4th generation exterior dimensions. Smaller or larger than 3rd?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDProOne, Mar 30, 2020.
  1. Apr 2, 2020 at 2:39 PM
    #141
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    ITT: lots of nonsense speculation.
    There's one guy (girl? person? @Carmaker1) here (TacomaWorld) who posts who actually knows what's going on. I strongly suggest searching their posts and taking it as gospel as much as one can from Toyota.
    OA
  2. Apr 2, 2020 at 5:02 PM
    #142
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Not quite that big. But getting there:
    2000 Tundra dimesions:
    Dimension (Exterior)
    Length 217.5 in
    Width 75.2 in
    Height 70.5 in
    Wheelbase 128.3 inch
    Ground clearance 10.4 - 11.6 inch
    Dimension (Interior)
    Front leg room 41.5 in
    Front head room 40.3 in
    Front shoulder room 62.4 in
    Front hip room 59.3 in
    2016 Tacoma Dimensions:
    Length 212.3 in
    Width 74.4 in
    Height 70.6 in
    Wheelbase 127.4 - 140.6 inch
    Ground clearance 9.4 inch
    Front leg room 42.9 in
    Rear leg room 24.6 in
    Front head room 39.7 in
    Rear head room 34.9 in
    Front shoulder room 58.3 in
    Rear shoulder room 56.5 in
    Front hip room 57.2 in
    Rear hip room 51.7 in
    MidCitiesMildMan and shakerhood like this.
  3. Apr 2, 2020 at 5:14 PM
    #143
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    I get that's where things are headed, but no, just...no.
    Also thank you for showing dimensions:thumbsup:
  4. Apr 2, 2020 at 6:13 PM
    #144
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    2005-present Frontier 205.5 inches long. Or 1st gen Tacoma 202.9 inches long. The current Tacoma is not as big as the 1st gen Tundra but it sure has grown.
  5. Apr 2, 2020 at 8:14 PM
    #145
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The 3rd Gen Tacoma is probably closer in size to the T-100 than the early Tundra's.
  6. Apr 2, 2020 at 8:15 PM
    #146
    Running Board Man
    Running Board Man Well-Known Member
    The 3rd gen is .8 inches narrower than t 1st gen tundra... thats pretty similar
  7. Apr 2, 2020 at 8:52 PM
    #147
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    I owned a 2004 Tundra access cab and kind of find it interesting that there is less than 1 inch difference in the width. You could fit a 4x8 sheet of plywood between the fenderwells on the tundra but the tacoma is a couple inches narrower in the bed.
  8. Apr 2, 2020 at 8:55 PM
    #148
    Running Board Man
    Its the composite bed
    I got to go up to a 1st gen tundra with an 8ft bed and gawd thats a lot of space
  9. Apr 2, 2020 at 9:30 PM
    #149
    rocky_mountain_dave
    David
    The Tacoma only needs 2 more inches on each side to fit a sheet of plywood between the wheel wells - sure seems like they could have added those 2 inches without causing any tire rubbing issues.
    Oh well, at least they have us those slots to fit a 2x6 horizontally to rest the plywood on. .
    shakerhood likes this.
  10. Apr 2, 2020 at 9:36 PM
    #150
    shakerhood
    Southern Ohio
    I have found (2) 2x4's fit those slots much tighter fit than a 2x6.
    Junkhead and P-Dawg like this.
  11. Apr 3, 2020 at 6:10 AM
    #151
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    front suspension, upper/lower control arms give a basically mid-travel setup for cheap. But the front tires do stick out further than stock and most ignore it, others have custom glass made. It’s a little wonky looking
    tonered[QUOTED] likes this.
  12. Apr 3, 2020 at 6:40 AM
    #152
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is pretty cool in the end. If it is the same for Tacos, I bet we see a lot of that since there will be some pickings by the time the Taco launches.
  13. Apr 3, 2020 at 11:34 AM
    #153
    Plucky was his name
    Plucky was his name Well-Known Member
    Carl
    Central East Texas
    2007 Reg Cab Taco 4x4 5-speed manual
    ARB Front Bumper, Wet Oakle Seat Covers, Aftermarket Stereo, OME suspension with Heavy Duty Dakar Leaf Springs
    I’d like Toyota to bring back a regular cab Tacoma, but with an 8’ bed. They can make the cab size larger so the overall proportions don’t look idiotic. (Thinking T-100) Then use that extra cab room to improve the seating position for a comfortable bench seat with fold-down center armrest.
    Retune (however much was possible) the 2.7L 2tr-fe, designating it some new engine code, low boost forced induction perfectly paired with our choice of either a 6 speed manual or 8 speed automatic, and call it a day. Give folks who don’t know any better other engine/cab/bed choices.
    Base all of the other configurations of the Tacoma around the above. I’ll take one in black. Then I’ll remove the bed and put a steel flatbed on it with a headache rack, lift it for no good reason whatsoever, and 35’s, and mount of toolbox right in the center between the bed sides right up against the back of the cab.
    I’ll use it 8 times a year the way it will look it gets used, and drive it forever, or just whenever I’m not driving my ‘07 regular cab. I know this isn’t 100% in response to the OP’s topic, but I haven’t posted in a while, started day-dreaming, so here ya go.
    VanGo3 likes this.
  14. Apr 3, 2020 at 8:21 PM
    #154
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    I found the seating was more comfy and the floor was lower. It had slightly less clearance.
    jmauvais[QUOTED] and tacowestley like this.
  15. Apr 3, 2020 at 8:40 PM
    #155
    aStrauss
    aStrauss Well-Known Member
    Andrew
    2019 TRD OR DCSB 6MT
    Axle shafts also.
    I considered titan swapping my XTerra when I did my front strut assemblies, axle shafts, and hubs but decided not to because if the cost, since I would have needed upper and lower control arms as well.
    So many parts were rusted solid and needed to be cut out and replaced that, by the time everything was done, I ended up replacing all the parts that I would have needed to if I’d just titan swapped from the jump. Talk about frustrating hahah I regretted not just pulling the trigger on the swap.
    Running Board Man likes this.
  16. Apr 4, 2020 at 12:15 AM
    #156
    jmauvais
    NorCal
    ...stuff
    I thought they had to get custom axle shafts made, or at least a certain company made the connection piece, but you’re probably right. The swap was cool but it did add up quick if you couldn’t source the parts from a yard
  17. Apr 4, 2020 at 4:35 AM
    #157
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    Running Board Man and skyking3 like this.
  18. Apr 5, 2020 at 7:18 AM
    #158
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    Since no one has answered your question, why don't you tell us why you think a shared platform weakens both the Tundra and Tacoma? I don't see the negatives, so tell me what i am missing.
  19. Apr 5, 2020 at 1:10 PM
    #159
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    If they could keep the Tacoma the same size with a bigger back seat. It would be perfect.
    I read the Landcruiser is losing the 3rd row seats and all the luxury features. Which will bring down the price and sell more. They are also making it more offroad capable then the current one. And the Lexus LX is going to get all the Luxury Lexus can put in it. They are using the Bentley Bentayga as its target.
    Rockefelluh likes this.
  20. Apr 5, 2020 at 6:05 PM
    #160
    VanGo3
    VanGo3 Modern vehicles are ugly.
    Northern California
    20 SX AC 4x4
    Mostly dust and dirt.
    While I’m certainly no engineer it seems to me that so many changes would need to be done with both chassis’s that either the Tacoma will be way overweight or the Tundra would be weakened.
    I’m not sure how Nissan does it with the Titan and Frontier.
