4 Wheel Drive blinking indicator light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maddog721, Jan 7, 2012.
  1. Jan 7, 2012 at 3:12 PM
    Maddog721
    Maddog721 [OP] New Member
    Bill
    Midwest
    Tacoma 4x4 SR5
    I have a 2006 Tacoma Double Cab SR5, 4x4, automatic with ~61,000 miles. I'm the original owner and all the scheduled maintenance done. Never a problem with this truck, until now.
    Over the holiday period, the road conditions were bad and I switch from 4x2 to 4x4 (at about 30 MPH) but the indicator light just blinked. It blinked for about 4 or 5 minutes and I wasn't sure if I was in 4x4. I pulled off the road, stopped, then felt/heard "the slight clunk" (as in the past) and the light stayed on. I was definitely in 4x4. Later, the road conditions improved and I switched back to 4x2 and again, the light just blinked. I decided to "let nature run its course” and after about 10 minutes (accelerating/decelerating along the way), the light final went out. Next day I tried it again and same thing happen. This is not normal.
    Any suggestions on possible cause / solutions?
    Love my truck but need my 4x4.
  2. Jan 7, 2012 at 3:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    How often do you use your 4x4 and when was the last time before the other day??
  3. Jan 7, 2012 at 3:22 PM
    Maddog721
    Bill
    Midwest
    Tacoma 4x4 SR5
    Good question....may last winter. This was the first time "this season" I had to use the 4x4.
    Thoughts?
  4. Jan 7, 2012 at 3:24 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    did you actually use(see the front wheels spinning or feal it pulling) the 4 wheel drive?almost sound like it never engauged,but with the clunk it might of.when mine clunks its in........but you can never trust a $2 light bulb
  5. Jan 7, 2012 at 3:25 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    maybe it's the 4x4 actuator motor assembly, it's a common problem..it's not sealed very well from the factory and sometimes it gets all boogered up inside. you can try taking the whole assembly off and try to clean all of the contacts with WD-40. usualy that will work. send BrandonH a PM..he has to do this frequently with his and im sure he can chime in with more useful info.
  6. Jan 7, 2012 at 3:26 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Takes a little bit before it goes in if it hasn't been exercised on a regular basis. Sometimes turning the wheel and tapping the brakes will allow the transfer case to line up properly.
    WNYTACOMA likes this.
  7. Jan 7, 2012 at 3:36 PM
    Maddog721
    Bill
    Midwest
    Tacoma 4x4 SR5
    Thanks for the info and suggestions...will try.
  8. Nov 24, 2012 at 12:56 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    resurrecting this thread..
    went to use 4 hi last week and the light just blinked. after 10 minutes of messing with the truck (drive forward, backwards, turn wheels ect ect) it finally went in.
    now occasionally the indicator light blinks at me for a few miles then goes out.
    I use 4wd ocassionally, not seasonally.
    signs of the actuator going south?
  9. Nov 24, 2012 at 1:13 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Not necessary.
    Problem with our 4x4 its sensitive, and like its buttons pushed often like a women.
    Things to check.
    1. How fresh and level of front differentail oil.
    2. How fresh and level is transfer case.
    Both may need fresh oil and oil needs to be at the fill hole level.
    Once those things are check find little dirt road and drive slowly. Then engage 4x4 drive for a minute disengage (regardless if locked or not) do that few times to get things lubricated.
    4x4 needs to be on/off at least once a moth to get things lubricated
  10. Nov 25, 2012 at 8:36 AM
    nj636
    Kev
    Jersey
    both diff's and t-case were dumped 6 weeks ago, fresh fluid dripping out of the fill hole.
    I use 4wd a few times every month or so (for play and fishing on the beach)
    a little more research in my future..
  11. Nov 25, 2012 at 8:40 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You have to be driving in an almost perfect straight line for 4H to engage. Probably because the front ADD has to line up.
  12. Nov 25, 2012 at 10:20 AM
    BlueT
    NorthEast
    If all that checks out then your next most likely culprits are sensors. transfer case and front ADD have these switch like sensors. They are simple design but when they get stuck they will do something similar. You going have to remove them and check if they are ok. Sensors should be grey with nut like base to unscrew them from the housing. Transfer case should have two of them one for 4hi one for 4 low. Then there is one on front actuator.
    JohnnyB17 likes this.
  13. Nov 25, 2012 at 10:48 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    If/when this happens I find that slipping the transmission into neutral before actuating four wheel drive tends to take all of the pressure/bind out of the drive train and allowing it to go into 4x4 instantly. Or instead of neutral, take your foot off the gas and coast while switching to 4x4
    Ymmv
    jetfishn and blefferd like this.
  14. Nov 25, 2012 at 10:57 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    ^ Happend to me
  15. Dec 23, 2012 at 6:35 AM
    nj636
    Kev
    Jersey
    so this happened again this weekend. was riding some trails that has some soft sand spots. remembering this problem, I went to go into 4hi just to make sure it went in and I wouldn't be fooling with it when I actually needed it.
    I tried going into 4hi multiple ways; stopped, driving 20 mph & under, accel, decel, coasting to a stop. you think of it I tried it. eventually it went right into 4hi and then into 4lo, came right out of 4 wheel and went back into 4 wheel with no problem.
    I'm going to be removing the actuator to see what's going on in there, I just wanted to update this issue.
  16. Dec 23, 2012 at 10:48 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    BLINKING means you turned the dial, but it is not yet in H4... try slowing, taking your foot off the gas pedal. The clunk sound/ feel is when it goes in or our of 4WD. The light will stop blinking. I wouldn't drive for 10 minutes with it blinking... obviously you don't need to be in 4WD if you can drive for 10 more minutes?! If it doesn't stop blinking, and you did what I suggested above, turn the dial back to H2, and then repeat. Read the card that is in your sun visor if you don't believe me. Fortunately, I have never had a transfer case/ selector issue with my three Tacomas... but I do use 4WD monthly (as requested by Toyota) and let off on the gas if shifting into 4WD while moving.
  17. Dec 23, 2012 at 10:56 AM
    DikDikerson
    DikDikerson Well-Known Member
    Devon
    Calgary
    13' 4x4 DCLB TRD Sport
    Anyone have trouble switching back and forth in cold temps? It was -25C with the wind last night and could not get the truck to switch from 2 to 4H, took about 10 mins of trying everything mentioned before.
  18. Dec 23, 2012 at 11:00 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I read your post super fast and was about to ask you where do I spray the WD-40 in the actuators every month. :facepalm:
    Derp :eek:
    Noch and Mr.PowerTrays like this.
  19. Dec 23, 2012 at 11:09 AM
    David K
    No WD-40 yet! Is tuna oil in the actuator really helpful? I guess to keep water out!?
  20. Dec 23, 2012 at 2:19 PM
    nj636
    Kev
    Jersey
    now the four-wheel-drive light blinks while I'm driving down the road in 2 wheel. I'll report back after I diagnose.
