4runner wheels on Tacoma and 255/80/17
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Offroadr, Dec 7, 2020.
  1. Dec 7, 2020 at 2:59 PM
    Offroadr
    Offroadr [OP] Well-Known Member
    Hello All,
    Looking to see if anyone has gone with newer 4runner wheels and 255/80/17? Will it rub while turning/articulating while off-roading?
    I’ve read that 255/85/16 on the Tacoma TRD wheels (what I have now on my 2020) fit without rubbing while turning/articulating but I know that the 4 runner wheels have a slightly different offset
    Below is a pic of wheels I’m considering from a few year old 4runner
    FloridaFree likes this.
  2. Dec 7, 2020 at 4:01 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    The Tacoma TRD Off Road wheels are a 16x7” with +25mm offset. The 4runner “snowflake” wheels are also 7” but have a +15mm offset. So that means the centerline of the tire will be out 10mm farther (approx .4”) with the snowflakes. I’m not sure if that will make the 255s rub but my guess will be yes, because the more they stick out, the longer the turning arc.
    Offroadr[OP] likes this.
  3. Dec 13, 2020 at 10:40 PM
    Offroadr
    Thanks for the info! Has anyone tried the snowflake 4 runner tires and 255/80/16 tires?
  4. Dec 14, 2020 at 6:18 PM
    Mi2CaMatt
    Mi2CaMatt Well-Known Member
    M.
    San Luis Obispo, CA
    2016 DCSB TRD OR 6SM 4X4 QUICKSAND
    ALL-PRO sliders and pack rack, Tepui Ayer RTT, Total Chaos Bed Stiffeners, OME 2" Med/Heavy, FJ Steel Wheels, 255 80 R17 BFG KM2s, Wilco Offroad Hitchgate Solo High Clearance
    I can't speak to the 4Runner offset but I can say that the FJ 17" Steelies with 255/80/17 KM2s I have fit just fine. There was some rubbing on the mudflaps at full turn but that was it.
    nictarine and xxTacocaTxx like this.
  5. Dec 31, 2020 at 9:37 PM
    Offroadr
    Bump.. has anyone run 4runner wheels with 255/80/17? There are much better tires made in that size vs 255/85/16
  6. Dec 31, 2020 at 9:48 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    I have the 4runner pro wheels which have a +4mm offset and they don't rub with 255/80r17's
    FloridaFree and Offroadr[OP] like this.
  7. Jan 1, 2021 at 7:00 AM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    No rub at full lock on stock suspension? If so I am pumped because I thought I was going to need a CMC to fit that exact setup with the offset from the SEMA wheels on my stock off road.
  8. Jan 1, 2021 at 7:07 AM
    Silverlogic
    Tyler
    Very minor plastic rub, but not metal rub. I trimmed it. But it probably wasn't necessary.
    SnuggleTruck[QUOTED] likes this.
  9. Jan 1, 2021 at 8:24 AM
    Offroadr
    Have you maxed out the articulation of the truck to see if it rubs while off-roading?
  10. Jan 1, 2021 at 8:31 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It will likely be totally fine. But every truck is slightly different and every brand of tire, even of the same size, will be slightly different. You’ll have to take the plunge and try it.
  11. Feb 9, 2021 at 8:05 PM
    Offroadr
    Bump to see if anyone else can confirm this will work
  12. Feb 9, 2021 at 8:35 PM
    Kingrs1
    Kingrs1 New Member
    Richard
    2019 Red Tacoma Sport 6 Speed
    Truck Shell K&N Air Filter Window Tint Console Organizer Rear Tailgate Letter Front Speakers and JBL Rear
    I have the FJ Cruiser wheels and 265/70-17 and they are great. No rubbing but I did put a 2" lift in front and and a leaf spring in the back which lifted it about 1.5".
    Greenbean and Stocklocker like this.
  13. Feb 10, 2021 at 2:47 PM
    Offroadr
    Looking to run 33x10.5x17 Klever RT on stock OF suspension but hate to buy the tires and 4runner wheels just to find out it’s going to rub off-road
  14. Feb 10, 2021 at 3:00 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    For context, I believe most FJ wheels are +15 the same as the 4runner snowflakes. (Which makes sense because the FJ and the 4runner are the same platform.)
    I did a bunch of research and read a ton of threads a few months ago looking at tires for wheels in the +10 to +15 range. I am 90% sure that you can run 255/80/17 with +15 on or off road with no rubbing except mud flaps. But I don't have personal experience with it.
    Another data point: it's common in the FJ world to run 285/75/16 (much fatter than 255/80/17 and only a smidge shorter) with the stock +15 wheels without any issues. Granted the wheel well is probably shaped differently but it shows it's in the ballpark.
  15. Feb 10, 2021 at 3:04 PM
    rocky_mountain_dave
    David
    What is the diameter? Usually 33s are actually 32.5 which is quite a bit smaller than 255/80/17. If so then you should have absolutely no issues with those 33s. 10.5 width is around a 265.
  16. Feb 10, 2021 at 3:04 PM
    brian2sun
    California
    255s are the only 33s that will fit with stock suspension and no rubbing because they are skinny (~10” wide). You get a 33x10.5 and you can bet that you’re going to rub.
  17. Feb 10, 2021 at 4:17 PM
    Offroadr
    there website says 32.7 and 10.47” wide
  18. Feb 10, 2021 at 4:18 PM
    Offroadr
    You thinking the +.47” in width will cause me to rub with 4 runner wheels?
  19. Feb 10, 2021 at 5:18 PM
    brian2sun
    California
    It’s a good chance that it will. Like I said, the reason 255s work is because they’re so skinny. With tires, often 1/2” wider can make a significant difference on rub.
    Offroadr[QUOTED][OP] likes this.
  20. Feb 10, 2021 at 5:20 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    That looks great. Always nice to see something other than black.
