4wd flashing HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgs2k2, Apr 24, 2010.
  1. Apr 24, 2010 at 8:20 PM
    cgs2k2
    cgs2k2 [OP] old man
    My 4wd light is flashing on my gauge cluster. I'm pretty sure its not letting me shift into 4wd but i can't really tell. It's a certified used car, and they said there is no way that it could be an actual mechanical problem as far as the transfer case and what not. It's an 06 with 58,000 miles on it, Automatic. Any ideas? Anyone else have this problem? Please help.
    Thanks guys, I'm new so I appreciate any help.
    UPDATE ON PAGE 2!!!
  2. Apr 24, 2010 at 8:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Go back and read the manual and make sure you are doing everything it says. The actuators can be kind finicky and if it hasn't been used in a while it might even be a bit sticky.
    If it's just flashing tho- It's not engaging. Make sure you are doing the shift procedure right and go from there....
  3. Apr 24, 2010 at 8:29 PM
    cgs2k2
    cgs2k2 [OP] old man
    Ok i will go back and try again, but i've read and tried a bunch of times.
    cmack: I'm not sure if i'm stuck in 2hi or 4hi. I can switch it from 2hi to 4hi but i dont notice a difference in ride, and the light continues to flash.
    does anyone think maybe unplugging the battery for a little while and trying to reset it will help at all?
    Thanks again for the quick responses guys.
  4. Apr 24, 2010 at 8:30 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Shifting from H2 to H4 should be easy as pie... on the fly... any speed to 60 mph. If you are parked, try moving... tires straight...
    Shifting from H4 to L4 requires your to STOP... put the tranny into NEUTRAL (not park), then rotate the dial to L4... repeat to go back to H4.
  5. Apr 24, 2010 at 8:35 PM
    David K
    Huh? Difference in ride? There is no ride difference in H4 over H2... only steering will be difficult if you are on firm ground or pavement (why you don't use 4WD on dry pavement as the front and back driveshafts are locked together, but they turn at different speeds.
    In L4, your gearing is much lower, so your top speed is much reduced... You WILL know when you are in L4 (low range).
  6. Apr 24, 2010 at 8:52 PM
    cgs2k2
    cgs2k2 [OP] old man
    I'm shifting it the right way, and doing everything correct in that aspect. This is something that seems to be wrong with either the button, wiring, or electronics itself. I just got the truck today so I'm new to the whole thing, but I know I'm shifting right because the guy at the dealership tried shifting and could not do it either.
    The light is flashing continuously so I feel like it's stuck in something, either 2hi or 4hi. When i go between the two I don't think it goes into either 4 or 2 wheel drive.
    Has nobody else had this problem?
  7. Apr 24, 2010 at 9:34 PM
    David K
    As I said, you would know if you are in 4WD on pavement, as it would be difficult to steer a tight turn. Flashing means it is NOT in 4WD, anyway... It goes on solid when you are in 4WD. Rotate the dial back to H2, the flashing should stop... does it? You are in 2WD... Now, repeat... while driving STRAIGHT, rotate to H4... You may hear a 'clunk' and then the light goes on solid and you are in H4. Blinking indicates the switch to 4WD failed, and for you to try again. (You said button, you do mean 'dial', right?) The 'button' (if equipped) is for the Rear Locker... that is another thing altogether... and only works in L4, okay?
  8. Apr 24, 2010 at 9:45 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Not entirely sure, but I assume the transfer case is shifted from 2 to 4hi via electric solenoid. If you can locate it and give it a few light taps with a hammer, or something similar, you might be able to free it up. And let me stress on the "light" taps.
    AbunaiTaco likes this.
  9. Apr 24, 2010 at 11:06 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Hey man, I had the exact same issue. Give me a call at ########## sometime tomorrow and I'll help you out. If I don't answer just leave a message and I'll call you right back.
  10. Apr 24, 2010 at 11:11 PM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    so we can shift into 4hi on the fly? I've always stopped went Neutral, then drove.... but on the fly is tight if we can
  11. Apr 24, 2010 at 11:16 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Like Brunes said, if you read the owners manual correctly and tried it by the book then, it sounds like the OP may have a bad 4wd actuator.
  12. Apr 25, 2010 at 8:11 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Yep. 4Lo is the only one you have to come to a stop to engage. 4Hi should work fine while moving. I do it all the time.
  13. Apr 25, 2010 at 8:16 AM
    David K
    YES you can, and should as soon as possible! :rolleyes::cool:
    Do you have the card in the sun visor pocket, driver's side OR an owner's manual? :confused::D
  14. Apr 25, 2010 at 11:16 AM
    cgs2k2
    cgs2k2 [OP] old man
    Yes, I did mean dial. Sorry. I've tried it all and it's looking like I'm gonna end up taking it to a dealer and having them look at it.
    Memario, thanks for the offer man! I'm gonna call you here soon and see if maybe you have an easy fix that i'd be comfortable with.
    Thanks for all the help guys/gals. very good community here, i love it.
  15. Apr 25, 2010 at 5:31 PM
    David K
    Okay... then get it to the dealership!
    Here is the info card in the sun visor from my 2010 Tacoma... for getting into and out of 4WD (H4, L4)... and a note on the VSC does not work in L4, but does in H2 and H4:
  16. Apr 25, 2010 at 8:29 PM
    cgs2k2
    cgs2k2 [OP] old man
    I never tried driving in reverse then trying to shift into 4Hi. Could that work??
    I've tried at a stop, accelerating, and decelerating though.
  17. Apr 25, 2010 at 8:42 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Toyota was dumb for even putting in a stupid button for the 4 wheel drive. Should have stayed with the old school shifter.
    TheWabbit likes this.
  18. Apr 25, 2010 at 8:43 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Yes it will work. While shifting into 4Hi it does not matter what position the transmission is in. The gears must align for the 4wd actuator to actually engage, sometimes turning the steering wheel to the left or right will do the trick.
    With the gears perfectly aligned I can put my truck into 4wd without moving.
    http://www.youtube.com/watch?v=ttPUtZl5QzY
    To me it seems that there is something wrong and your truck needs to be diagnosed.
  19. Apr 25, 2010 at 9:40 PM
    mpleitez
    mpleitez Well-Known Member
    valencia
    03 toyota tacoma double cab 4x4
    Rear E-Locker TRD supercharger w/URD 7th injector 3 in. lift (soon) Icon coil overs front (soon) Icon UCA (soon) K&N air intake DT Headers (one day)
    get under the fron differential and check the actuator. Mine was full of mud and doing the same thing, once it was replaced it worked perfectly.
    quote=cgs2k2;1692670]I'm shifting it the right way, and doing everything correct in that aspect. This is something that seems to be wrong with either the button, wiring, or electronics itself. I just got the truck today so I'm new to the whole thing, but I know I'm shifting right because the guy at the dealership tried shifting and could not do it either.
    Has nobody else had this problem?[/quote]
  20. Apr 25, 2010 at 9:48 PM
    memario1214
    Colton
    Missoula, MT
    It has got to be his actuator. I talked to him earlier today and we went through all of his electricals, it's no them. My best guess is that there is some water or something in his actuator. He is not super auto fix-it inclined, so I told him to take it into the dealer he just bought it from, and see what they say. If they tell him its gonna cost, he will most likely give me a call back, and I will talk him through checking the status of his actuator that engages the front diff.
    rfcomm2019 likes this.
