4th Gen 4runner Rear Brake Caliper Rebuild
Discussion in '4Runners' started by Benny123, Feb 12, 2019.
  1. Feb 12, 2019 at 11:58 AM
    Benny123
    Benny123 [OP] Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Been looking into doing this, instead of buying a Reman. I have an 07 4runner. Have been getting the rear brakes replaced every 4 years or so. They rust and eventually seize. Feb 1 marks 4 years, so trying to prevent the seize this year. Was going to take them off, wire brush them, clean them up, check pistons out, relube, put new seals in, POR15 caliper paint on them and put them back on with new pads and hardware, then bleed.
    Bought kit 04479-35060
    Process looks straightforward, and only one piston per caliper in the back. Tons of videos on the front, none rebuilding the back.
    Anyone done them?
  2. Feb 15, 2019 at 4:57 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Never done them but are the rears usually the ones that seize up? If so I may be doing this
  3. Feb 15, 2019 at 4:59 PM
    Benny123
    Ben
    South Charlotte, NC
    Yeah I've never had the fronts seize, but I've done the rears twice and headed for a 3rd.
  4. Feb 15, 2019 at 5:01 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    Ok I heard the 4th gens had a problem with brakes seizing and thought it was all 4 that could seize. Is there a reason you haven’t done the upgraded brakes or have you?
  5. Feb 15, 2019 at 5:03 PM
    Benny123
    Ben
    South Charlotte, NC
    There's not much to upgrade. Tried several brands. They're all single piston.
    This year I did make an effort to lube the slide pins. Maybe that'll help.
  6. Feb 15, 2019 at 5:07 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    This is the upgrade I’m referring to it uses 5th gen parts.
  7. Feb 15, 2019 at 5:11 PM
    Benny123
    Ben
    South Charlotte, NC
    Interesting.
    DW85 likes this.
  8. Feb 15, 2019 at 5:22 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    Yea if you didn’t know about it, it could be a possible solution for you. I haven’t had my 4Runner long and haven’t experienced any seizing so far but I’m looking into doing both front and rear to be safe. If it’s more common for the rear to seize than the front I would look into only doing the rear. I’m mostly curious about the bleeding procedure due to the abs system. My Tacoma does not have abs so I have no experience with it.
