4Runner vs Highlander
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guyfromky, Feb 24, 2021.
  1. Feb 24, 2021 at 11:20 AM
    guyfromky
    guyfromky [OP] Well-Known Member
    Hey guys! Newer member here. Love the forum and joined a little while back after having my 07 DCSB Tacoma for almost a year now. I never thought I would love the truck as much as I do.
    My wife currently has a 2019 Honda Passport and we are looking to trade it in because we have been largely unimpressed with it. As the title states, would you all recommend a 4Runner or Highlander? Pros? Cons? Yes, we will definitely be test driving them both but would like to know personal experiences or pieces of advice from owners of either model.
    The 4Runners we are looking at are both SR5 options with 3rd row seating, so that does not play a factor. Any input would be greatly appreciated.
    Wasn't sure where to post this, so, being a 2nd gen owner, I threw it in here. Mods can move it if necessary. Thanks so much guys (and gals). Love the forum by the way!
    06AtlTaco likes this.
  2. Feb 24, 2021 at 11:29 AM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Buy her a new Tacoma Double cab.
  3. Feb 24, 2021 at 11:42 AM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    3rd row definitely plays a factor. I have heard pretty lackluster things about the third row in the 4Runner. I think if 3 rows is important to you, go for the Highlander. I would only go for the 4Runner if you're going to take it offroad. Personally I love 4Runners but they are very lackluster in space if you want a family vehicle. I think the Highlander also gets better fuel economy, and you could get a hybrid. My vote is Highlander. You already have your truck for your adventures.
  4. Feb 24, 2021 at 11:42 AM
    guyfromky
    If that was the case, I'd give her mine and buy a Cement 3rd gen :D
    With two kids, we need something with more room.
  5. Feb 24, 2021 at 11:43 AM
    guyfromky
    Excellent points. Thank you for this!
  6. Feb 24, 2021 at 11:48 AM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Obviously you'll know more when you go have a look at them. Set up the third row and get back there and check them both out. See how much trunk space it leaves with it up. If you google them I am sure the Highlander has waaay more storage capacity. Are you looking to buy new or used?
  7. Feb 24, 2021 at 11:49 AM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Both are very different vehicles. Once you drive and think about how you'll actually be using them and the kind of features you want in a vehicle (if you like tech or not), i think the choice will become clear.
  8. Feb 24, 2021 at 11:49 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    What’s the price difference?
  9. Feb 24, 2021 at 11:50 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I have a 2018 4Runner as well with 3rd row seats. Here is what I can tell you after doing my research and picking the 4Runner.
    If you need more leg and and head room for the 2nd and 3rd rows, gas mileage, and creature comforts then the Highlander is a better choice.
    If you need cargo room and like to customize your vehicle then the 4Runner is a better choice.
    The current Highlander is so much more modern than the current 4runner but there are rumors that the 4Runner will be all new for 2022.
    suaveflooder likes this.
  10. Feb 24, 2021 at 11:51 AM
    guyfromky
    Valid points which I will definitely check out. Buying used. The 4Runner has ~40,000 miles and Highlander ~35,000 miles.
  11. Feb 24, 2021 at 11:52 AM
    guyfromky
    Nominal with the 4Runner being slightly more pricey.
  12. Feb 24, 2021 at 11:55 AM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Those are both really low miles so should be fine. 2019s? Wouldn't hurt to look on 4Runner/Highlander forums for problems and things to look at with the year/generation.
  13. Feb 24, 2021 at 12:17 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Like others have said two very different vehicles. Does your wife like to drive a bof frame suv? Like stated above the Highlander does the 3rd row seat better then the 4 runner. I've been looking at 4 runners as well lately. Baby #2 on the way and the t4r looks like it's going to handle the rear facing car seat much better then my double cab tacoma.
  14. Feb 24, 2021 at 12:32 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The 4Runner is closer to truck like performance, ride, and fuel mileage. If you plan to tow or take it off road 4Runner is the best choice. The Highlander is closer to a Mini-Van. And I don't mean that in a negative way. It will cost less get better fuel mileage and probably ride better, but it isn't as capable off road nor for towing
    My wife and I went through the same process. I looked at stuff and spent 3 months researching on line. I initially wanted a RAV-4 to go along with the 4X4 F150 and 4X4 Tacoma in the driveway. But wifey said it was too small. With 2 crew cab trucks we didn't need the capability of the 4Runner and it came down to Highlander or the new redesigned Explorer. We ended up with the Explorer.
    vtown and nictarine like this.
  15. Feb 24, 2021 at 12:37 PM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    Do you have plans to off road with it? If not then just get the highlander.
    I mean you already have a tacoma for off roading so it's not like you need two off road vehicles.
  16. Feb 24, 2021 at 12:40 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Highlander more kid friendly and women too
    Foster1 likes this.
  17. Feb 24, 2021 at 12:40 PM
    OldManTacoFeels
    OldManTacoFeels The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    This right here
  18. Feb 24, 2021 at 12:45 PM
    Hans Moleman
    Bay Area, CA
    Another option is the Lexus GX460. It's bit of a compromise between both but it also has a V8 engine.
    NWTacoTime likes this.
  19. Feb 24, 2021 at 12:52 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I vote 4runner, looks way better than the Highlander. Stand out from the crowd when you are dropping the kids off at school!
  20. Feb 24, 2021 at 1:00 PM
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    Very very different ** vehicles. I just had a loaner 2021 Higherlander Hybrid so i can speak to that and my sister in law has a 2018 TRD Pro 4runner.
    If your wife prefers safety features, just overall comfort functionality (power lift gate, updated technology etc.) then the Highlander is the way to go.
    The hybrid highlander got stupid gas milage, i had it in sport mode the whole time just hauling ass and i couldn't get lower than 30 mpgs..... Imagine if i drove in eco/tried to conserve gas.
    If you care about mpgs/gas price/milage highlander would be better.
    But if you want the 4runner to be sort of a jack of all trades, camping family offroading etc car then i'd get a 4runner.
    I love the 4runner and have wanted my wife to get one, but if i'm being realistic the highlander suits her needs way better than a 4runner at least until they update it. Now if your wife wants to take this offroad then 4runner all the way.
    Also, the highlander is super spacious which caught me off guard
