4th gen Oil Change
Discussion in '4th Gen. Tacomas (2024+)' started by Teuton, Jun 8, 2024.
  1. Jun 8, 2024 at 9:14 AM
    Teuton
    Teuton [OP] Well-Known Member
    2011 Reg Cab 4x4, 2021 TRD sport, 2024 TRD Sport
    It’s about time for a lot of us to do the first oil change. Procedure is the same as it’s always been, just new locations of the plug and filter.
    You still only need a 14mm for the drain plug and I needed a 12mm to remove the felt skid plate thing. Beware, my factory oil filter was super tight. I was able to twist it off with rubber gloves but having a filter wrench might be a good idea.
    Manual calls for 5.9 quarts with Filter. I did 5.5 which put me right in the middle of the dip stick.
    Oil Filter is 90915-YZZN1. Drain bolt still uses the standard blue washer.
    This is the 14mm drain plug. I removed the plastic housing just to see what's under it. There is no reason to remove it, the draining oil will not run under it. If you do take it off, be easy when reinstalling because the bolts screw straight into the block.
    I totally underestimated the flow and made a huge mess as usual.
    Reinstall your drain plug with washer. Plug torque is 40nm according to a post below.
    Next is the filter, it is located on the front of the engine under the skid plate. Remove the 4 13mm bolts to get to it.
    Pretty good design with the little funnel, but you still need a piece of cardboard to keep oil off the frame.
    Don't worry about oil filter part numbers, the 10009 is only used at the factory but its the same thing as the YZZN1.
    Lastly, install your new filter and skid plate and fill with new oil.7816428F-6519-4135-B827-3BB5F354095A.jpg
    That's it, now admire your truck.
  2. Jun 8, 2024 at 9:19 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Thanks for posting this.
    CROM123 and Teuton[OP] like this.
  3. Jun 8, 2024 at 9:23 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    So glad to see its a spin on filter, not one of those horrid cartridge style filters
  4. Jun 8, 2024 at 9:25 AM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    A spin on oil filter.... holy crap!
  5. Jun 8, 2024 at 9:27 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    Nice, I'm doing mine tomorrow, it was a PITA for me to find a oil filter.
    Beaglesridefree likes this.
  6. Jun 8, 2024 at 9:27 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Quality post. Good looking truck.
  7. Jun 8, 2024 at 9:29 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Would make a nice sticky thread!
  8. Jun 8, 2024 at 9:29 AM
    captrussia253
    captrussia253 IG: ruslan.khinotskiy
    PNW
    2017 Tundra CrewMax 2016 Toyota 4Runner
    Love that they went back to the older style oil filter!
  9. Jun 8, 2024 at 9:29 AM
    Bridge1821
    Bridge1821 Member
    Tom
    idahodesert, H3llRid3r and gasgasman like this.
  10. Jun 8, 2024 at 9:38 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
  11. Jun 8, 2024 at 9:50 AM
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    Back to spin-on!
    I'd like to meet the bipolar motherfucker in engineering who decides which gen gets what style filter.
  12. Jun 8, 2024 at 12:10 PM
    stinkyyamalinky
    stinkyyamalinky Well-Known Member
    Great post!
    Any reliable online source selling OEM blue bolt washers? Or am I overthinking that aspect of the oil change?
    Related question: Toyota Care only allows oil changes at factory recommended intervals; if I schedule oil change at 1000 miles they'll say "come back in 4000 miles"?
    Sincerely,
    Admitted Amazon-er/DIYer/oil bolt washer re-user on most everything
  13. Jun 8, 2024 at 12:34 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Thanks for the great post! The pictures really help.
    Dirtsifter and Teuton[OP] like this.
  14. Jun 8, 2024 at 12:38 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    No... they'll charge you the shop rate.
  15. Jun 8, 2024 at 12:43 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    You seem rather wound up about this. In the previous gen, half the Taco world wanted to know why they didn't go with a "normal" filter. But I don't recall anyone using the MF word.
    It's either this guy or one of his other engineers.
    https://youtu.be/rpS1HoA1R4g?si=9tLfAMswyH4gAo38
  16. Jun 8, 2024 at 12:48 PM
    Newwt
    Tampa, FL
    they are all over Amazon, but i prefer the fiber ones
  17. Jun 8, 2024 at 12:53 PM
    Sagebrush
    Gens 1, 2, 3, and 4
  18. Jun 8, 2024 at 1:03 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Just me why is the oil red ?
    TacomaAddict23 and Squirt like this.
  19. Jun 8, 2024 at 1:07 PM
    Mallcrawler20
    must of been added for California… since everything causes cancer in California lol
    TacoSR523 and Digitalwiz5 like this.
  20. Jun 8, 2024 at 1:08 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    That be me, you wanna fight about it?
