4 Tire Inflation System
Discussion in 'Wheels & Tires' started by guwoptaco, Oct 23, 2019.
  1. Oct 23, 2019 at 8:16 AM
    guwoptaco
    guwoptaco [OP] Well-Known Member
    2018 Magnetic Long Bed OR
    https://youtu.be/bYqeXxEItDI inflate + deflate all tires at once.
    Tried the search feature, but.. well, try searching tires on this forum. :crazy:
    Does anyone know where I can find a write up for something like the above video, only spec’d to a Tacoma(long bed preferred)? I want to do it myself, and I’d like to do it right the first time. Me and measurements are a hit or miss thing.
    Manfred likes this.
  2. Oct 25, 2019 at 9:04 AM
    pro2aaf
    pro2aaf Well-Known Member
  3. Oct 25, 2019 at 9:11 AM
    Shellshock
    Iowa
  4. Oct 25, 2019 at 9:13 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I've got the indeflate system on order for a while now. They've got 2 or 4 tires it can do at once. I have an ARB dual so it'll run well. Looking forward to it. The money we spend to be lazy...
  5. Oct 25, 2019 at 9:15 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    @Shellshock 's setup is too damn easy. You'll see mine at the end of his linked thread. I went a slightly different route on the connections because I'm a dork.
    That said, those valve stem clamps are killer. The ease of use has me checking pressures at home a bit more often.
  6. Oct 25, 2019 at 12:22 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    I really like the indeflate system. @G.T. has it and it’s super quick to drop air from the tires. Way faster than my air chuck.
  7. Oct 25, 2019 at 12:23 PM
    su.b.rat
    su.b.rat broken truck
    i have @Shellshock's setup with Flexzilla lines. i would only do two tires, because i run different pressures front & rear.
