4runner ecu into Taco 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by SuperJ, Jan 12, 2019.
  1. Jan 12, 2019 at 12:27 PM
    SuperJ
    SuperJ [OP] Member
    98 Tacoma TRD
    Hey members, has anyone used a 97 4runner ecu in a 98 tacoma ? Thanks !
  2. Jan 13, 2019 at 11:28 AM
    SuperJ
    SuperJ [OP] Member
    98 Tacoma TRD
    Will it work ?
  3. Jan 13, 2019 at 11:31 AM
    UnderFire
    UnderFire Well-Known Member
    Yes it will. We swapped a 97 4Runner ECU into a 99 Tacoma with no issues.
  4. Jan 13, 2019 at 11:37 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  5. Jan 13, 2019 at 12:11 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If the numbers on the ECM match your good to go.
    If not things will get real interesting perhaps
  6. Jan 13, 2019 at 12:15 PM
    SuperJ
    SuperJ [OP] Member
    98 Tacoma TRD
    The engine cranks but new fuel pump is not getting any power,circuit opening relay will only click with direct power.I swapped in a 4runner ecu with no luck either.
  7. Jan 13, 2019 at 12:26 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    What you need to do is sit down with the Toyota EWD for your truck and for the 4 runner it came out of.
    Re pin your harness to match the 4 Runner ECM
    What you just did is the same as most any 3.4 engine swap.
    This is gonna be interesting .
    Maybe start where this all begun to reach this point ?
  8. Jan 13, 2019 at 12:33 PM
    SuperJ
    SuperJ [OP] Member
    98 Tacoma TRD
    Wyoming09, are you saying the pins are configured differently?
  9. Jan 13, 2019 at 12:38 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    They would be configured differently. Even on Tacomas, the connectors and pin outs changed every single year. Even some ECU’s of the same year would be different between engines and drivetrains.
    You need to match the ECU part number already on your truck.
    Hamer95USA likes this.
  10. Jan 13, 2019 at 12:43 PM
    SuperJ
    SuperJ [OP] Member
    98 Tacoma TRD
    Thanks all !
  11. Jan 13, 2019 at 1:52 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I hope you have done enough trouble shooting you know for sure it is the ECM
  12. Jan 13, 2019 at 2:15 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Denso had an employee leak some crazy stuff on supra forums about their ecu’s and other Supra owners had backed him on it, he said: with the Denso computers they can take them apart and replace most or all of the capacitors and usually when in there, the ecu has water damage or broken cold solder joints to the board from the caps and can be replaced with newer caps and its somehow a way to get actual hp. I need to dig up the link as to where you can actually get the parts to fix it.
  13. May 27, 2019 at 1:01 PM
    SuperJ
    SuperJ [OP] Member
    98 Tacoma TRD
    Here's the culprit. FYI the 97 4Runner ECU will not work on a 98 Taco.tacomaplug.jpg
