have this problem.
  20. Sep 28, 2011 at 9:25 AM
    puckstopper55
    Long Island
    makes sense guys .. thanks for the help and clarification
