4runner suspension swap to Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomandan08, Jan 11, 2018.
  1. Jan 11, 2018 at 8:24 AM
    Tacomandan08
    Tacomandan08 [OP] Well-Known Member
    Daniel
    2008 Toyota Tacoma trd off road
    6in procomp lift, 17in method wheels,35" bag tires
    Does anyone know for sure if the 4Runner front suspension can bolt up to our 2nd gen Tacoma’s? I’m curious because I’m reading everywhere that it would work but the Tacoma suspension onto a 4runner adds lift. So I’m assuming if i added front 4runner suspension it would lower my Tacoma. If anyone knows for certain and hopefully give me some insight on this. Thanks guys!
  2. Jan 11, 2018 at 8:39 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Do you want to lower your tacoma? I believe the lower bushings are too wide to fit into the tacoma LCA, so you would need to swap them or cut them down.
  3. Jan 11, 2018 at 8:42 AM
    Tacomandan08
    Daniel
    No i don’t want to lower my Tacoma. I’m selling fox coilovers for a 4runner or fj Cruiser and I’m getting a lot of questions if these would fit a Tacoma. Everywhere I’m reading says it bolts right up but I’m not 100% sure and i don’t want to misinform anyone buying these coilovers from me.
    Levalexi likes this.
  4. Jan 11, 2018 at 8:43 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    What year 4Runner?
  5. Jan 11, 2018 at 8:45 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    I think 03-09 4Runner is the same, at least that’s what Wheelersoffroad site tells me.
  6. Jan 11, 2018 at 8:53 AM
    Tacomandan08
    Daniel
    I have a set of brand new fox coilovers for a 03-18 4runner or 07-14 fj. Part # 883-02-111.
  7. Jan 11, 2018 at 8:58 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Those don’t cross reference, call Fox and ask. May be as simple as a different spacer for the lower mount.
  8. Jan 11, 2018 at 9:14 AM
    Tacomandan08
    Daniel
    I’ll give them a call. Thanks!!
  9. Jan 11, 2018 at 9:15 AM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Just curious what your selling this for, provided they fit a tacoma?
  10. Jan 11, 2018 at 9:18 AM
    Tacomandan08
    Daniel
    So long story short is that i needed the Fox coilover for the bds kit 883-02-048 and purchased them on eBay but when i received the coilovers they were for a 4runner or fj (883-02-111). Ebay seller disappeared, can’t get my money back, now I’m stuck trying to sell these so i can fund the right coilovers for my truck.
  11. Jan 11, 2018 at 10:08 AM
    Tacomandan08
    Daniel
    Just spoke with fox. Coilovers will mount right up. Only differences are the overall length(1/4in difference) heavy duty valving in the shock, better for Tacoma’s that want to overland because 4runners and fj’s are heavier and more travel, also better for Tacoma’s. Length isn’t much of an issue because the coilovers are adjustable.
    Hugz likes this.
  12. Mar 16, 2021 at 11:36 PM
    Hugz
    Hugz Member
    Hugz
    2006 grey tacoma
    Nothing
    so it will fit all around? front and back?
  13. Apr 29, 2021 at 7:52 AM
    BudLoomis
    BudLoomis Well-Known Member
    Colorado
    2018 TRD Off-road
    Toytec Aluma Series 2.0 (2.5" x 3.5" lift), JBA UCA, Deaver stage 3 Leaf pack, CMC, Viair OBA set-up, KBVOODOO mid rack, Roofnest Condor RTT, CaliRaised Premium Roof Rack w/ 360 lighting, Custom Bed box w/ camp stove built in
    So the 4runner coilovers is 1/4" longer than the tacoma?
  14. Apr 29, 2021 at 7:56 AM
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    Should fit no problem. 4R lca has a narrower pocket for the stock mount. When putting taco front suspension on 4r you have to grind down the bushings or the lca mount. Going 4r to taco should bolt right up
    BudLoomis and y=mx+b like this.
  15. Apr 29, 2021 at 9:01 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Idk if this helps. I swapped 5th gen 4runner shocks into my 4th gen and the lower eye hole of the shock was to wide to fit the lca. Had to grind it down a little bit.
