4Runner Sway Bar on a Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by keninsb, Oct 29, 2013.
  1. Oct 29, 2013 at 8:48 PM
    keninsb
    keninsb [OP] "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    I had a 2008 Tundra and one of the mods that I did (along with many others) was to put a Sequoia front sway bar on the Tundra. The Sequoia sway bar was heavier and had a thicker wall on the construction so it was stiffer. Apparently this was because the Sequoia was more top heavy than the Tundra. I was just wondering if anyone knew if the same applied to the 4Runner and Tacoma? It would be pretty cool if the 4Runner sway bar was stiffer and was a direct fit on the Tacoma. Does anyone know?
    Thanks,
    Ken
  2. Oct 29, 2013 at 8:51 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Not sure, but the TRD sport sway-bar is rumored to be bigger than the base/TRD OR sway-bar.
  3. Oct 29, 2013 at 8:55 PM
    keninsb
    Ken
    Goleta, CA
    Are those on the sport model or are they an accessory purchase?
  4. Oct 29, 2013 at 8:59 PM
    95 taco
    95 taco Battle Born
    They're factory on the sport.
  5. Oct 29, 2013 at 9:08 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    FJ front end is closer in design to the Tacoma than the 4runner...
  6. Oct 30, 2013 at 5:59 PM
    keninsb
    Ken
    Goleta, CA
    Really? That is surprising.
    I did find out that Helwig makes a direct replacement front sway bar (PN 7719) that is supposed to be solid and much stiffer than the OEM sway bar. They also make a rear sway bar (PN 7671). they are pricey, about $225-$250 each, but I bet that they would make the Taco corner MUCH better.
    Ken
  7. Oct 30, 2013 at 6:59 PM
    The Stig
    The Stig Well-Known Member
    Seems like a lot of people here would suggest not having one at all
  8. Oct 30, 2013 at 7:00 PM
    keninsb
    Ken
    Goleta, CA
    I don't follow. Do you mean for off road articulation?
  9. Oct 30, 2013 at 7:07 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    I bought front and rear sway bars for an old GMC PU I owned once (over 20 years ago) upon a time. They used several proprietary bolts that you could only get from Helwig and they were shit quality. I remember a LOT of broken bolts with that set-up and not a major upgrade in cornering power.
    David
  10. Oct 30, 2013 at 7:10 PM
    keninsb
    Ken
    Goleta, CA
    I had one on my 2002 Tundra and it seemed to work well. I think the bolts were standard, but it has been a while.
    That is kind of why I wanted to see if there was a Toyota option. Too bad they don't at least offer a TRD rear sway bar like they do for the Tundra.
    Ken
  11. Oct 30, 2013 at 7:29 PM
    Canazes9
    David
    Texas
    In my opinion, you are looking in the wrong direction. A quality coil over set-up will improve handling and ride over stock, particularly if you set it for minimal lift (typically 1"). Of course you would want to upgrade the rear shocks to a complimentary set at the same time.
    While that is certainly more money than the sway bars you are suggesting, it will be a far more useful suspension upgrade that won't limit your trucks off road capabilities. My '12 Tacoma w/ Bilstein 5100's and Eibach coils and stock swaybar has better handling capabilities than stock despite the mild lift. My wife's new 4Runner I'm running a mildly lifted Icon suspension and it is a significant upgrade over the 5100's on my Tacoma and a huge improvement over stock - again factory swaybar.
    JMO
    David
  12. Oct 30, 2013 at 8:04 PM
    keninsb
    Ken
    Goleta, CA
    I do have a lift on the truck, but rarely if ever off road, I believe it is a 2 1/2" to 3" in the front and 2" in the rear. What coilovers would you suggest to allow me to keep the height and improve the handling? Thanks,
    Ken
  13. Oct 30, 2013 at 9:06 PM
    jmg256
    Al Tonter
    TRD Offroad
    The XRunner came with a factory rear swaybar...might could find one to add to your truck
    Xrunner bars were 1.18" front diameter and 0.98" rear diameter...not sure if front is same design as 4x4/prerunner, doubt it is...different suspension design
    http://www.xr-underground.com/forum/showthread.php?t=23408
    Sittin sic also makes a rear swaybar
  14. Oct 30, 2013 at 11:57 PM
    95 taco
    95 taco Battle Born
    Fox, Icon, King, Sway-a-way......
  15. Oct 31, 2013 at 3:27 AM
    Canazes9
    David
    Texas
    This^^^
    David
  16. Oct 31, 2013 at 10:23 AM
    keninsb
    Ken
    Goleta, CA
    Thanks guys! Great info!!!!!
    Ken
  17. Oct 31, 2013 at 12:21 PM
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    its no rumor, but another user corrected me on that
    sr5 and sport are normal
    offroad is smaller
    i have all three and can verify this for sure
    i also vote sway bar delete :)
  18. Oct 31, 2013 at 4:44 PM
    keninsb
    Ken
    Goleta, CA
    I would LOVE to put a nice set of shocks and coilovers on my truck, but they are just a little pricey for me now. I checked with Matt at TRDSparks (they always give me great prices) and all of the parts that I would need for the XRunner sway bar install would run over $400 after shipping. YIKES!
    When I did a search for Sittin Sic I found THIS website called Twelve (XII) Performance. They have a front and rear kit for $420, but I am not sure if it will work on the 4WD. I am waiting to hear from them, they are actually cheaper and probably better made than the Helwig.
    Ken
  19. Oct 31, 2013 at 8:23 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I have the Helwig rear sway bar. It's night and day difference. The quality of the nuts and bolts are great IMO. The written directions are useless I agree on that but the pictures in the directions made the difference. The truck drives and handles amazing when it is pushed through the corners and canyon roads I drive through. I plan to add the front Helwig sway bar soon. It definitely puts the Sport in the TRD Sport :thumbsup:
  20. Nov 1, 2013 at 12:50 PM
    keninsb
    Ken
    Goleta, CA
    Good to know LH. Helwig used to be the name to get for sway bars, I was really surprised at the negative comments on TW. I had one on my '02 Tundra and it worked great. I did have to order some longer end links for my 2" lift, but it still worked great.
    Ken
