4th gen hub size?
Discussion in '4th Gen. Tacomas (2024+)' started by MAGTRD23, Feb 11, 2024.
  1. Feb 11, 2024 at 10:39 AM
    MAGTRD23
    MAGTRD23 [OP] Well-Known Member
    23 TRD OR
    Edit ** found this online——-
    The 2024 Tacoma now has a different hub bore. It went from 106.1 down to 95.1, the bolt pattern is still 6-139.7. **
    Did the hub size change for the 4th gen taco or will 5th gen 4Runner wheels still fit on 4th gen Tacomas?
  2. Feb 11, 2024 at 3:28 PM
    chazmen
    chazmen Well-Known Member
    JT
    The studs are now different, 5th Gen 4Runner wheels will not work
  3. Feb 11, 2024 at 3:29 PM
    MAGTRD23
    23 TRD OR
    No longer 6x139.7 or different size studs themselves?
  4. Feb 11, 2024 at 3:34 PM
    chazmen
    JT
    Not sure on actual specs . Just know they have changed .
  5. Feb 11, 2024 at 3:35 PM
    MAGTRD23
    23 TRD OR
    The studs or the bore??
  6. Feb 11, 2024 at 3:40 PM
    chazmen
    JT
    Studs I believe. I've read it somewhere unfortunately unable to find to attach for you
    shakerhood likes this.
  7. Feb 11, 2024 at 4:13 PM
    BirdBrain
    BirdBrain Well-Known Member
    2021 4wd Off-Road
    The studs are larger now. I believe they increased from 12 to 14mm. Older aftermarket wheels might work but part of the challenge will be the socket clearance for lug nuts or splines.
  8. Feb 12, 2024 at 5:09 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    guess SCS better get to work then
  9. Feb 12, 2024 at 9:05 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Previously M12x1.50, now M14x1.50.
    Jeff
    MAGTRD23[OP] likes this.
  10. Feb 15, 2024 at 1:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Larger studs mean the lugnut shank is larger too. You'll likely need to drill out the lug holes in old OEM wheel to fit.
    Also see this thread: https://www.tacomaworld.com/threads/wescott-designs-put-a-small-lift-and-fit-35s-video.824837/
    Look at the amount of poke with +20mm wheels. OEM 4Runner wheels with +15mm offset will poke out 5mm more than the truck in the video. TRD 4Runner wheels with +5mm offset will poke out 15mm more.
    Visa_Declined likes this.
