4Lo... when to use it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymoussy, Jan 29, 2024.
  1. Jan 29, 2024 at 11:25 AM
    jaymoussy
    jaymoussy [OP] Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    For the first time in a few years, I set the truck to 4Lo, near the end of my 1/2 mile usual 4H mini-maintenance run, on the long straight leading to my house.
    Should I have operated the 4Lo more often?
    Works as expected anyway, with its flashing yellow reminder.
    Now to the main question, when do you use 4lo in real life (Taco is 4-in-line, auto)?
  2. Jan 29, 2024 at 11:28 AM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    I've used it in very soft & deep sand/snow. Or when hung up on something and need to lock out the rear diff
    Marc70 likes this.
  3. Jan 29, 2024 at 11:30 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I generally have only needed it in a recovery situation. Thats so I can lock the rear and be a gentle as possible to the other vehicle. But I occasionally use it for steep slow climbs. Its more for comfort than anything that I've seen.
    Marc70 likes this.
  4. Jan 29, 2024 at 11:33 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    It's generally good practice to use 4LO if you are on technical trails. Not only for the lower gearing but it also help keep trails in better shape. For example, some of the more out-there trails in Canyonlands must be in 4LO after a certain point.
    stevesnj likes this.
  5. Jan 29, 2024 at 11:47 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, if anything switch it to 4LO every couple months.
    Even if you don't drive it, at least switch it to 4LO.
    Doing this will exercise the actuator on the transfer case fully across all the traces. The actuator has a set of sliding electrical contacts.
    By operating the actuator you are wiping the contacts "clean" each time.
    90% of all the 4WD failures on these trucks are from the actuators.
    There are 2 on the truck. One on the front differential, and one on the transfer case.
    If you have a locker, you also have one more on the rear differential.
    Here are what the traces look like
    EMR, Williston, Logger and 9 others like this.
  6. Jan 29, 2024 at 5:02 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I try to get into 4hi as much as possible. Any time I'm on a dirt or gravel road for even a mile or so. I work out low range less often. 4hi will keep everything lubricated, but 4 lo occasionally will help with the electronics.
    jaymoussy[OP] and Canadian Caber like this.
  7. Jan 29, 2024 at 5:11 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Living in the concrete jungle I try to get it into 4H 2-3 times a month driving straight. I'll toggle back and forth between 2H and 4H 3-4 times. I'll go out of my way and find a quiet spot once a month on any surface and get it in and out of 4L a few times.
    After a while you will know when you need to use 4L. Even if off roading and I don't need 4L, I use it as an opportunity to exercise 4L for sure.
    Marc70 likes this.
  8. Jan 29, 2024 at 5:23 PM
    TacoTuesday1
    FL
    Maintenance says do it once a month.
    4x is generally for off roading loose terrain.
  9. Jan 29, 2024 at 5:49 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It's for control. I can tell when it's time by having to use my clutch a lot. If auto. you can think of that situation.
    BC Hunter likes this.
  10. Jan 29, 2024 at 9:53 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    If the 4lo was flashing. That means it wasn’t on.
    you have to be in neutral to switch it to 4lo.
    I use 4lo when it’s really rocky and I need better throttle control. Also, once in a while in steep sand dunes.!
    BC Hunter and Marc70 like this.
  11. Jan 30, 2024 at 5:25 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Every weekend for us during cabin season: steep rocky ascent and descent to get in and out.
    In winter on deep snow or unplowed roads.
    Whenever conditions warrant.
    bhigbee and Canadian Caber like this.
  12. Jan 30, 2024 at 5:32 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    4Lo is essential is essential when i rock crawl. Then if needed I will triple lock.
    nudavinci64[QUOTED] and shaeff like this.
  13. Jan 30, 2024 at 7:54 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I use 4lo often off road, I go, am I going to be doing more than 40mph in this section of off road? No 4Lo it is, gives me more gear options, easier on the transmission (if auto keeps things cool, if manual makes it easy on your clutch) etc etc. I see people all the time refusing to use 4Low for whatever reason when you can be so precise and easier on your truck with such minimal throttle inputs vs 4Hi.
    cruxofthebisquit, shaeff and stevesnj like this.
  14. Jan 30, 2024 at 8:04 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    when do I use it?
    the first time i towed my new camper home and went up my long steep drive, the taco was not happy. It went, but complained the whole time. So now when i come home, i switch to 4 lo going up the driveway and the truck smiles, happily pulling 4000 lbs uphill.
    i also use it for snow plowing. i basically let the truck just drive, not much gas is needed, keeps the speed low which is good for all components while plowing, and in my case i get to use atrac which helps when slipping and plowing uphill.
    nd4spdbh likes this.
  15. Jan 30, 2024 at 4:02 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    I need 4L occasionally to power through the barrier the snow plow leaves at the end of the driveway. When the truck bogs down and struggles or can't make it through in 4H, I stop and select 4L and it easily powers right through. (it's also easier on the transmission) Other than that: steep down hills on slippery off-road trails so I don't have to use the brakes to reduce speed and risk locking up the wheels.
